Manual Chapter :
Configuring SSL with mirroring
Applies To:
Show Versions
BIG-IP APM
- 16.1.5
BIG-IP ASM
- 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0
You need to create an SSL certificate and custom
SSL profile for secure communications between the two mirrored devices.
- Enable sys db:
- tmsh modify sys db statemirror.secure value enable
- tmsh modify sys db statemirror.verify value enable
- On the Main tab, click and create a new SSL certificate.Standard SSL certificates are not supported for this feature.
- On the Main tab, click . The SSL Server profile list screen opens. Create a new SSL profile with the created SSL certificate and with "Cache Size" = 0.See the BIG-IP System: SSL Administration Guide for more information on creating a custom SSL profile.
