Manual Chapter : Restoring Snapshots
Applies To:
  • F5 SSL Orchestrator
    17.0.0
Restoring Snapshots
Restoring configurations from a snapshot deletes all existing configurations and restores the device status to the same state as it was when it was backed up. When you modify a restored configuration and delete it, SSL Orchestrator reverts it to its last deployed (restored) state.
To restore the working configuration using a selected snapshot as input, do the following:
  1. Navigate to SSL Orchestrator > Configuration and click the
    icon. The SSLO Snapshots screen opens with a list of backups that have been created on this device.
  2. To restore a specific snapshot, select the check box to the left of the snapshot and click Restore.
  3. The restoration process begins. This might take some time. Once the process starts, you will be blocked from performing any other tasks or interacting with the UI in any way until the process is completed.
  4. Refresh the SSL Orchestrator page for the updated status of the process.
