Manual Chapter : Integrating C3D with SSL Orchestrator
Applies To:
  • F5 SSL Orchestrator
    17.1.0
  1. Create a client SSL profile in LTM with Client Certificate Constrained Delegation enabled.
  2. Create a server SSL profile in LTM with Client Certificate Constrained Delegation enabled.
For more information, refer Configuring Client Certificate Constrained Delegation (C3D) (f5.com)
Starting 11.0, you can integrate Client Certificate Constrained Delegation (C3D) SSL profiles in SSL Orchestrator from the user interface. The C3D SSL profiles are listed in the Protocol Settings section of the Interception Rules tab. You can replace the client and server SSL profiles created by SSL Orchestrator, with C3D SSL profiles in the Interception Rules tab of an inbound topology (for both Gateway mode and Application mode).
Perform the following steps to integrate C3D with SSL Orchestrator:
  1. Deploy an inbound topology.
  2. Select the inbound topology, and then click the Interception Rules tab.
  3. In the Protocol Settings section, remove the default SSL client and server profiles (created by SSL Orchestrator), and then add the C3D client and server profiles from the lists.
  4. Click Deploy.
