Updated Date: 07/07/2026
Configuring SSL with mirroring
You need to create an SSL certificate and custom SSL profile for secure communications between the two mirrored devices.
Enable sys db:
tmsh modify sys db statemirror.secure value enabletmsh modify sys db statemirror.verify value enable
On the Main tab, click System > Certificate Management > Traffic Certificate Management > SSL Certificate List and create a new SSL certificate.
Standard SSL certificates are not supported for this feature.
On the Main tab, click Local Traffic > Profiles > SSL > Server. The SSL Server profile list screen opens. Create a new SSL profile with the created SSL certificate and with “Cache Size” = 0.
See the BIG-IP System: SSL Administration Guide for more information on creating a custom SSL profile.
