When you want the BIG-IP system to process application traffic over SSL, you can configure the
system to perform the SSL handshake that destination servers normally perform. This ability for
the BIG-IP system to offload SSL processing from a destination server is an important feature of
the BIG-IP system.
In this release, TLS 1.3 is supported with RFC 8446.
The most common way to configure the BIG-IP system is to create a Client SSL profile, which
makes it possible for the BIG-IP system to decrypt client requests before sending them on to a
server, and encrypt server responses before sending them back to the client.
Within a Client SSL profile specifically, you can specify multiple certificate/key pairs, one
per key type. This enables the system to accept all types of cipher suites that a client might
support as part of creating a secure connection. The system then decrypts the client data,
manipulates any headers or payload according to the way that you configured the Client SSL
profile, and by default, sends the request in clear text to the target server for processing.
For those sites that require enhanced security on their internal network, you can configure a
Server SSL profile. With a Server SSL profile, the BIG-IP system re-encrypts the request before
sending it to the destination server. When the server returns an encrypted response, the BIG-IP
system decrypts and then re-encrypts the response, before sending the response back to the
client.
About client-side and server-side SSL
profiles
You can manage the way that the BIG-IP system processes SSL application traffic by configuring
two types of SSL profiles: A Client SSL profile, a Server SSL profile, or both. These profiles affect the
way that the system manages SSL traffic passing through the system.
When you configure Client
SSL or Server SSL profiles and assign them to a virtual server, the BIG-IP system
offloads SSL processing from the destination server. This offloading not only conserves resource on destination servers, but enables the BIG-IP system to
customize SSL traffic processing according to your configuration specifications.
Create a custom Client SSL profile
You create a custom Client SSL profile when
you want the BIG-IP system to terminate client-side SSL traffic for the purpose of
decrypting client-side ingress traffic and encrypting client-side egress traffic. By
terminating client-side SSL traffic, the BIG-IP system offloads these
decryption/encryption functions from the destination server. When you perform this task,
you can specify multiple certificate key chains, one for each key type (RSA, DSA, and
ECDSA). This allows the BIG-IP system to negotiate secure client connections using
different cipher suites based on the client's preference.
At a minimum, you must specify a certificate key chain that
includes an RSA key pair. Specifying certificate key chains for DSA and ECDSA key
pairs is optional, although highly recommended.
On the Main tab, click
Local Traffic
Profiles
SSL
Client
The Client SSL profile list screen opens.
Click
Create
The New Client SSL Profile screen opens.
In the
Name
field, type a unique name for the profile.
From the
Parent Profile
list, select
clientssl
Select the
Custom
check box.
The settings become available for change.
From the
Configuration
list, select
Advanced
For the
Mode
setting, select the
Enabled
check
box.
For the
Certificate Key Chain
setting, click
Add
From the
Certificate
list, select a certificate name.
This is the name of a certificate that you installed on the BIG-IP system. If you have not generated a certificate request nor installed a certificate on the BIG-IP system, and the BIG-IP system is not part of a device service clustering (DSC) configuration, you can specify the name of the existing certificate named
default
If the BIG-IP system is part of a DSC Sync-Failover group, always select a non-default certificate name, and ensure that this same certificate name is specified in every instance of this SSL profile in the device group. Taking these actions helps to ensure that SSL handshakes are successful after a failover event.
From the
Key
list, select the name of the key associated with the certificate specified in the previous step.
This is the name of a key that you installed on the BIG-IP system. If you have not installed a key on the BIG-IP system, and the BIG-IP system is not part of a device service clustering (DSC) configuration, you can specify the name of the existing key named
default
If the BIG-IP system is part of a DSC Sync-Failover group, always select a non-default key name, and ensure that this same key name is specified in every instance of this SSL profile in the device group. Taking these actions helps to ensure that SSL handshakes are successful after a failover event.
From the
Chain
list, select the chain that you want to include in the certificate key chain.
A certificate chain can contain either a series of public key certificates in Privacy Enhanced Mail (PEM) format or a series of one or more PEM files. A certificate chain can contain certificates for Intermediate certificate Authorities (CAs).
The default self-signed certificate and the default CA bundle certificate are not appropriate for use as a certificate chain.
For the
Passphrase
field, type a string that enables access to SSL certificate/key pairs that are stored on the BIG-IP system with password protection.
This setting is optional. For added security, the BIG-IP system automatically encrypts the pass phrase itself. This pass phrase encryption process is invisible to BIG-IP system administrative users.
Click
Add
In the
setting, click
Add
again, and repeat the process for all certificate key chains that you want to
specify.
At a minimum, you must specify an RSA
The result is that all
specified key chains appear in the text box.
The
OCSP Stapling
setting
allows you to select an SSL Online Certificate Status Protocol (OCSP) stapling
profile which contains various OCSP stapling parameters. By default this setting
is disabled. To enable OCSP stapling, select the
OCSP Stapling
check
box.
To enable OCSP stapling, you must first
create an OCSP Stapling profile. See
Creating an
OCSP stapling profile
for detailed steps.
If you want to
Notify Certificate Status to Virtual
Server
, select the check box.
This setting is used to communicate
SSL certificate revocation status to the virtual server. This is typically
implemented in conjunction with an OCSP stapling
configuration.
The
Ciphers
setting is optional. By default, the Client SSL profile uses the DEFAULT cipher string. In most cases, the DEFAULT cipher string is appropriate, but you can customize it as necessary to meet the security and performance needs of your site. Specify a cipher group or cipher string by choosing one of these options.
If you specified an ECDSA certificate key chain in the
setting, you must include the cipher string
ECDHE_ECDSA
in the cipher group or cipher string that you specify in the
Ciphers
setting. (At a minimum, you should specify a cipher group or string such as
DEFAULT:ECDHE_ECDSA
.) This is necessary to ensure successful cipher negotiation when the BIG-IP system is offered an ECDSA-based certificate only.
Option
Description
Cipher Group
Select an existing cipher group from the list when you want to use a system-defined or custom cipher group to define the ciphers that the BIG-IP system uses for negotiating SSL connections. Here's an example of the
Ciphers
setting where we've selected a custom cipher group that we created earlier.
Cipher String
Type a cipher string in the box if you want to manually specify a cipher string instead of selecting a cipher group. For security and performance reasons, consider following these recommendations:
Always append ciphers to the
DEFAULT
cipher string.
Type a cipher string that includes the ECC key type, because its shorter length speeds up encryption and decryption while still offering virtually the same level of security.
Disable ADH ciphers but also include the keyword
HIGH
. To do this, just include both
!ADH
and
:HIGH
in your cipher string.
For AES, DES, and RC4 encryption types, make sure you specify the DHE key exchange method. DHE uses
Forward Privacy
, which creates a key that it throws away after each session so that the same session key never gets used twice. When you use DHE, make sure that the SSL private key isn't being shared with a monitoring system or a security device like an intrusion detection or prevention system. Also, diagnostic tools like
ssldump
won't work when you're using Forward Secrecy.
Disable EXPORT ciphers by including
!EXPORT
in the cipher string.
If you can live with removing support for the SSLv3 protocol version, do it. This protocol version is not secure. Simply include
:!SSLv3
in any cipher string you type.
Ciphers
setting where we have opted to manually type the cipher string
setting, references the Options List setting, which are industry standard SSL
options and workarounds use for handling SSL processing. The default setting is
All Options Disabled. By default, TLSv1.3 is disabled in this
configuration.
The
Options List
setting provides selection from a set of industry
standard SSL options and workarounds for handling SSL processing.
The
Data 0-RTT
setting when Enabled, specifies that you can
initiate a server connection for early data so to receive the benefits of early
data delivered to the server-side early. The default value is Disabled.
When the
Proxy SSL
setting is enabled, the client can
directly authenticate with the server, and the server can authenticate with the
client, based on the client certificate presented. In a typical setup, with the
BIG-IP system in the middle, the client and server cannot communicate directly
to authenticate each other. The Proxy SSL setting requires both a Client SSL
profile and a Server SSL profile, and you must enable the setting in both
profiles. For information about the Proxy SSL setting, refer to the following
resources:
setting allows Proxy SSL to
pass traffic when the cipher suite negotiated between client and server is not
supported. Disabled by default. If you enable it, you should enable this setting
on the server SSL profile as well.
The
ModSSL Methods
setting enables or disables ModSSL
method emulation. Disabled (cleared) by default. Enable this setting when
OpenSSL methods are inadequate. For example, enable it when you want to use SSL
compression over TLSv1. When you enable this setting, you can then write an
iRule, using the
HTTP::header
insert_modssl_fields
command, which inserts some of the ModSSL
options as headers into HTTP requests. See
ModSSL options for use with
iRules
section of the
Additional SSL Profile Configuration
Options
chapter in this guide.
The
Cache Size
setting specifies the maximum number of
SSL sessions allowed in the SSL session cache. The default value for Cache Size
is 262144 sessions. A value of
0
disallows session caching.
The
Cache Timeout
setting specifies the number of
seconds that the system allows SSL sessions to remain in the SSL session cache
before removing them. The default value for Cache Timeout is 3600 seconds. The
range of values configurable for Cache Timeout is between 0 and 86400 seconds
inclusive.
Longer cache timeout periods can
increase the risk of SSL session hijacking.
The
Alert Timeout
setting specifies the duration that
the system tries to close an SSL connection by transmitting an alert or
initiating an unclean shutdown before resetting the connection. Select
Indefinite to specify that the connection should not be reset after transmitting
an alert or initiating an unclean shutdown. The BIG-IP system sends an RST once
the Alert Timeout value has been reached, forcefully aborting the connection
early and reducing the amount of data transferred between the peer system and
the BIG-IP system. The Immediate value makes the BIG-IP system reset both client
and server side flows after 1/1000 seconds.
The
Handshake Timeout
seconds that the system tries to establish an SSL connection before terminating
the operation. Selecting Indefinite specifies that the system continues trying
to establish a connection for an unlimited time.
Configure the
Renegotiation
setting to control if the
virtual server allows midstream session renegotiation. When enabled (default),
Renegotiation allows the BIG-IP system to process midstream SSL renegotiation
requests. When disabled, the system either terminates the connection or ignores
the request, depending on system configuration. See
Additional SSL
Profile Configuration Options
chapter in this guide for more
details.
The
Renegotiation Period
setting indicates the amount of
time before the system renegotiates the SSL session after the initial
connection. If you set it to Indefinite (default), the system does not
renegotiate the SSL session.
The
Renegotiation Size
application data in megabytes the system must receive from the time of initial
connection before it renegotiates the SSL session. If set to Indefinite
(default), the system does not renegotiate the SSL session.
The
Renogotiate Max Record Delay
number of SSL records allowed during the SSL renegotiation before the system
terminates the connection. If set to Indefinite, the system allows an unlimited
number.
The
Secure Renegotiation
setting specifies the method of
secure renegotiation for SSL connections. The default value for the Client SSL
profile is
Require
. The values for the Secure
Renegotiation setting in the Client SSL profile are as follows:
Request
: Specifies that the system requests
secure renegotiation of SSL connections.
Require
: Specifies that the system requires
secure renegotiation of SSL connections. In this mode, the system
permits initial SSL handshakes from clients but terminates
renegotiations from clients that do not support secure
renegotiation.
Require Strict
requires strict, secure renegotiation of SSL connections. In this mode,
the system denies initial SSL handshakes from clients that do not
support secure renegotiation.
The
Max Renegotiation
number of SSL renegotiation attempts per connection that the system can receive
in one minute before renegotiating an SSL session. For example, one client with
three connections may have a maximum number of SSL renegotiation attempts equal
to three times the configured Max Renegotiation value. After the system receives
this number of SSL renegotiation records, it closes the connection. This setting
applies to client profiles only. The default value is 5.
The
Max Aggregate Renegotiation
maximum number of aggregated SSL renegotiation records that the system can
receive before renegotiating an SSL session. After the system receives this
number of aggregated SSL renegotiation records, it closes the connection. This
setting applies to client profiles only. The default value is Indefinite.
setting
requires that the client support the TLS SNI extension; otherwise, the BIG-IP
system disconnects the client connection with a fatal alert. This setting is
disabled by default.
The
Unclean Shutdown
setting allows the BIG-IP system to
perform an unclean shutdown of SSL connections by closing the underlying TCP
connection without sending the SSL close notify alerts. By default, this setting
is enabled (selected) and is useful for certain browsers that handle SSL
shutdown alerts differently. For example, some versions of Internet Explorer
require SSL shutdown alerts from the server while other versions do not, and the
SSL profile cannot always detect this requirement. In the case where the browser
expects a shutdown alert but the SSL profile has not exchanged one (the default
setting), the browser displays an error message.
The
Strict Resume
setting
enables or disables the resumption of SSL sessions after an unclean
shutdown.
The BIG-IP SSL profiles support the stateless TLS session resumption mechanism
as described in Internet Engineering Task Force (RFC 5077) . This
mechanism allows the BIG-IP system to encapsulate the TLS session state as a
ticket to the client and allows the client to subsequently resume a TLS session
using the same ticket. Disabled (cleared) by default.
The
Session Ticket Timeout
setting specifies the timeout
for the session ticket. The default is 0 seconds, which means the system uses
the cache timeout.
The
Session Mirroring
setting enables or disables the
mirroring of SSL session ID data to a high-availability peer. The default
setting is Disabled, preventing the system from mirroring SSL session ID
data.
When enabled (default), the
Generic Alert
setting causes
the system to send all SSL alerts using a generic handshake failure message.
When the setting is disabled, the system sends more specific SSL alert
messages.
The
Non SSL Connections
acceptance of non-SSL connections.
The
Allow Dynamic Record Sizing
setting allows a TLS
performance improvement preventing buffering and delay of TLS record fragment
delivery. The BIG-IP system dynamically adjusts the size of TLS records based on
the state of the connection. The disabled by default.
The
Maximum Record Size
setting specifies the profile's
maximum record size. Set to enabled when you want to allow dynamic record
sizing. The range is 128 - 16384. The default setting is 16384.
The
SSL Sign Hash
setting specifies the hash algorithm
that the BIG-IP system uses to sign server key exchanges with the Diffie-Hellman
(DHE), including Elliptic Curve (ECDHE) ciphers, and for certificate verify
messages. Possible choices are SHA1, SHA256, SHA384, or Any. When you select
Any, you authorize the system to choose any one of the hash algorithms. The
BIG-IP system respects the client signature_algorithms extension as defined in
TLS 1.2. When possible, the BIG-IP system prefers SHA256 in the handshake
signature based on the content of the signature_algorithms extension. The BIG-IP
system further upgrades the hash algorithm to Hash SHA384 from SHA256 when P-384
is used. The BIG-IP system attempts to avoid the use of SHA1 in a TLS handshake,
except in the case when signatures are used in X.509 certificates (these
signatures are created by the X.509 Certificate Authority). The only time the
BIG-IP system uses the SHA1 handshake signature is when an RSA key is used and
the signature_algorithms extension is missing or - signature_algorithms is
present and only lists SHA1.
The
Peer No-renegotiate Timeout
number of seconds the system waits before resetting the connection to peer
systems that do not renegotiate SSL sessions. The default is 10.
The
Max Active Handshakes
setting limits the number of
concurrent SSL handshakes. When the number of active SSL handshakes reaches the
specified limit, the system terminates the most recent SSL handshake. The
default setting is Indefinite, which means that there is no limit.
For information about using the SSL Forward Proxy
feature, refer to the
Implementing SSL Forward Proxy
on a Single BIG-IP system
chapter of the SSL Administration
guide.
In the
Client Authentication
section, the
Client Certificate
setting enables and disables
client certificate authentication. The possible options for this setting
are:
Ignore
: The Ignore setting is the default
setting. It disables Client Certificate Authentication. The BIG-IP
system ignores any certificate presented and does not authenticate the
client before establishing the SSL session.
Request
: The Request setting enables optional
Client Certificate Authentication. The BIG-IP system requests a client
certificate and attempts to verify it. However, an SSL session is
established regardless of whether a trusted CA presents a valid client
certificate. The Request setting is often used in conjunction with
iRules to provide selective access depending on the certificate
presented. For example, this option is useful if you want to allow
clients who present a certificate from the configured trusted CA to gain
access to the application, while redirecting clients who do not provide
the required certificate to a page that details the access requirements.
However, if you are not using iRules to enforce a different outcome,
depending on the certificate details, there is no functional benefit to
using the Request setting instead of the default Ignore setting.
Require
: The Require setting enforces Client
certificate and attempts to verify it. The system establishes an SSL
session only if a trusted CA presents a valid client certificate. Use
the Require setting to restrict access to only clients that present a
valid certificate from a trusted CA.
The
Frequency
setting specifies the frequency of client
authentication for an SSL session. The default value for this setting is
once.
The
Retain Certificate
is enabled by default. When this
setting is disabled, the client certificate is not stored in an SSL
session.
The
Certificate Chain Traversal Depth
setting specifies
the maximum number of certificates to be traversed in a client certificate
chain. The default value is 9.
The
Trusted Certificate Authorities
setting specifies a
client CA that the system trusts. The default is
None
None
: Specifies that no CA is trusted for
client-side processing.
ca-bundle
: Uses the ca-bundle.crt file, which
contains all well-known public certificate authority (CA) certificates,
for client-side processing.
default
: Specifies that the trusted CA for
client-side processing is the default certificate on the system.
The
Advertised Certificate Authorities
setting specifies
that the CAs that the system advertises to clients is being trusted by the
profile. The default is None.
None
: Specifies that the system does not
advertise any chain as being trusted.
ca-bundle
default
: Specifies that the name of the
certificate on the system is the default certificate name, which the
system advertises as trusted.
The
CRL File
setting allows you to specify a CRL that
the BIG-IP system should use to check revocation status of a certificate prior
to authenticating a client. If you want to use a CRL, you must import it to the
BIG-IP system.
The
Allow Expired CRL File
setting instructs the system
to use the specified CRL file, even if it has expired. Disabled by
default.
client SSL profile name of the certificate file that is used as the client
certificate when the client does not send one during SSL handshake. You can
click the + icon to open the create-new OCSP object screen.
The
OCSP
setting specifies the SSL client certificate
constrained delegation OCSP object that the BIG-IP system's SSL should use to
connect to the OCSP responder and check the client certificate status. You can
click the + icon to open the create-new SSL Certifcate screen.
The
Unknown OCSP Response Control
action the system takes when the OCSP object returns an unknown status. The
default value is Drop, which causes the connection to be dropped. Selecting
Ignore causes the connection to ignore the unknown status and continue.
In the
Logging
section, the
Log
Publisher
setting specifies the defined Log Publisher for the
system to use for logging information.
Click
Finished
After performing this task, you can see the custom
Client SSL profile in the list of Client SSL profiles on the system.
To use this profile, you must assign it to a
virtual server. See
Assigning SSL profiles to a virtual
server
for detailed information.
Create a custom Server SSL profile
can perform decryption and encryption for server-side SSL traffic.
Local Traffic
Profiles
SSL
Server
The Server SSL profile list screen opens.
Click
Create
The New Server SSL Profile screen opens.
In the
Name
From the
Parent Profile
list, select
serverssl
From the
Configuration
list, select
Advanced
Select the
Custom
check box.
From the
Certificate
list, select the name of an SSL certificate on the BIG-IP system.
From the
Key
list, select the name of an SSL key on the BIG-IP system.
In the
Pass Phrase
field, type a
pass phrase that enables access to the certificate/key pair on the BIG-IP
system.
From the
Chain
list, select the name of an SSL chain on the BIG-IP system.
The
SSL Forward Proxy
that the system encrypts all traffic between a client and the BIG-IP system
using one certificate, and encrypts all traffic between the BIG-IP system and
the server using a different certificate. You must create both a Client SSL and
a Server SSL profile, and enable SSL Forward Proxy and SSL Forward Proxy Bypass
in both profiles.
The
specifies that SSL traffic that meets the criteria specified in the SSL Forward
Proxy Bypass settings of the assigned Client SSL profile of the virtual server
can bypass SSL forward proxy.
The
Bypass on Handshake Alert
setting enables or
disables SSL forward proxy bypass on receiving a
handshake_failure
protocol_version
, or
unsupported_extension
alert message
during the server-side SSL handshake. When this occurs, SSL traffic bypasses the
BIG-IP system untouched, without decryption/encryption. The default is
Disabled
The
Bypass on Client Cert Failure
setting enables or
disables SSL forward proxy bypass on failing to get client certificate that the
server asks for. When this occurs, SSL traffic bypasses the BIG-IP system
Disabled
The
Verified Handshake
that in SSL forward proxy mode, the system should always do a TLS handshake with
the server first before doing the client handshake. When Disabled, the system
performs the server handshake first only if it has not previously forged and
cached the server certificate; once the server certificate is ready, the system
always perform a handshake first with the client. The default value is
Disabled.
The
Ciphers
ECDHE_ECDSA
Ciphers
DEFAULT:ECDHE_ECDSA
Option
Description
Cipher Group
Ciphers
Cipher String
DEFAULT
cipher string.
HIGH
!ADH
and
:HIGH
Forward Privacy
ssldump
!EXPORT
:!SSLv3
Ciphers
setting,
which are industry standard SSL options and workarounds for handling SSL
All Options
Disabled
The
Options List
The
Data 0-RTT
can initiate a server connection for early data so to receive the benefits of
early data delivered to the server-side early. The default value is
Disabled.
When the
Proxy SSL
resources:
The
ModSSL Methods
iRule, using the
HTTP::header
iRules
section of the
Options
The
Cache Size
0
The
Cache Timeout
inclusive.
The
Alert Timeout
setting specifies the duration in time
for the system to try to close an SSL connection before resetting the
connection. The default is Indefinite.
Specify
: Specifies the number of seconds for the
system to wait before resetting the connection.
Indefinite
: Specifies that the connection does
not time out.
Immediate
: Specifies that the connection times
out immediately.
The
Handshake Timeout
Configure the
Renegotiation
Additional SSL
details.
The
The
Renegotiation Size
The
profile is
Require
Request
Require
renegotiation.
Require Strict
setting
The
Unclean Shutdown
The
Strict Resume
resumption of SSL sessions after an unclean shutdown.
The
Session Mirroring
data.
Generic Alert
setting causes
messages.
The
SSL Sign Hash
The
In the
Server Authentication
section, the
Server Certificate
specifies how the system handles server certificates. The possible options for this
setting are:
Ignore
setting. The BIG-IP system ignores certificates from the server and
never authenticate the server.
Require
: The Require setting enforces server
authentication. The BIG-IP system requires the server to present a valid
certificate before establishing the SSL session. A blank
Authenticate Name
setting indicates that all
servers are authenticated, even though you have specified
Require
as the
Server
Certificate
setting.
The
Expire Certificate Response Control
setting
specifies how the system handles SSL connections when the server certificate
expires. The default value for this setting is
drop
which causes the SSL connection to be dropped. Conversely, configuring this
setting to
ignore
causes the system to ignore the expired
server certificate and proceed with establishing the connection.
The
Untrusted Certificate Response Control
setting
specifies how the system handles SSL connections when the server certificate has
an untrusted CA. The default value for this setting is
drop
, which causes the SSL connection to be dropped.
Conversely, configuring this setting to
ignore
causes the
system to ignore the untrusted CA and proceed with establishing the
connection.
The
Revoke Certificate Status Response Control
setting
takes effect when the
Server Certificate
setting is set
to
require
. This setting specifies how the system handles
SSL connections from clients when the server certificate status is revoked. The
drop
. However in BIG-IP 16.1.0, the
default value is
ignore
if the server SSL profile is enabled with
ssl-forward-proxy; this is due to ID 911777. When the value is
drop
, the system
drops SSL connections from clients when the server certificate status is
revoked. When the value is
ignore
, the system ignores the revoked server
certificate status and allows the SSL connection by forging a unique server
certificate with revoked status to send to the client. When the value is
mask
, the system masks the server certificate status error and
continues the SSL handshake with the client. This setting is typically used in
SSL forward proxy configuration with certificate status service enabled such as
an SSL Orchestrator L3 Outbound deployment with a local OCSP responder. For more
information, refer to K65136200: Overview of the local OCSP
responder feature for F5 SSL Orchestrator.
The
Unknown Certificate Status Response Control
setting
Server Certificate
setting is set
to
require
SSL connections from clients when the server certificate status is unknown. The
ignore
. When the value
is
ignore
, the system ignores the unknown server
certificate with unknown status to send to the client. When the value is
mask
error and continues the SSL handshake with the client. When the value is
drop
, the system drops SSL connections from clients
when the server certificate status is unknown. This setting is typically used in
The
Frequency
setting specifies the frequency of server
Once
, which causes the system to authenticate the
server for an SSL session only once. When you configure this setting to
Always
, the system authenticates the server for an
SSL session and every subsequent reuse of the SSL session.
The
Retain Certificate
setting when enabled, specifies
that the server certificate is retained in SSL session. The default value is
true (selected).
The
setting specifies
the maximum number of certificates that the system traverses in a server
certificate chain. The default value is
9
The
Authenticate Name
setting specifies a Common Name (CN) that is iframed in a server certificate.
The system authenticates a server based on the specified CN. There is no default
value for this setting.
The
setting is
optional. The system uses this setting to specify the CAs that the BIG-IP system
trusts when verifying a server certificate. The default value for this setting
is
None
, which causes the system to accept a server
certificate signed by any CA. If you choose
Require
for
the
Server Certificate
setting, you must specify a CA
from the
setting. The
selected CA is trusted by the system when verifying a server certificate. The
ca-bundle
certificate may be appropriate for use as a
Trusted Certificate Authorities certificate bundle. However, if this bundle is
specified as the Trusted Certificate Authorities certificate store, any valid
server certificate that is signed by one of the popular root CAs included in the
default
ca-bundle.crt
is authenticated. This provides
some level of identification, but very little access control because almost any
valid server certificate could be authenticated.
If you want to trust only a server certificate that has been signed by a
private PKI or set of private PKIs, F5 recommends that you create and
install a custom certificate bundle that contains the private PKI
certificates, including the CA that directly signed your servers'
certificates. You can then choose the new certificate bundle in the
The
CRL
constrained delegation CRL object that the BIG-IP system's SSL should use. You
can click the + icon to open the create-new CRL object screen.
The
Certificate Revocation List (CRL)
or
CRL
File
setting allows you to specify a CRL that the BIG-IP system
should use to check revocation status of a certificate before the system
authenticates a server. If you want to use a CRL, you must import it to the
BIG-IP system. You can then choose the name of the CRL file using the
setting instructs the system to
use the specified CRL file, even if it has expired. Disabled by default.
The
Client Certificate Constrained Delegation
setting
enables or disables SSL Client certificate constrained delegation.
The
CA Certificate
setting specifies the name of the
certificate file that is used as the certification authority certificate. The
certificate should be generated and installed by you on the system.
The
CA Key
setting specifies the name of the key file
that is used as the certification authority key. The key should be generated and
The
CA Passphrase
setting specifies the passphrase of the key file
The
Confirm CA Passphrase
setting confirms the
CA
Passphrase
you specified.
The
Certificate Lifespan
setting specifies the lifespan
of the certificate generated using the SSL client certificate constrained
delegation. The default is
1
day,
0
hours.
The
Certificate Extensions
setting specifies the extensions of the client certificates to be included in
the generated certificates.
Basic Constraints
: Uses basic constraints to
indicate whether the certificate belongs to a CA.
Extended Key Usage
: Uses Extended Key Usage,
typically on a leaf certificate, to indicate the purpose of the public
key contained in the certificate.
Key Usage
: Provides a bitmap specifying the
cryptographic operations that may be performed using the public key
contained in the certificate. For example, it may indicate that the key
should be used for signature but not for encoding.
Subject Alternative Name
: Allows identities to
be bound to the subject of the certificate. These identities may be
included in addition to, or in place of, the identity in the subject of
the certificate.
The
Certificate Extensions List
setting provides the
list of enabled extensions and a list of available extension. When you disable
an extension in the
Enabled Extensions
list, it moves to
the
Available Extensions
list. When you enable an
extension in the
list, it moves to
the
Enabled Extensions
list. You can also specify a
Custom Extension
representing the OID of the client
certificates to be included in the generated certificates.
In the
Logging
section, the
Log
Publisher
Click
Finished
custom Server SSL profile in the list of Server SSL profiles on the system.
configuration.
virtual server. See the
server
section for detailed information.
Create a custom Client SSL profile that supports SM2
You create a custom Client SSL profile when you
want the BIG-IP® system to terminate client-side SSL traffic for the purpose of
F5 has
added SM2, SM3, and SM4 Cryptographic Algorithm support for the Chinese market. The
algorithms were independently developed by the China State Cryptography
Administration, where SM2 is the public key algorithm, SM3 is the hash algorithm,
and SM4 is the block cipher algorithm. SM2 is based on the Elliptic Curve Discrete
Logarithm Problem (ECDLP). Also see the following sections for details importing,
exporting, and managing a certificate and key with SM2 license.
Before you create a customer Client SSL profile that supports SM2, create an SM2
cipher rule and cipher group.
Create an SM2 Cipher Rule
Local Traffic
Ciphers
Rules
The Ciphers Rules screen opens.
Click
Create
The New Cipher Rule screen opens.
In the
Name
field, type a unique name for your SM2
cipher rule.
In the
Cipher Suites
field, type the following cipher
suites string:
ECC-SM4-SM3
In the
DH Groups
field, type the following DH groups
string:
SM2P256
In the
Signature Algorithms
signature algorithm string:
SM2-SM3
Click
Finished
. You are now ready to create a cipher
group.
Create an SM2 Cipher Group
Local Traffic
Ciphers
Groups
The Ciphers Groups screen opens.
Click
Create
The New Cipher Group screen opens.
In the
Name
cipher group.
In the
Group Details
area, select the check box next to
the SM2 cipher rule from the
Available Rules
list.
Select the arrows next to the
Allow the following
field
to move the selected SM2 cipher rule to this field.
Click
Finished
. You are now ready to create your custom
Client SSL profile that supports SM2.
Create a Custom Client SSL Profile that supports
SM2
Traffic
Profiles
SSL
Client
Click
Create
screen opens.
In the
Name
profile.
From the
Parent Profile
list, select
clientssl
Select the
Custom
check box.
From the
Configuration
list, select
Advanced
For the
Mode
setting, select the
Enabled
check box.
or the
setting, click
Add
For SM2 client profile, select
SM2
file type from the Certificate, Key, and Chain lists.
From the
Certificate
list,
select a certificate name. // This is the name of a certificate that you
you can specify the name of the existing certificate named default. //
Important: If the BIG-IP system is part of a DSC Sync-Failover group,
From the
Key
list, select the
previous step. // This is the name of a key that you installed on the
default. // Important: If the BIG-IP system is part of a DSC
From the
Chain
list, select
the chain that you want to include in the certificate key chain. // A
certificate Authorities (CAs). // Note: The default self-signed
For the
Passphrase
field,
stored on the BIG-IP system with password protection. // This setting is
Click
Add
For the
Ciphers
setting, specify a
Cipher Group
and
select the existing
SM2
For the
Options List
setting, select
the following as Enabled Options:
GMSSLv1.1
No SSL
No TLS
No DTLS
Click
Finished
Client SSL profile that supports SM2 in the list of Client SSL profiles on the
system.
Create a custom
Client SSL profile that supports C3D
client-side SSL traffic for the purpose of decrypting client-side ingress traffic and
encrypting client-side egress traffic. By terminating client-side SSL traffic, the
BIG-IP system offloads these decryption/encryption functions from the destination
server. When you perform this task, you can specify multiple certificate key chains, one
for each key type (RSA, DSA, and ECDSA). This allows the BIG-IP system to negotiate
secure client connections using different cipher suites based on the client's
preference.
Local Traffic
Profiles
SSL
Client
Click
Create
In the
Name
From the
Parent Profile
list, select
clientssl
Select the
Custom
check box.
From the
Configuration
list, select
Advanced
For the
Mode
setting, select the
Enabled
check
box.
For the
setting, click
Add
From the
Certificate
default
From the
Key
default
From the
Chain
For the
Passphrase
Click
Add
In the
setting, click
Add
specify.
OCSP Stapling
check
box.
Creating an
for detailed steps.
If you want to
Server
The
Ciphers
ECDHE_ECDSA
Ciphers
DEFAULT:ECDHE_ECDSA
Option
Description
Cipher Group
Ciphers
Cipher String
DEFAULT
cipher string.
HIGH
!ADH
and
:HIGH
Forward Privacy
ssldump
!EXPORT
:!SSLv3
Ciphers
check box for the
Client Certificate Constrained Delegation area.
for change.
See
About client
prior to enabling
C3D.
For the
Delegation
setting, select
Enabled
From the
OCSP
list, select the object
that the BIG-IP system's SSL should use to connect to the OCSP responder and
You can click the
OCSP object screen. See
Creating an OCSP stapling
profile
for detailed steps.
For the
list, specify the action the system takes when the OCSP object returns an
unknown status:
If you want the connection to be dropped,
retain the default value
Drop
If you want the connection to ignore the
unknown status and continue, Select
Ignore
Click
Finished
After performing this task, you can see the custom Client SSL profile in the list of
virtual server. See
server
Create a custom
Server SSL profile that supports C3D
With a Server SSL profile, the BIG-IP system can perform decryption and encryption for
For detailed information on how to complete the client
certificate constrained delegation (C3D) configuration and ensure that your custom
server SSL profile is set up properly, see
About client
before completing your custom profile
setup.
Local Traffic
Profiles
SSL
Server
Click
Create
In the
Name
From the
Parent Profile
list, select
serverssl
From the
Configuration
list, select
Advanced
Select the
Custom
check box.
From the
Certificate
From the
Key
In the
Pass Phrase
field, type a
system.
From the
Chain
The
Ciphers
ECDHE_ECDSA
Ciphers
DEFAULT:ECDHE_ECDSA
Option
Description
Cipher Group
Ciphers
Cipher String
DEFAULT
cipher string.
HIGH
!ADH
and
:HIGH
Forward Privacy
ssldump
!EXPORT
:!SSLv3
Ciphers
In the same area of the screen, configure any other settings as needed.
Select the
Custom
check box for the Server Authentication area of the screen.
for change.
Change or retain the values for all Server Authentication settings as needed.
If you intend to use OCSP stapling, then from the
OCSP
list, select the OCSP
object that the BIG-IP system's SSL should use to connect to the OCSP responder
and to check the server certificate status. You can click the + icon to open the
The OCSP stapling object can be added in
both forward and reverse proxy configurations. When the server
SSL Forward Proxy
property is
set to
Enabled
, the
forward proxy OCSP object is used to validate and staple the web server's
certificate status. When the server
SSL Forward Proxy
property is set to
Disabled
, the
reverse proxy OCSP object is used to reset the client connection if the web
server certificate has been revoked.
Select the
Custom
check box for the
Client Certificate Constrained Delegation section.
for change.
See
About client
prior to enabling
C3D.
From the
Delegation
setting, select
Advanced
From the
Delegation
list, select
Enabled
From the
CA Certificate
list, select
the name of the certificate file that is used as the certification authority
certificate.
From the
CA Key
of the key file that is used as the certification authority key.
In the
CA Passphrase
field, type the
passphrase of the key file that is used as the certification authority
key.
This
should be the passphrase corresponding to the specified
CA Key
For the
field,
type the identical passphrase.
For the
fields,
type the lifespan of the certificate generated that is using the SSL client
The default is
1
day,
0
hours.
To define the extensions of the client
certificates to be included in the generated certificates, from the
list,
select
Extensions
List
For the
setting, click
Disable
or
Enable
to add or
remove available extensions.
Basic
Constraints
: Uses basic constraints to indicate whether
Extended Key
Usage
: Uses Extended Key Usage, typically on a leaf
certificate, to indicate the purpose of the public key contained in the
certificate.
Key
Usage
: Provides a bitmap specifying the cryptographic
operations that may be performed using the public key contained in the
certificate; for example, it could indicate that the key should be used
for signature but not for enciphering.
Subject Alternative
Name
: Allows identities to be bound to the subject of
the certificate. These identities may be included in addition to, or in
place of, the identity in the subject field of the certificate.
You can also add extensions in the
Custom extension
field.
Type in the extension name and click
Add
Click
Finished
server
Create a custom Server SSL profile that supports CRL
A certificate revocation
list (CRL) is a published list of revoked certificates issued and updated by the
certificate authority who signed them. Clients like your internet browser, will
check the certificate's CRL URI to find out if the certificate is valid. When a
certificate is revoked, the CRL is updated to reflect the revokation and published
accordingly. Lists are not the most efficient way to maintain a record of revocation
in high volume scenarios so some application vendors have deprecated their use in
favor of online certificate status protcol (OCSP). However, you still need a CRL
configuraiton as it is still a common scenario and recommended for backward
compatibility.
Before you create a customer Server SSL profile that supports CRL, you
must create either a configured DNS resolver or a configured BIG-IP LTM
pool.
Create an internal proxy
Internal Proxy is used by services such
as CRL cert-validator, for defining how to send/receive the outbound traffic for
the service.
System
Services
Internal Proxies
The Internal Proxies screen
opens.
Click
Create
The New Internal Proxy screen
opens.
In the
Name
name for your internal proxy.
Select the
Use Proxy Server
check box if you want to use
the
Proxy Server Pool
instead of
DNS
Resolver
. The
Proxy Server Pool
is the
LTM pool with one or multiple proxies for forwarding the CRL request to the CRL
server. The
DNS Resolver
is the internal DNS resolver the
BIG-IP system uses to fetch the internal proxy response.
From the
DNS Resolver
list,
select the internal DNS resolver the BIG-IP system uses to fetch the
internal proxy response. This involves specifying one or more DNS
servers in the DNS resolver configuration. Use this option when:
There is a DNS server that can do the
name-resolution of the internal proxy.
The internal proxy can be reached on one of
BIG-IP system's interfaces.
If you are not selecting a pre-existing DNS
Resolver you can create one. Click
to define a new
internal DNS resolver and then return to this screen.
From the
Proxy Server Pool
list, select the LTM
pool for forwarding the CRL request to the CRL server.
From the
Route Domain
list, select the
route domain for fetching an internal proxy using HTTP explicit proxy. It is
common to have the Route Domain set to
0
. Click
to define a new route
domain.
You have now created an internal proxy
and are ready to create a CRL configuration object.
Create a CRL configuration
object
System
Certificate
Management
Traffic Certificate
Management
CRL
The CRL screen
opens.
Click
Create
The New CRL screen
opens.
In the
Name
field, type a name that
specifies the certificate revocation list.
Specify if you want to select
Strict Revocation Check
to
protect your configuration from accidental future changes. The Strict Revocation
Check specifies whether the strict revocation check for the certificate
revocation list is enable or disabled. If the check box is selected it enables
the strict revocation check and keymgmtd waits for the c fetching/caching to
complete. If it is disabled, keymgmtd immediately replies with certificate
status that is unknown and starts to download/cache the certificate revocation
list file.
For the
Internal Proxy
section, select
Internal Proxy List
to define the CRL
list that specifies the internal DNS resolver or a proxy server pool. Select
either New Internal Proxy or Internal Proxy List to specify the internal
proxy.
Click
Update
You are now ready to create your custom Server SSL profile that supports
CRL.
Create a Custom Server SSL Profile that
supports CRL
Local Traffic
Profiles
SSL
Server
screen opens.
Click
Create
screen opens.
In the
Name
From the
Parent Profile
list, select
serverssl
From the
Configuration
list, select
Advanced
Select the
Custom
check box.
for change.
From the
Certificate
list, select the
From the
Key
In the
Pass Phrase
field, type a
system.
From the
Chain
For the
Ciphers
setting, specify a
key chain in the
Certificate
Key Chain
ECDHE_ECDSA
in the
Ciphers
setting. (At a
DEFAULT:ECDHE_ECDSA
.) This is
Option
Description
Cipher Group
Select an
example of the
Ciphers
Cipher String
DEFAULT
cipher string.
security.
keyword
HIGH
!ADH
and
:HIGH
in your
cipher string.
Forward Privacy
, which creates
ssldump
!EXPORT
in the
cipher string.
:!SSLv3
in
Ciphers
setting
Select the
Custom
check box for the
for change.
From the
CRL
list, select the CRL
object that specifies the SSL client certificate constrained delegation CRL
object that the BIG-IP system's SSL should use. You can click the
screen.
From the
CRL File
list, select the name of a file containing a list of revoked server
certificates.
In the
field, select the check
box to instruct the system to use the specified CRL file even if it has expired.
The default is disabled.
Complete any other settings and click
Finished
task, you can see the custom Server SSL profile that supports CRL in the list of Server
Assign SSL profiles to a virtual server
The final task in the process of implementing SSL profiles is to assign the SSL profile to a virtual server. If the relevant virtual server does not yet exist, you can assign the SSL profile (or profiles) to the virtual server when you create it.
Local Traffic
Virtual Servers
The Virtual Server List
screen opens.
Click the name of a virtual server.
From the
Configuration
list, select
Advanced
For the
SSL Profile (Server)
setting,
from the
Available
list, select the name of the Server SSL profile you previously created and move
the name to the
Selected
list.
Click
Update
to save the
changes.
About BIG-IP cipher
support
The BIG-IP system includes a default cipher string named DEFAULT, which contains a subset of the cipher suites that the BIG-IP system supports.
The full set of cipher suites that the BIG-IP system supports are contained in the NATIVE cipher string. The cipher suites contained in both the DEFAULT and NATIVE cipher string are eligible for hardware acceleration.
The BIG-IP system supports a large set of cryptographic parameters that you can use to modify how the BIG-IP manages SSL/TLS connections.
For TLS 1.2 and TLS 1.3, you can configure all or some of the cryptographic
parameters:
Ciphersuites.
Key exchange algorithms, for example RSA, DH, or ECDHE.
Signature algorithms, for example RSA or ECDSA.
Encryption primitives, for example AES128 or CAMELLIA.
Hash algorithms, for example SHA256.
Message authentication codes, for example HMAC-SHA256 or
HMAC-SHA384.
Glossary of cipher-related terms
The BIG-IP system supports many cryptographic parameters used to negotiate SSL/TLS connections. The following list will help you understand how these parameters are organized on the BIG-IP
system.
Cipher Group
A BIG-IP configuration object that specifies a list of cipher rules. The BIG-IP system offers several pre-built cipher groups, such as
f5-default
f5-ecc
, and
f5-secure
. You can use a pre-built cipher group or create a new custom
cipher group. Cipher Groups can be associated with a Client or Server SSL profile's Cipher option to specify the allowed cryptographic parameters.
Cipher rule
A BIG-IP configuration object that specifies a list of cipher suites used to negotiate SSL/TLS connections. The BIG-IP system
offers several pre-built cipher rules, such as
f5-default
f5-ecc
, and
f5-secure
. You can use a pre-built cipher rule or create a custom
cipher rule. Cipher Rules are applied to Cipher Groups.
Cipher string
A BIG-IP named object that specifies a list of one or more cipher suites, for example DEFAULT or NATIVE. You can combine cipher strings to create the final cipher string that the BIG-IP system uses to negotiate SSL security parameters with another system. Cipher Strings can be associated with a Client or Server profile's Cipher option to specify the allowed cryptographic parameters.
Cipher Suites
A cipher suite is a combination of a key exchange method, authentication method, bulk encryption algorithm, and a message authentication code (MAC). The BIG-IP system uses cipher suites to negotiate the security parameters used to create SSL/TLS connections.
Rule Audit
The Rule Audit can be used when creating a custom Cipher Rule to display list of cipher suites contained in the cipher rule.
Group Audit
The Group Audit can be used when creating a custom Cipher Group, to display the list of cipher suites that will make up the final Cipher Group.
What is a cipher group?
A
cipher group
contains a list of cipher rules, and the instructions that the BIG-IP system needs for building the cipher string it will use for security negotiation. The instructions tell the system which cipher rules to include in the string, and how to apply them (allow, restrict, or exclude, and in what order).
Pre-built cipher groups
The BIG-IP system offers a few pre-built cipher groups that you can choose from to use as is
to build your final cipher string, However, it's common to create your own custom cipher group
instead.
Custom cipher
groups
This illustration shows an example of a custom cipher group.
Using this cipher group, the BIG-IP system builds the final cipher string using a user-created
custom cipher rule named
/Common/my_ecdhe_rsa
and the pre-built cipher rule
/Common/f5-default
Notice that the system will exclude from the string any cipher suites defined in the pre-built
cipher rule
/Common/f5-hw_keys
Also notice that the cipher group displays a preview of the final cipher
string after the instructions are applied.
To create a custom SM2 cipher group to use when
creating a custom client SSL profile that supports SM2, see the
section for task details. This section also provides
information on creating a custom SM2 cipher rule.
About pre-built cipher groups
The BIG-IP system offers a set of pre-built cipher groups, with names containing the
prefix
f5-
. Note that in general, a
cipher group
contains the cipher suites that you want to allow, restrict, or exclude when the system builds the cipher string used for SSL negotiation.
A
allows all cipher suites specified in a corresponding pre-built cipher rule to be included in the final cipher string that the BIG-IP system builds for SSL negotiation. A prebuilt cipher group does not restrict the allowed cipher suites in any way, nor does it exclude any cipher suites.
This table lists and describes the pre-built cipher groups on the system.
Descriptions of the pre-built cipher groups
Cipher group name
Description
f5-aes
Allows all cipher suites specified in the pre-built cipher rule
f5-aes
f5-default
f5-default
f5-ecc
f5-ecc
f5-hw_keys
f5-hw_keys
f5-secure
f5-secure
About custom cipher groups
This illustration shows an example of a custom cipher group. Using
/Common/f5-default
defined in the pre-built cipher rule
/Common/f5-hw_keys
cipher string after the instructions are applied.
Building a custom
Cipher Group
Before starting this task, make sure you've confirmed the need to create a custom
cipher string instead of using a pre-built cipher group.
You build a final, custom cipher string by creating a cipher
group. A
cipher group
contains the cipher rules
and instructions that the BIG-IP system needs for building the cipher string it will
use for security negotiation with a client or server system.
To create a custom SM2 cipher group to use when creating a custom client SSL
supports SM2
Local Traffic
Ciphers
Groups
The screen displays a list of
pre-built cipher groups.
Click
Create
In the
Name
field, type a name for
the cipher group.
Never include the prefix
f5-
in a cipher rule
name. This prefix is reserved for pre-built cipher groups
only.
If you created any custom rules, then in the
Cipher Creation area of the screen in the
Available Cipher Rules
list,
verify that the custom rules appear in the list.
For each cipher rule in the
list,
click the plus sign to view the cipher suites included in the rule.
For example,
this shows the cipher suites included in the pre-built cipher rule named
/Common/f5-ecc
In the
list,
select the boxes for the cipher rules you want to allow for negotiating security
We strongly recommend that you select the cipher rule
/Common/f5-default
, and for added security, select other
cipher rules, too.
Here's an
example of a list of available cipher rules that you might see within a
cipher group. Notice that we've selected both a pre-built cipher rule and a
custom cipher rule:
In the
Group Details
setting, move the selected cipher rules to the
Allow the following
box.
Here we see
that we're instructing the BIG-IP system to allow, during security
negotiation, the cipher suites contained in the selected cipher
rules:
Again from the
list,
select the boxes for the cipher rules you want to restrict the allowed cipher
rules to when negotiating security for SSL connections.
Move the selected cipher rules to the
Restrict the Allowed list to the
following
box.
If you want to exclude any cipher rules from the
allowed list, then from the
list, select the boxes for the rules you
want to exclude.
Exclude the following from the Allowed
list
box.
From the
Order
list, select the order
that you want the BIG-IP system to use when negotiating SSL connections.
The choices are:
Default
Speed
Strength
FIPS
, and
Hardware
In the
Cryptographic Parameters
box, view the
cipher suites that the BIG-IP system will use to construct the final cipher string, based on the selections you
made in the previous steps.
Click
Finished
After you complete this task, the BIG-IP system has a custom cipher group that the
BIG-IP system will use to build the final cipher string.
What is a cipher rule?
A
cipher rule
is an object that contains
a list of cipher suites. After you create a cipher rule, you specify
it within a cipher group. A
cipher
group
is the object that builds the actual cipher string that the system will use during
SSL negotiation.
You can use pre-defined cipher rules that the BIG-IP system provides, or you
can create your own.
An example of a cipher rule might be one that specifies only cipher suites
that use a particular bulk encryption algorithm and key exchange method.
DH Groups and Signature Algorithms allow modification of TLS
1.2 and 1.3 key agreements and signature algorithms respectively.
To create a custom SM2 cipher rule to use when creating a custom client SSL profile that
About pre-built cipher rules
Pre-built cipher rules
The BIG-IP system offers a set of pre-built cipher rules, with names containing the
prefix
f5-
. This table lists these cipher rules and the cipher
strings they represent.
You can use the following cryptographic parameters to create custom cipher rules:
Cipher suites
These represent the bulk encryption and hash algorithms used to negotiate SSL/TLS connections. An example of a cipher suite is
ECDHE-RSA-AES128-CBC-SHA
DH groups
In TLS 1.2 and 1.3, these are the Elliptic Curve Diffie Hellman (ECDH) key
agreement algorithms used to negotiate SSL/TLS connections. The available
key agreement curves
are:
P256
P384
, and
X25519
In TLS 1.2 and 1.3, these are the digital signature algorithms for
authentication. Examples of signature algorithms are
rsa_pkcs1_sha256
and
ecdsa_secp256r1_sha256
Create a custom cipher rule
When you create your
own cipher rules for inclusion in a custom cipher group, the BIG-IP system builds a
cipher string that includes or excludes the cipher suites and algorithms needed for
section for task
details.
Local Traffic
Ciphers
Rules
pre-built cipher rules.
Click
Create
In the
Name
the cipher rule.
f5-
in a cipher rule
name. This prefix is reserved for pre-built cipher rules only.
For
example:
In the
Cipher Suites
field, type one
or more cipher suites.
For
example:
In the
DH Groups
field, type one or
more Elliptic Curve Diffie-Hellman key exchange algorithms, separated by commas
(:). The available named groups (formerly known as
curves
) are:
secp256r1
secp384r1
, and
X25519
You can also type a special keyword,
DEFAULT
, which
represents the recommended set of named groups.
For example, you can specify
secp256r1:X25519
In the
field,
type one or more signature algorithms, separated by commas (:), that you want to
include in the cipher rule. You can also type a special keyword,
DEFAULT
, which represents the
recommended set of signature algorithms.
The available signature algorithms are:
DSA-SHA1
DSA-SHA256
DSA-SHA384
DSA-SHA512
ECDSA-SHA1
ECDSA-SHA256
ECDSA-SHA384
ECDSA-SHA512
RSA-PKCS1-SHA1
RSA-PKCS1-SHA256
RSA-PKCS1-SHA384
RCS-PKCS1-SHA512
RSA-PSS-SHA256
RSA-PSS-SHA384
, and
RSA-PSS-SHA512
RSA_PKCS1_SHA256:ECDSA_P256_SHA256
Click
Finished
The cipher rule now appears within any custom
cipher group, in the list of available cipher rules.
About the DEFAULT and NATIVE cipher strings
The
DEFAULT
cipher string appears as the default value in the
Ciphers
setting of the Client SSL and Server SSL profiles and represents a subset of the cipher suites found in the
NATIVE
cipher suite.
The
NATIVE
cipher string represents the full set of BIG-IP supported cipher suites.
Both the
DEFAULT
and
NATIVE
cipher strings represent cipher suites that are eligible for hardware acceleration.
We strongly recommend that you use the default cipher string and, for added security, append
other cipher suites to it.
Viewing cipher
suites in the DEFAULT and NATIVE cipher strings
Before you use this command, confirm that your BIG-IP user account grants you access to
the advanced shell.
Follow these steps to display the cipher suites associated with
the DEFAULT cipher string. This list of cipher suites is also included in the
f5-default
Using an SSH client application such as PuTTY,
access the advanced shell on the BIG-IP system.
At the system prompt, to view the DEFAULT cipher
suites used for client-side negotiation, type the command
tmm --clientciphers
DEFAULT
suites used for server-side negotiation, type the command
tmm --serverciphers
DEFAULT
Best practices for BIG-IP cipher
strings
For security and performance reasons, consider the following recommendations:
When modifying cipher suites, F5 strongly recommends that you append cipher suite modifications to the
DEFAULT
cipher string.
Include a cipher
string that specifies the ECC key type. Due to their smaller size, ECC keys reduce computing costs while maintaining a similar level of security.
Disable ADH
HIGH
. To
!ADH
and
:HIGH
For AES, DES, and
method. DHE uses
perfect forward secracy
, which creates an ephemeral private key for each new secure connection. This ensures the same private key is never used twice.
prevention system. And by the way, diagnostic tools like
ssldump
Secrecy.
About Diffie-Hellman
Ephemeral key exchange
The BIG-IP system supports the
Diffie-Hellman Ephemeral key exchange method, as well as other Diffie-Hellman variations. A
Diffie–Hellman key exchange method
is an alternative to RSA key
exchange and allows the client and the BIG-IP system to establish a shared secret session key to
use for communication.
About DHE key
exchange
Because Diffie-Hellman key exchange methods do not include
authentication, use of Diffie-Hellman Ephemeral (DHE) requires that it be paired with an
authentication mechanism. The DHE key exchange/authentication pairs that the BIG-IP system
supports are:
DHE key
exchange methods, when paired with RSA and DSS authentication, are not included in the
cipher rule
f5-default
nor in the
cipher keyword
DEFAULT
About Perfect-Forward-Privacy
The Diffie-Hellman Ephemeral (DHE) key exchange method provides Perfect Forward Privacy (PFP).
With standard Diffie-Hellman, multiple key exchanges all use the same session key, which can
compromise security. By contrast, DHE uses
PFP
, which generates a disposable key per
session and thereby ensures that the same session key is never used twice. No key remains to be
disclosed, and if the private key of the server is discovered, past communication remains
secure.
Supported Diffie-Hellman variations
The BIG-IP system supports all three Diffie-Hellman key exchange methods. They are:
Diffie-Hellman Ephemeral uses temporary public keys. The authenticity of a temporary key can
be verified by checking the digital signature included in the key exchange messages. The key
exchange messages are signed using either the RSA or DSA algorithms, depending on the cipher
being used. For example, DHE-RSA uses RSA to sign the key exchange messages. DHE includes
Perfect Forward Secrecy (PFS), which means that a compromise of the system's long-term signing
key does not affect the privacy of past sessions. Like FIPS, DHE prevents private key
disclosure.
Diffie-Hellman (DH)
Diffie-Hellman embeds the system's public parameter in the certificate, and the CA then
signs the certificate. That is, the certificate contains the Diffie-Hellman public-key
parameters, and those parameters never change.
Anonymous Diffie-Hellman (ADH)
Anonymous Diffie-Hellman uses DH, but without authentication. The keys used in the exchange
are not authenticated, resulting in keys being susceptible to security attacks.
Viewing a list of supported DHE ciphers
Before using this command, confirm that your user account grants you access to the advanced shell.
You perform this task when you want to display a specific set of ciphers that the BIG-IP system supports.
Access the advanced shell on the BIG-IP system.
At the system prompt, type the command
tmm --clientciphers
ciphers
For example, to see a list of DHE+DES ciphers, type
tmm --clientciphers DHE:DHE_DSS
. To see a list of ECDHE ciphers, type
tmm --clientciphers ECDHE:ECDHE_ECDSA
Specifying a Diffie-Hellman key exchange method
Use this task to modify an existing Client SSL profile to enable support for
Diffie-Hellman key exchange.
On the Main tab, click
Local Traffic
Profiles
SSL
Client
or
Local Traffic
Profiles
SSL
Server
The Client SSL or Server SSL profile list screen opens.
In the Name column, click the name of the profile you want to modify.
Select the
Custom
check box.
The settings become available for change.
To specify DHE ciphers:
From the
Configuration
list, select
Advanced
For the
Ciphers
setting, click
Cipher String
and type
DHE:DHE_DSS
Click
Update
After you perform this task and assign the profile to a virtual server, the BIG-IP uses the DHE key exchange method to establish secure communication with the relevant client or server.
Viewing DHE key exchange statistics
You can use the Traffic Management Shell (tmsh)
to view statistics about the use of Diffie-Hellman ciphers in SSL negotiation.
Access the system prompt on the BIG-IP
system.
From the BIG-IP system prompt, type
tmsh show ltm profile client-ssl
profile_name
An example of a name for a profile
that specifies DHE ciphers is
my_dhe_profile
After you type this command, the BIG-IP system
displays output such as the following. In this example, the profile statistics show that
Diffie-Hellman Ephemeral (DHE) with RSA certificates has been used once:
Sample profile statistics for key exchange
method
About Elliptic Curve
encryption
The BIG-IP system supports Elliptic Curve Cryptography (ECC). Because
Elliptic Curve key sizes are significantly smaller than those of other key types, ECC is ideally
suited for smaller, mobile devices for which key storage is an issue. On the BIG-IP system, ECC
works with the SSL offload feature.
cipher support
The BIG-IP system supports multiple ciphers that use Elliptic Curve
Cryptography (ECC) encryption with Diffie-Hellman key exchange. On the BIG-IP system, EC is used
with DHE to establish the shared secret; however, the subsequent bulk encryption of data cannot
be done with any ECC-based algorithm and must be done using conventional crypto algorithms such
as AES and 3DES. For example, a typical Elliptic Curve cipher is: ECDHE-RSA-AES128-CBC-SHA.
The specific ECC ciphers that the BIG-IP system supports are:
ECDHE-RSA-*
ECDHE-ECDSA-*
ECDH-ECDSA-*
Because ECC with Diffie-Hellman does not include a mechanism for digitally
signing handshake messages, the RSA or DSA algorithms are used to digitally sign the handshake
messages to thwart Man-in-the-Middle attacks. For example, an ECDHE-ECDSA-* cipher suite uses the
ECC DSA certificate specified in the Client SSL profile to digitally sign the handshake
messages.
Elliptic
Curve ciphers with DSA are not included in the
DEFAULT
cipher suite.
Viewing ECDH key exchange statistics
to view statistics about the use of Elliptic Curve Diffie-Hellman ciphers in SSL
negotiation.
system.
profile_name
| grep ECDH.
my_ecdh_profile
ECDH with RSA certificates has been used six times:
method
Specifying an Elliptic Curve Diffie-Hellman key exchange method
Use this task to modify an existing Client SSL profile to enable support for Elliptic Curve Diffie-Hellman Ephemeral (ECDHE) key exchange.
Local Traffic
Profiles
SSL
Client
or
Local Traffic
Profiles
SSL
Server
Select the
Custom
check box.
For the
Ciphers
setting, click
Cipher String
and type
DEFAULT:ECDHE
Click
Update
After you perform this task and assign the profile to a virtual server, the BIG-IP system uses the ECDHE key exchange method to establish secure communication with the relevant client or server.
Unsupported cipher suites on the BIG-IP system
For security reasons, these cipher suites are unavailable in the BIG-IP system:
EXP-EDH-RSA-DES-CBC-SHA
EXP-ADH-DES-CBC-SHA
EXP-RC2-CBC-MD5
EXP-ADH-RC4-MD5
About cipher keywords on the BIG-IP system
There are a few things you should know when specifying keywords to create a BIG-IP cipher string. These things apply whether or not you are creating a cipher string using cipher rules and groups or typing a raw cipher string into an SSL profile.
About the COMPAT cipher string
In previous BIG-IP releases, cipher support included the
COMPAT
cipher string, allowing the use of OpenSSL cipher suites not natively
supported by the BIG-IP. In this release, the
COMPAT
cipher string has been removed.
If your configuration includes the
COMPAT
cipher string, it will be replaced with
NONE
and secure connections relying on these cipher suites will fail.
This change:
Optimizes the security of your cipher configuration by preventing any OpenSSL cipher suite
vulnerabilities from being introduced into the BIG-IP system.
Changes the meaning of the
NATIVE
keyword;
this keyword now equivalent
to the keyword
ALL
Invalid keywords for BIG-IP cipher strings
When you manually configure a cipher string on the BIG-IP system (as
opposed to using a cipher group), these keywords are invalid:
COMPAT
SSLV2
(a
subset of
COMPAT
RC2
(a subset
of
COMPAT
Any other
subsets of
COMPAT
or
SSLv2
If you attempt to specify these keywords within a cipher string,
the system displays an error message and prevents you from creating the relevant SSL
profile.
If you have an SSL profile in a previous BIG-IP version and
then upgrade to version 14.0 or higher, the system automatically resolves the issue
for you.
Changes to BIG-IP cipher keywords during a system upgrade
During a BIG-IP software upgrade to version 14.0 or higher, the
system takes these actions:
If the system
detects the keywords
COMPAT
SSLv2
RC2
, or any subset of these in an existing cipher string, the
system logs a message in the file
/var/log/ltm
and changes any of these keywords to
None
The system
treats the keyword
NATIVE
as being equivalent to keyword
ALL
If a cipher
string evaluates to an empty set, the system remaps the string to the default
cipher string, represented by the keyword
DEFAULT
. The default cipher
string contains a subset of the cipher suites that are suitable for most SSL
connections.
About OCSP stapling
When you create a Client SSL profile, you can specify Online Certificate Status Protocol (OCSP)
stapling to improve the certification response time.
OCSP stapling
is when a TLS
server (acting as OCSP client) asks the OCSP server for a valid revocation status of its TLS
certificate ahead of time and "staples" the signed OCSP response to the TLS handshake. The TLS
client sees the stapled OCSP response and verifies the signature, thus validating the TLS
server’s certificate and eliminating the round trip at the client for fetching the certificate
status. It also helps protect the identity of the client.
By default, OCSP stapling is disabled. You can can create an OCSP stapling profile and then
enable it from within a Client SSL profile. There is no default OCSP Stapling profile, so you
must create one that specifies the parameters you want to use. For example, the default OCSP
stapling profile setting is to use a DNS resolver to fetch the OCSP response, and you must
specify the DNS resolver to use. Alternatively, you can choose to use a proxy server to fetch the
OCSP response, and then you must specify the proxy server pool.
Creating an OCSP stapling profile
Before you start this task, be sure
that you have configured a proxy server pool or a DNS resolver.
When you create an OCSP stapling profile and assign it to a client SSL profile, you
speed up the time it takes for the client to get the certificate revocation status of
the BIG-IP system.
System
Certificate Management
Traffic Certificate Management
OCSP
Click
Create
The new OCSP Stapling Profile screen opens.
In the
Name
field, type a unique name for the OCSP stapling profile.
For the
Use Proxy Server
setting, specify how to fetch
the OCSP response:
If you want the BIG-IP system to use the
Proxy Server
Pool
, select the check box. Use this when there are one
or more servers that can act as a proxy an HTTP request to an external
server and fetch the response.
If you want to use the
DNS Resolver
, clear the
check box. Use this when the OCSP responder can be reached on one of the
BIG-IP system interfaces.
In the
Proxy Server Pool or DNS Resolver
field, select
the proxy server pool or DNS resolver used for fetching the OCSP response.
In the
Route Domain
field, select the route domain for
fetching an OCSP response using HTTP forward proxy.
In the
Concurrent Connections Limit
field, type the
maximum number of connections per second allowed for the OCSP certificate
validator.
50
connections.
In the
Responder URL
field, type the name of a URL that
will override the OCSP responder URL obtained from the certificate's AIA
extension.
This must be an HTTP or HTTPS-based URL.
In the
Timeout
field, type a time interval for the BIG-IP system to wait before dropping the connection to the OCSP responder.
From the
Trusted Responders
certificate to use to verify the response from the OCSP responder.
In the
Clock Skew
field, type a value for the maximum tolerable absolute difference between the clocks of the responder and the BIG-IP system.
In the
Status Age
allowed lag time in the OCSP response that the BIG-IP system accepts.
If you type
0
, the validation is skipped. The default
value is
86400
To have the system check the responder's certificate for the OCSP signing
extension for the
Options
setting, select the
Strict Responder Certificate Checking
check
box.
From the
Timeout
list, select a value that specifies the
lifetime of the OCSP response.
The default is
Indefinite
, indicating that the response
validity period takes precedence.
In the
Error Timeout
field, type a value for how long a
BIG-IP system will cache an error response.
3600
seconds.
The
Error
Timeout
must be greater than Connection
Timeout
From the
Certificate
list, select a certificate
corresponding to the key used for signing the OCSP request.
From the
Key
list, select a key to use to sign an OCSP
request.
In the
Passphrase
field, type the passphrase of the key
used to sign an OCSP request.
From the
Hash Algorithm
list, select the hash algorithm
The default is
SHA256
This is not the algorithm
used in the certificate itself. It is what the OCSP responder will use when
validating the request.
Click
Finished
After you create an OCSP profile, make sure you enable the
OCSP Stapling
setting from within the relevant Client SSL profile.
View OCSP stapling statistics
You can use the OCSP stapling
statistics to view output such as the number of successful cache requests, the number of
Good, Revoked, and Unknown certificate status statistics, and the number of internal,
connection, and response errors based on the OCSP definitions in the
configuration.
System
OCSP
Statistics
The System OCSP statistics screen opens.
From the
Statistics Type
list, verify that
OCSP
is selected.
From the
Data Format
list, select how the system
presents the statistics information.
Option
Description
Normalized
(default)
Rounds values to the nearest whole number.
Unformatted
Presents the actual value, including all decimal places.
From the
Auto Refresh
list, select a time interval to
automatically update the statistics display screen information.
The default is
Disabled
When you specify an automatic-refresh interval, the system presents a
Stop
button for halting the operation, and counts
down the seconds to the next update.
Short automatic-refresh
intervals may negatively affect system performance.
The BIG-IP system displays output
such as the number of successful cache requests, the number of Good, Revoked, and
Unknown certificate status statistics, and the number of internal, connection, and
response errors based on the OCSP definitions in the configuration. Click
Reset
to clear the OCSP statistics display screen information.
