Manual Chapter : Setting up logs for Access profile
Use the following procedure to set up your SSL Orchestrator logs settings with specific severity levels.
  1. On the Main tab, click SSL Orchestrator > Logs > Settings. The Logs Settings screen opens.
  2. For each facility, you can select from the following log setting severities:
    • Emergency: Specifies the emergency system panic messages.
    • Alert: Serious errors that require administrator intervention.
    • Critical: Critical errors, including hardware and filesystem failures.
    • Error: Non-critical, but possibly very important, error messages.
    • Warning: Warning messages that should at least be logged for review.
    • Notice: Messages that contain useful information but may be ignored.
    • Information: Messages that contain useful information but may be ignored.
    • Debug: Messages that are only necessary for troubleshooting. Generally, higher levels contain all the messages for lower levels. For example, the Alert level will generally also report all messages from the Emergency level, and the Debug level will generally also report all messages for all levels.
  3. Click Save Draft or Save & Next before you leave the screen.
