Manual Chapter : Creating a Virtual Server using Connector Profile
Applies To:
F5 SSL Orchestrator
  • 21.0.0
Ensure that you created a service in SSL Orchestrator.
A connector profile is generated when you create a service in SSL Orchestrator. You can use that connector profile to create a virtual server. The following steps illustrate how to create a virtual server using a connector profile in SSL Orchestrator Limited Mode.
  1. On the Main tab, click Local Traffic > Virtual Server > Virtual Server List.
    The Virtual Server List opens.
  2. Click Create.
    The New Virtual Server screen opens.
  3. Enter the required details in the General Properties section.
  4. In the Configuration drop-down list, select Advanced.
  5. In the Connector Profiledrop-down list, select the connector profile related to the service that you created in SSL Orchestrator.
  6. Click Finish.
The Virtual Server is created and added to the Virtual Servers list.
Parent topic: Using SSL Orchestrator in Limited Mode
