Manual Chapter : Setting up logs for LTM policy
Applies To:
F5 SSL Orchestrator
  • 21.0.0
For L3 Inbound/Application topology, you can enable logging for LTM policy. Use the following procedure to set up your SSL Orchestrator logs settings for LTM policy.
  1. On the Main tab, click SSL Orchestrator > Logs > Settings. The Logs Settings screen opens.
  2. Select whether to Enable Logging for LTM policy.
  3. From the Log Publisher drop-down list, select a log publisher to specify where the system sends alert messages.
  4. Click Save Draft or Save & Next before you leave the screen.
On deployment, the policies are auto-generated with naming convention “ssloP_XXXX_log_ltm_pol” and “ssloP_XXXX_logssl_ltm_pol” and maintained in the Local Traffic > Policies > Policy List.
Parent topic: Logs settings
