Updated Date: 09/02/2026
Create a virtual server for web traffic over QUIC
You can create a virtual server on the BIG-IP system to manage web traffic that uses the transport-layer protocol QUIC instead of TCP. Once deployed, this virtual server causes the system to: listen for secure client web traffic sent over QUIC and UDP, decrypt the traffic, and forward the decrypted traffic to an application server pool over TCP.
- On the Main tab, click Local Traffic > Virtual Servers. This displays a list of virtual servers on the system.
- Click Create.
- Type a name for the virtual server, such as
my_vs_quic. - From the Type list, select Standard.
- In the Source Address box, confirm that Host is selected, and type the address 0.0.0.0.
- In the Destination Address/Mask box, confirm that Host is selected, and type an IP address in CIDR format.
The netmask you specify must be
/32(that is,255.255.255.255). - From the Service Port list, select HTTPS.
- From the State list, confirm that Enabled is selected.
- From the Configuration list, select Advanced.
- From the Protocol list, select UDP.
- From the Protocol Profile (Client) list, confirm that udp is selected.
- From the Protocol Profile (Server) list, select an existing TCP profile. Note: F5 recommends that you select the default profile f5-tcp-lan.
- For the HTTP Profile (Client) setting, confirm that the default profile http is selected.
- For the HTTP Profile (Server) setting, confirm that (Use Client Profile) is selected.
- For the SSL Profile (Client) setting, select clientssl-quic.
- From the Source Address Translation list, select Auto Map.
- For the Address Translation setting, confirm that the Enabled check box is selected.
- For the Port Translation setting, confirm that the Enabled check box is selected.
- In the Acceleration area of the screen, for the HTTP MRF Router setting, select the check box.
- For the QUIC Profile setting, select the QUIC profile that you previously created.
- From the HTTP3 Profile list, select the HTTP3 profile you previously created.
- From the Default Pool list, select the name of the web server pool you created earlier.
- Click Finished.
