Updated Date: 09/02/2026
Create a pool of web servers
Use this procedure to create a pool of servers for serving web application traffic.
- On the Main tab, click Local Traffic > Pools. The Pool List screen opens.
- Click Create. The New Pool screen opens.
- In the Name field, type a unique name for the pool.
- Using the New Members setting, add each resource that you want to include in the pool:
- Select Node List.
- For the Address option, select the IP address of the web application server.
- For the Service Port option, select HTTPS from the list.
- Click Add. The added pool member appears in the displayed table.
- Repeat the process until all pool members are added.
- Click Finished. The new pool appears in the Pools list.
