Manual Chapter : Device Discovery and Basic Device Management
Applies To:
  • BIG-IQ Centralized Management
    6.1.0
To start managing a BIG-IP device, you must add it to the BIG-IP Devices inventory list on BIG-IQ Centralized Management, and discover and import their licensed services.
Note: If you only want to do basic management tasks (like software upgrades, license management, and UCS backups) for a BIG-IP device, you do not have to discover and import service configurations.
There are a few ways you can add BIG-IP devices to your BIG-IQ system so you can start managing them.
  • Add a single BIG-IP device, and discover and import its services in a separate procedure.
  • Add one or more BIG-IP devices and discover and import their services at the same time.
  • Import BIG-IP devices in bulk, using a CSV file.
Adding devices to the BIG-IQ Centralized Management system and discovering and importing their services is the first step to managing them.
After you add devices, you discover and import their services. It’s important to know a few things about services shared between BIG-IQ and BIG-IP devices. When BIG-IQ manages BIG-IP devices, it stores a copy of their service configuration objects. The BIG-IQ system uses the following terms to describe configurations between BIG-IQ and BIG-IP devices:
  • The working configuration is the configuration that is maintained and edited on the BIG-IQ system. This is the configuration you deploy to the BIG-IP device during a deployment.
  • The current configuration is the configuration discovered on the BIG-IP device. This is also sometimes referred to as the running configuration. The current configuration is updated during re-import or re-discovery and before calculating differences during the deployment process. The current configuration is also updated after a successful deployment to the BIG-IP device.
  • A difference is when an object with the same type and name occurs in both the current configuration and the working configuration but with different data. For example, a difference would occur if the policy object Pol021 in the current configuration (imported from the BIG-IP device) contains more properties than that policy object in the working configuration (on the BIG-IQ Centralized Management system).
To address these conflicts automatically in the same way, you can have BIG-IQ use one of the following conflict resolution policies if it finds a conflict.
  • Shared - All objects shared across BIG-IP devices, except LTM profiles and monitors.
  • Version-specific - Only LTM profile and monitor objects that are specific to a BIG-IP software version.
  • Device-specific - Objects that are specific to a particular to a BIG-IP device and not shared among multiple BIG-IP devices.
Use BIG-IQ
Keep the object in BIG-IQ system’s working configuration. The next time BIG-IQ deploys a configuration to that BIG-IP device, it updates the object to match the one on BIG-IQ.
Use BIG-IP
Use the object from the BIG-IP device’s configuration to replace the object in the BIG-IQ system’s working configuration that is different. If you select this option, BIG-IQ replaces that object for all of your managed BIG-IP devices the next time it deploys a configuration.
Create Version
BIG-IQ creates and stores a copy of the BIG-IP device’s LTM monitor or profile object (s), specific to the software version running on that BIG-IP device. If you select this option, BIG-IQ replaces that object for all the managed BIG-IP devices running that version, the next time it deploys a configuration. You can store multiple versions of LTM monitors or profiles. BIG-IQ deploys the appropriate stored version to your managed devices. BIG-IQ automatically resolves conflicts against the appropriate version the next time it imports services that contain LTM monitors or profiles.
Alternatively, you can have BIG-IQ stop importing any service that contains conflicts, and attempt to discover and import the next service. If you use this option, you can rediscover and reimport the services that failed from the BIG-IP device’s Service page, and resolve each conflict individually.
Note: If you want to view shared objects, from the command line, type the following command: GET "/mgmt/cm/shared/metadata?\$filter='category'+eq+'working-config'+and+'configData/configType'+eq+'shared'&\$select=itemKind,uriPath"
Before you can add BIG-IP devices to BIG-IQ Centralized Management:
  • The BIG-IP device must be located in your network and running a compatible software version. Refer to https://support.f5.com/csp/article/K14592 for more information.
  • The management address of the BIG-IP device must be open (typically this is port 22 and 443), or any alternative IP address used to add the BIG-IP device to the BIG-IQ inventory. Ports 22 and 443 and the management IP address are open by default on BIG-IQ.
  • Note: A BIG-IP device running versions 10.2.0 - 12.0.0 is considered a legacy device, and cannot be added to the BIG-IQ system’s inventory for management. If you were managing a legacy device in a previous version of BIG-IQ and upgrade, the legacy device displays as impaired with a yellow triangle next to it in the BIG-IP Devices inventory. To manage it, you must upgrade it to version 12.1.0 or later. For instructions, refer to the section titled, Upgrading a Legacy Device.
You add a BIG-IP device to BIG-IQ so you can discover and import its services, such as LTM, AFM, and so forth. After you discover and import a device’s services, you can start managing it. This procedure allows you to add a single BIG-IP device.
Note: If you would prefer to add several BIG-IP devices at once and handle all object conflicts the same way, select the Add multiple BIG-IP devices option.
  1. At the top of the screen, click Devices.
  2. On the left, click BIG-IP DEVICES.
  3. Click the Add Device(s) button.
  4. For the Device setting, select Add a single BIG-IP device.
  5. In the IP Address field, type the IPv4 or IPv6 address of the device.
  6. In the Port field, type the management port for this BIG-IP device.
    The port number must be between 4 and 65535. In many cases, it’s the default port 443.
    Note: Chrome and Safari browsers don’t allow access to web applications running on port 65535. So if you use port 65535 as the management port, you won’t be able to access the BIG-IP device’s interface from BIG-IQ when using Chrome or Safari. You can still discover and manage BIG-IP devices that are using port 65535.
  7. If this device is part of a Device Service Cluster (DSC) group, for the Cluster Display Name setting, specify how to handle it:
    • For an existing DSC group, select Use Existing from the list, and then select the name of the DSC group from the next list.
    • To create a new DSC group, select Create New from the list, and type a name in the field. For BIG-IQ to properly associate the devices in the same DSC group, the Cluster Display Name must be the same for all members in a group.
    There can be up to 8 members in a DSC group.
    Important: For BIG-IP devices with ASM services, you can only add five devices at a time. If the BIG-IP device(s) provisioned with ASM is part of a DSC cluster, that device must also be a member of a sync-only device group, and ASM synchronization must be enabled on one of the devices in the DSC group. Without these DSC group settings, deploying changes to the ASM device can cause the cluster to become out of sync. For details on configuring these groups, refer to https://support.f5.com/csp/article/K12200102 or the ASM implementations chapter Automatically Synchronizing Application Security Configurations on support.f5.com.
  8. If this device is configured in a Device Service Clustering (DSC) group, for the Deployment Settings, specify how to handle it:
    Note: For more information about DSC groups, see What is a BIG-IP Device Service Clustering (DSC) group and how do I start managing it from BIG-IQ?.
    • Initiate BIG-IP DSC sync when deploying configuration changes (Recommended): Select this option if this device is part of a DSC group and you want BIG-IQ to automatically synchronize configuration changes with other members in the DSC group from BIG-IQ.
      • Allow deployment when DSC configured devices have changes pending (Not Recommended) this option pushes changes to all the devices in the cluster independently, ignoring the logical device cluster configuration. This option is intended for temporary use when a BIG-IP cluster node becomes unavailable, you would like to push changes to individual devices, until the node comes back online.
        Note: If multiple nodes are online, the entire BIG-IP DSC group will go into a Change Pending state. This can only be resolved by the system administrator.
    • Ignore BIG-IP DSC sync when deploying configuration changes: Select this option if you want to manually synchronize configurations changes between members in the DSC group.
  9. Click the Add button at the bottom of the screen.
    The BIG-IQ system opens communication to the BIG-IP device, and checks the BIG-IP device framework.
    Note: The BIG-IQ system can properly manage a BIG-IP device only if the BIG-IP device is running a compatible version of the REST framework.
  10. Click the Discover & Import button at the bottom of the screen.
  11. To centrally manage this device’s configurations for licensed services, select the check box next to each service you want to discover.
    You can select other service configurations after you add the BIG-IP device to the inventory.
You can now discover the services for this device, and manage any differences for shared objects (on an object-by-object basis) between the BIG-IQ system and the BIG-IP device(s) during import.
After you add a BIG-IP device to BIG-IQ Centralized Management, you can discover and import its services.
You discover and import services for a BIG-IP device so you can start managing it. Use this procedure if you added a BIG-IP device, but have not yet discovered and imported its services. When you’re importing services, you have the opportunity to select a conflict resolution option for any conflicts between the shared objects between BIG-IQ and this BIG-IP device.
  3. Click the name of the BIG-IP device you’re discovering and importing services for.
  4. On the left, click SERVICES.
  5. If you want to create a snapshot of this device’s current configuration before discovering and importing its services, select the Create a snapshot of the current configuration before importing check box for each service.
    This step is optional.
  6. For each service this BIG-IP device is licensed for, click the Discover button.
  7. Once BIG-IQ has discovered the service, click the Import button next to the service.
    If there is a difference between BIG-IQ and this device for the service’s objects, a popup screen opens and you are prompted to resolve the conflict by using the object on the BIG-IQ system or the BIG-IP device.
When you’re finished discovering and importing services for this device, the device displays on the BIG-IP Devices screen.
You can now manage this device and its services.
Before you add BIG-IP devices to BIG-IQ and discover and import their services, save the devices’ information in a comma separated values file. The information you save can include:
Device Details
Description and Action
Management IP address
Specify the management IP address(es) for the BIG-IP device(s) you are adding.
HTTPS Port
Type the management port for this BIG-IP device(s).
This number must be between 4 and 65535 In
management port, you won’t be able access the BIG-IP device’s interface from BIG-IQ when using Chrome or Safari. You can still discover and manage BIG-IP devices that are using port
65535.
User Name
Specify the user name for the device(s).
Password
Specify the password for the device(s).
Cluster Name
Specify if these devices are part of a cluster.
DSC Sync Mode
If these devices are part of a DSC, initiate DSC sync when deploying configuration changes by specifying FALSE.
Pending Changes
If these devices are part of a DSC, allow deployment of any pending changes by specifying TRUE.
Services List
List of services running on these devices, separated by a space. For example: LTM APM ASM AFM SSM DNS FPS
Enable Statistics Collection
If these device are collecting statistics, allow data collection by specifying TRUE.
Zone
If these devices are part of a data collection device cluster, specify the name of their zone.
APM Group
If these devices support the APM service, specify the APM group.
APM Shared Import
If these devices are part of an APM group, set this to TRUE only for the first device in the APM group, leave the rest at FALSE.
Shared Object Conflict Policy
Specify how you want any shared object conflicts between BIG-IQ and the BIG-IP devices using one of the following values: USE_BIGIQ, USE_BIGIP, .
Version Object Conflict Policy
Conflict Resolution Policy for Version Specific Objects. Specify one of the following values: USE_BIGIQ, USE_BIGIP, KEEP_VERSION. The default is USE_BIGIQ.
Device Specific Conflict Policy
Conflict Resolution Policy for Device Specific Objects. Specify one of the following values: USE_BIGIQ, USE_BIGIP. The default is USE_BIGIP.
You must save your devices’ details in a comma separated value (CSV) file.
If you are running BIG-IP versions earlier than version 11.6.0, you might need root user credentials to discover and add the device to the BIG-IP devices inventory. You don’t need root user credentials for BIG-IP devices running versions 11.6.0 and later.
Important: For devices with ASM services, you can only add 5 devices at a time.
You add BIG-IP devices to BIG-IQ Centralized Management and discover and import their services so you can start managing them. This procedure allows you add multiple BIG-IP devices to BIG-IQ using a comma separated value (CSV) file, and discover and import their services.
  4. For the Device setting, select Add multiple BIG-IP devices
  5. For the Snapshot setting, leave the check box selected, unless:
    • You don’t want to create a copy of the current BIG-IQ configuration before adding these devices, and discovering and importing their services.
    • You’re adding devices with the APM service and you plan on creating a new access group for them during this task.
  6. check box is selected, If you want BIG-IQ to skip importing any service that contains an object that conflicts with the object on BIG-IQ, and continue discovering and importing other services, select the Conflict Resolution check box.
    You’ll have the opportunity to re-import the services with conflicting objects, and resolve the conflicts individually after discovery and import is complete.
  7. Click the Upload CSV button.
  8. Navigate to the location where you saved your CSV file and click Open.
  9. Select the check box next to the BIG-IP devices you want to discover and import services for, and click the Discover and Import button at the bottom of the screen.
To view status and address any conflicts between BIG-IQ and BIG-IP device objects, on the left, click BIG-IP DEVICES.
After you add BIG-IP devices to BIG-IQ Centralized Management and discover and import their services, you can start managing those devices.
You can use a device’s Properties screen to manage that device. You can log directly in to the device, remotely reboot it, and create an instant backup of its configuration. You can also view details about the managed device, such as:
  • Host name
  • Self IP Address
  • Build Number
  • Software Version
  • Status
  • Last Contact
  • Boot Location
  • Cluster Properties
From this screen you can also perform the following tasks:
  • Create an instant backup of the device’s configuration.
  • Change the boot location of the device.
  • Edit cluster properties.
  • Log directly into the device from BIG-IQ.
  • Reboot the device from BIG-IQ.
  • Access details about the health of the device.
  • Access statistics for the device (if applicable).
  • Access services licensed for the device.
  2. Click the name of the device you want to view.
    The device Properties screen opens.
To more easily manage a large number of BIG-IP® devices, you can organize them into groups. The types of groups you can use are:
  • Static groups
  • Dynamic groups
A static group contains specific devices that you add to it, and those devices stay in that group until you remove them. For example you might want to create a static group named, Seattle, and add all of the devices located in Seattle to it.
In contrast, a dynamic group is basically a saved query on a group. For example, if you created a static group that contained all of your managed devices located in Seattle and you wanted to view only those devices running a specific application, you could create a dynamic group with that filter. If one of the devices stops running the specified application, the device no longer appears in that dynamic group.
If you delete a managed BIG-IP device from the parent group, you see that change when you view the dynamic group.
You must license and discover BIG-IP devices before you can place them into a group.
To more easily manage a large number of devices, you can organize them into groups. For example, you could add devices to groups according to the running applications, geographical location, or department.
  2. On the left, click DEVICE GROUPS.
  3. Near the top of the screen, click the Create button.
  4. In the Name field, type the name you want to use to identify this group.
    You can change this name at any time, after you save this group.
  5. In the Description field, type a description for this group.
    For example, BIG-IP devices located in Seattle.
    You can change this description at any time, after you save this group.
  6. For the Group Type setting, select Static.
  7. From the Parent Group list, select the source for the group you are creating.
  8. For the Available in Services setting, select the services licensed for this device.
    If this BIG-IP device is licensed for services you are not managing, you can reduce the number of devices displayed in the BIG-IP inventory by selecting the check box next to only the services you manage. If you are managing all aspects of BIG-IQ, select the check box next to each service running on this BIG-IP device.
  9. From the Hostname list, select the device you want included in this group.
    To add additional devices, click the + sign and select a device from the new list that is displayed.
  10. Click the Save & Close button.
If you want to further filter specific devices from within this group, you can create a dynamic group.
You must create a static group before you can create a dynamic group.
To filter a static group on certain parameters, you can create a dynamic group. For example, if you have a static group for all devices located in a particular city, and you want to view only those running a specific version of software, you could create a dynamic group to filter on that version number.
  3. Click the Add Group button.
    For example, BIG-IP Devices running version 13.0
    You can change this description any time, after you save this group.
  6. For the Group Type setting, select Dynamic Group.
  8. In the Search Filter field, type a term on which you want to filter the group.
  9. For the Available in Services setting, select the services licensed for this device.
This dynamic group reflects any changes made to the static group. For example, if a device is removed from its parent group, it no longer appears in the associated static group. Also, if a device no longer contains the object you filtered on, the device no longer displays in the dynamic group.
From each BIG-IQ screen that contains a list of objects, you can easily find specific objects. For example, after you discover several devices, you might want to find a specific device by its name or IP address. To do this, you start by filtering on certain configuration objects. Filtering on specific criteria saves you time because you can view only those objects associated with the criteria you specify.
  2. To search for a specific object, in the Filter field at the top right of the screen, type all or part of an object’s name and click the filter icon.
    BIG-IQ refreshes the screen to show only those devices that contain the object you filtered on.
  3. To remove the filter, click the X icon next to it.
To export the BIG-IP Device inventory to a CSV file, your browser must be configured to allow popup screens.
Using BIG-IQ, you can quickly access and view the properties for all the devices you manage in your network. These properties include details about the device’s IP addresses, platform type, license details, software version, and so forth. You (or another department in your company) can create custom reports containing this information to help manage these assets. To do this, you can export device properties to a CSV file and edit the data as required.
  3. Click the Export Inventory button.
BIG-IQ creates a CSV file and downloads it locally.
When you manage BIG-IP device from BIG-IQ Centralized Management, it is good practice to change the default admin and root passwords on a regular basis. From BIG-IQ, you can change the passwords for several BIG-IP devices at one time.
Note: You can change the passwords for several BIG-IP devices simultaneously only if they have the same password.
  2. On the left, click PASSWORD MANAGEMENT > Change Device Passwords.
  4. In the Name and Descriptions fields, type a name and optional description to help you identify this task.
  5. From the Available list, select devices and move them to the Selected list.
    Important: The passwords for the BIG-IP devices you select must all be identical.
  6. Select an option for the Change Password setting.
  7. Provide the old and new passwords, as required.
  8. Click the Run button at the bottom of the screen.
    BIG-IQ will apply the new password to all of the selected BIG-IP devices. You can view the status of this task from the Change Device Passwords screen.
If you upgrade or make a change directly on a managed BIG-IP device, you must re-discover and re-import services for that device so BIG-IQ Centralized Management has the most current configuration for that device.
  2. Select the check box next to the device you want to rediscover and reimport services for.
  3. Click the More button and select Re-discover and Re-import.
  4. In the Name and Description fields, type a name and an optional description to identify this task.
  5. For the -[[+[[]]-Shared Object -[[]]+]]-Conflict Resolution Policy and Version Object Conflict Resolution Policy and Device Object Conflict Resolution Policy settings, select an option:
    • Use BIG-IQ Keep the object in BIG-IQ system’s working configuration. The next time BIG-IQ deploys a configuration to that BIG-IP device, it updates the object to match the one on BIG-IQ.
    • Use BIG-IP if you want to override the configuration settings stored on BIG-IQ with the settings from the BIG-IP device if any differences for shared objects are found. For the Version Object Conflict Resolution Policy, you also have the option to select Create Version, if you want BIG-IQ to create a version-specific object if any differences for version-specific objects are found. If you select this option, BIG-IQ creates and stores a copy of the BIG-IP device’s LTM monitor or profile object (s), specific to the software version running on that BIG-IP device and replaces that object for all the managed BIG-IP devices running that version, the next time it deploys a configuration. You can store multiple versions of LTM monitors or profiles. BIG-IQ deploys the appropriate stored version to your managed devices. BIG-IQ automatically resolves conflicts against the appropriate version the next time it imports services that contain LTM monitors or profiles.
  6. If you want to save a snapshot of the BIG-IP device’s configuration before importing their services, select the Create a snapshot of the current configuration before importing check box.
  7. Click the Create button at the bottom of the screen.
You can now manage these BIG-IP devices.
Device Service Clustering, or DSC, is a BIG-IP TMOS feature that lets you organize BIG-IP devices in groups to share configurations. These groups are called device service clusters (also DSC). With BIG-IQ, you can manage devices configured in a DSC, and their shared objects, from one centralized location.
Before you can manage BIG-IP systems configured in a DSC, you must:
  • Add the DSC device members to the BIG-IP Devices inventory.
  • Add the DSC group to the BIG-IP Clusters inventory.
  • Ensure that each DSC group includes at least one sync-failover configuration.
When a DSC group is in the BIG-IP Cluster inventory, you can view its properties and the devices within those groups, and synchronize their configurations, all without having to log in to each device individually. This allows for automatic synchronization among devices for any changes on objects defined in the cluster.
Note: For specific information about BIG-IP DSC groups, refer to the BIG-IP® Device Service Clustering: Administration guide.
It is important to note, that although objects are shared among devices in a DSC group, they appear based on the state of each managed BIG-IP device. This can indicate that objects, such as a shared pool, is offline for a specific device that is experiencing network issues. However, the pool will appear as online for other devices in the DSC group.
You must add the BIG-IP devices configured in a DSC to the BIG-IQ system’s BIG-IP Device inventory before you can discover DSC groups.
All BIG-IP devices in a cluster must be running the same software version and the same settings for:
  • Pools
  • Traffic-groups
  • VLANs
  • Tunnels
  • Route domains
The BIG-IQ DSC Groups inventory screen shows you a centralized view specific to DSC clusters.
Note: The Cluster Display Name displays on this screen only for managed BIG-IP devices in a DSC.
Important: BIG-IQ supports up to 8 BIG-IP systems in a DSC.
  2. On the left, click BIG-IP CLUSTERS > DSC groups.
  3. Click the Discover button.
  4. Select the devices in the Available list, and then click the right arrow to add them to the Selected list.
    This list is populated from the BIG-IP Device inventory list. If you can’t see all of the available devices listed, left-click the right bottom corner of the list and use your cursor to expand the dialog box.
  5. Click the Discover button.
The DSC Groups list refreshes to display the discovered DSC group.
You must add a BIG-IP device configured in a DSC to the BIG-IP Devices inventory list and discover the DSC from the DSC Groups inventory list before you can synchronize BIG-IP devices configured in a DSC.
Synchronizing configuration between BIG-IP devices in a DSC cluster saves you time because you don’t have to log on to each BIG-IP device in the cluster individually.
Important: Unmanaged BIG-IP devices in a DSC do not display the Sync button.
  2. On the left, click BIG-IQ CLUSTERS > DSC Groups.
    The screen displays the list of DSC groups defined on this device.
  3. Click the name of the cluster you want to synchronize.
  4. Click the Refresh Status button to get the most current sync status for the devices in the DSC group.
  5. For the Sync Option setting, select one of the options:
    • Device to Group - Select this option to prompt the BIG-IP device to synchronize its configuration with other device(s) in the DSC group.
    • Group to Device - Select this option to prompt the DSC group to load its configuration onto the BIG-IP device.
  6. Click the Sync button.
  7. To close the screen, click the Close button.
