Updated Date: 07/07/2026
Health monitoring and alerts using SMTP and SNMP alerts
You specify an SMTP server so F5 BIG-IQ Centralized Management can send email to alert specified people when a certain condition happens, such as when an SSL certificate is about to expire.
At the top of the screen, click System.
On the left, clickSMTP configuration.
Click the Add button at the upper right of the screen.
In the Name field, type a name for this SMTP configuration.
In the SMTP Server Host and SMTP Server Port fields, type the SMTP server and TCP port.
By default, SMTP uses TCP 25.
In the From Email Address field, type the email address from which to send the alert email.
From the Encryption list, select the type of encryption to use for the email.
To require a user name and password, from the Use Auth list, select Yes, and type the required user name and password.
To verify that you can reach the server you configured, click the Test Connection button.
Click the Save & Close button.
You can now specify email recipients and set up the alert conditions that prompt BIG-IQ to send an email when a certain event happens on a managed device.
Simple Network Management Protocol (SNMP) is an Internet-standard protocol for collecting and organizing information about managed devices on IP networks. You can set up BIG-IQ® to work with SNMP so you can receive alerts when certain things happen on a managed device.
To set up BIG-IQ to work with SNMP, you must:
- Set up the SNMP Agent
- Configure SNMP Access
- Specify settings for the SNMP Trap
Gather the following information before you start your SNMP configuration.
| CONFIGURATION COMPONENT | CONSIDERATIONS | FOR MY CONFIGURATION |
| SNMP administrator contact information | Find out or decide who is responsible for SNMP administration. The contact information is a MIB-II simple string variable. | |
| Machine location | Find out the location of the BIG-IQ system. The location is a MIB-II simple string variable. | |
| BIG-IQ client allow list | Gather the IP or network addresses (with netmasks) of the SNMP managers from which the SNMP agent will accept requests. | |
| Access | Find the OID for the top-most node of the SNMP tree to provide access to. | |
| Community | Get the v1 and v2c communities and the IP addresses of the SNMP managers you want to grant access to. | |
| Users | Get the v3 users you want to grant access to SNMP data, along with the privacy protocols and passwords, Community, Destination, and Port. |
This screen displays specified user addresses allowed to access your 3rd-party SNMP Manager BIG-IQ through the SNMP Agent. An agent can communicate with multiple managers, so you can configure BIG-IQ to support communications with one management station using the SNMP version1 protocol, one using the SNMP version 2C protocol, and another using SMNP version 3.
On the left, click SNMP Configuration > SNMP Agent .
At the top of the screen, click the Download MIB button to download the F5-required MIBs.
At the top of the screen, click Edit.
Edit the Contact Information and Machine Location fields to reflect your SNMP agent settings and click the Save & Close button at the bottom of the screen.
Click the Save & Close button at the bottom of the screen to save your changes.
For the SNMP Access - Client Allowed List setting, click the Add button.
In the Addresses/Networks and Mask fields, type the IP address and networks and the netmask (if applicable) that the SNMP manager is allowed to access.
To add another address, click the plus ( + ) sign.
You can now configure SNMP access and SNMP traps.
After you configure the SNMP agent, you can configure SNMP access and SNMP traps.
You configure SNMP access to allow the SNMP agent to accept requests from specific SNMP managers.
On the left, click LOCAL HOST SETTINGS > ****SNMP Configuration > SNMP Access (v3).
In the Name and User Name fields, type a name for this SNMP access and the user name.
If you want to specify the authentication protocol for SNMP traps, from the Type list, select an option.
- MD5 specifies digest algorithm.
- SHA specifies secure hash algorithm.
If you selected an authentication protocol, in the Password and Confirm Password fields, type and confirm the password for access.
The password must be between 8 and 32 characters, include alphabetic, numeric, and special characters, but no control characters.
If you want to encrypt the SNMP traps, from the Protocol list, select an option.
- AES specifies Advanced Encryption Standard
- DES specifies Data Encryption Standard
If you selected a privacy protocol, in the Password and Confirm Password fields, type the password to use for authentication.
Alternatively, you can select theUse Authentication Password check box to use the authentication password.
In the OID field, type the object identifier (OID) you want to associate with this user.
From the Access list, select an option:
- Read Only - This user can only view the MIB.
- Read/Write - This user can view and modify the MIB. The most secure access level or type takes precedence when there is a conflict. When you set the access level to read/write, and an individual data object has a read-only access type, access to the object remains read-only.
On the left, click SNMP Traps.
In the Name field, type a name for this SNMP trap.
From the Version list, select V3.
In the Destination and Port fields, type the IP address and the port for this trap destination.
For the Security Level setting, select an option. Auth, No Privacy processes SNMP messages using authentication, but no encryption. Auth and Privacy processes SNMP messages using authentication and encryption.
For the Security Name setting, specify the user name you want to use to handle SNMP version 3 traps.
For the Engine ID setting, specify the unique identifier (snmpEngineID) of the remote SNMP protocol engine.
In the Password and Confirm Password fields, type and confirm the password for the protocol.
You can now specify email recipients for alerts.
On the left, LOCAL HOST SETTINGS > SNMP Configuration > SNMP Access (V1, V2C)
At the top left of the screen, click the Add button.
In the Name field, type the SNMP manager’s user name.
From the Type list, select the format for the IP address.
In the Community field, type the community string (password) for access to the MIB.
From the Source list, select a source or select Specify and type the source address for access to the MIB.
In the Community, Destination, and Port fields, type, respectively, the community name, IP address, and port for the trap destination.
At the bottom of the screen, click the Save & Close button.
After you configure SMTP and/or SNMP, you can add email recipients.
Email recipients you add will get alert notifications when specified events happen on BIG-IQ or your managed devices
On the left, click LOCAL HOST SETTINGS > Email Notification Recipients.
In the Name the Email address fields, type the name and email address of the person you want to receive an alert.
In the Description field, you can type an optional description to help identify this user.
Select the check box next to each type of notification you want this user to receive an email about.
To add another email recipient, click +.
You can now configure the alert settings that trigger BIG-IQ to send an email to the specified recipients.
When you manage BIG-IP® devices that load balance SSL traffic, you must monitor their SSL traffic.
BIG-IQ® imports the certificates for every managed BIG-IP device you discover. This makes it easy to monitor the expiration dates all of your devices’ SSL certificates from one location.
You can also:
- Set up alerts to let you know when a certain certificate is about to expire within a specified number of days.
- Download the data to a CSV file for reporting purposes.
After you set up the SNMP and/or SMTP on F5 BIG-IQ Centralized Management, you can select the alerts that prompt BIG-IQ to send an email to the people you specified.
At the top of the screen, click Monitoring.
On the left, click ALERTS & NOTIFICATIONS.
At the top of the screen, click the Settings button.
Select the Enabled check box next to each alert you want to receive and, if applicable, specify the Threshold.
Only SNMP events specified as Yes are available for SNMP alerts. BIG-IQ uses SMTP for all other event types.
