Manual Chapter : Integrating Venafi with BIG-IQ for Certificate Management
Applies To:
  • BIG-IQ Centralized Management
    7.0.0
F5 Networks and Venafi have partnered to provide a tightly-integrated solution for certificate and key management. Managing Venafi certificate requests through BIG-IQ automates laborious processes and reduces the amount of time you have to spend requesting and distributing certificates and keys to your managed devices. From BIG-IQ, you have a centralized view into the key and certificate life cycle for your BIG-IP devices in multi-cloud and local environments.
To maintain the security of sensitive information on your Venafi Trust Protection Platform information, BIG-IQ generates a new authorization key with each API call. The authorization key expires soon after each call, preventing attackers from gaining access by re-using older keys.
You’ll need to configure your Venafi Trust Protection Platform before you add Venafi as a CA provider.
Add Venafi as a CA provider so you can send Certificate Signing Requests to Venafi to get certificates and keys for your BIG-IP devices from BIG-IQ.
  1. At the top of the screen, click Configuration.
  2. On the left, click LOCAL TRAFFIC.
  3. On the left, click Certificate Management > Third Party CA Management.
  4. From the CA Providers list, select Venafi.
  5. Click Create.
  6. In the Web SDK Endpoint field, type the address for the Venafi Web SDK endpoint BIG-IQ sends the CSR to.
  7. In the User Name and Password fields, type the user name and password for the Web SDK Endpoint.
  8. Click the Test Connection button to verify BIG-IQ can reach it.
    If you haven’t yet configured the Venafi Trust Protection Platform, the test will fail.
  9. Click the Save & Close button at the bottom of the screen.
    The Venafi provider you added appears in the list.
  10. Click the Edit Policy link of the new Venafi provider you added.
  11. In the Policy Folder Path type the path of the Venafi Trust Protection Platform where the certificates and keys are located, and then click the Get button.
    BIG-IQ populates the Policy Folder List with the policies to where BIG-IQ should send Certificate Signing Requests. At this point (or at a later time), you have the option to rename the policies for easier identification by editing its nickname.
  12. If you want to change the credentials of the Venafi Web SDK endpoint, click its name.
You can now add a Venafi CSR to send to Venafi to get certificates for your BIG-IP VE devices.
To automatically send a CSR from BIG-IQ, you must have selected User Provided CSR for the CSR Generation option when you configured the Venafi platform.
Create a Certificate Signing Request (CSR) on BIG-IQ to use to request certificates and keys from Venafi.
  1. At the top of the screen, click Traffic & Network
  2. On the left, click LOCAL TRAFFIC > Certificate Management > Certificates & Keys.
  3. Near the top of the screen, click the Create button.
  4. If the partition is anything other than Common, type it into the Partition field.
  5. In the Certificate Properties area, from the Issuer list, select the Venafi CA.
  6. From the Policy Folder list, select the policy you retrieved from Venafi.
  7. Specify the division and organization for the certificate.
  8. Complete the SSL certificate properties.
    Note: A Subject Alternative Name is embedded in a certificate for X509 extension purposes. Supported names include email, DNS, URI, IP, and RID. For the Subject Alternative Name field, use the format of a comma-separated list of name:value pairs.
    If Venafi is configured for manual CSR approval, the approval process might require a few hours. The pending approval is indicated in the BIG-IQ UI until certificate retrieval. Navigating away from this screen will not disrupt the process.
BIG-IQ generates the CSR and sends it to Venafi for signed certificates and keys. The signed certificate displays on the Certificate and Keys screen.
You can now assign this certificate to your managed BIG-IP VE devices.
You must add Venafi as a third-party certificate authority before you can import certificates from Venafi.
Import certificates from Venafi so you can deploy them to your managed BIG-IP devices.
  2. On the left, click Certificate Management > Certificates & Keys.
  3. From the Import Type list, select Import from CA Providers.
  4. Select the check box next to Venafi, enter the passphrase, and click the Import button at the bottom of the screen.
