Manual : How do I manage software licenses for my devices?
Applies To:
  • BIG-IQ Centralized Management
    7.0.0
A software license is specific to F5 product services (for example, BIG-IP LTM, BIG-IP APM, and so forth), and is organized in a license pool. From BIG-IQ Centralized Management, you can easily manage licenses in those pools for numerous devices. That means you don’t have to log in to each individual BIG-IP VE device to activate, revoke, or reassign a license.
After you activate your subscription or ELA registration key for a pool license from BIG-IQ, you can assign the license to a managed, or unmanaged, BIG-IP VE device. If you assign a license from a license pool to a BIG-IP device and later decide you don’t need that device licensed, you can revoke the license and assign it to another BIG-IP VE device. This process is similar to a library, where you loan (assign) a license to a BIG-IP device when it is required, and check the license back into the license pool on BIG-IQ (revoke it from the device) so it is available to assign to another BIG-IP VE. This flexible licensing model helps keep track of the licenses, and manage your operating costs.
There are 3 types of devices you can manage licenses for:
Managed BIG-IP devices
From BIG-IQ, you assign licenses to and revoke license from BIG-IP devices using each device’s SSL certificate for authentication over an SSL connection.
Unmanaged BIG-IP devices
From BIG-IQ, you assign licenses to and revoke licenses from BIG-IP devices using each BIG-IP device’s IP address, user name, and password for authentication over an SSL connection.
Unreachable devices
Unreachable devices (sometimes referred to as disconnected devices) are devices that BIG-IQ can generate licenses for without direct communication between BIG-IQ and BIG-IP. Because there is no direct communication between BIG-IQ and BIG-IP, clients must provide additional device information as input. The client is responsible for installing the license on BIG-IP. To do that, use an API call through a third-party computer or program that communicates with BIG-IQ to get a license from BIG-IQ and assign it to the BIG-IP device by a method of your choosing. The third party makes a similar API call to BIG-IQ for revoking a license. For more information, see the F5 API documentation for BIG-IQ.
To manage licenses for BIG-IQ devices, you must be assigned to one of the following roles:
  • Admin
  • Device Manager
  • License Manager
  • Types of license pools
    There are four types of license pools. You can assign, revoke, and reassign licenses from these pools as needed.
