Manual Chapter : Revoke pool license from a BIG-IP VE device
Applies To:
Show Versions Show Versions
BIG-IQ Centralized Management
  • 7.0.0
Manual Chapter
Before you can revoke a license for a device in your network, you must have the device's IP address.
When fewer devices are required for your applications, you can revoke licenses to reassign them to other BIG-IP VE devices, as needed. This procedure allows you to revoke a single license.
  1. At the top of the screen, click
    Devices
  2. On the left, click
    LICENSE MANAGEMENT
    Assignments
  3. Select the check box next to the device you want to remove a license from.
  4. If this is an unmanaged device, type the BIG-IP system's administrator's
    Username
    and
    Password
    Unmanaged devices
    are devices that are located in your network, but are not in the BIG-IQ system's BIG-IP Inventory list. These fields do not display if this is a managed device.
  5. Click the
    Revoke
    button at the bottom of the screen.
