Updated Date: 07/07/2026
Revoke pool license from a BIG-IP VE device
Before you can revoke a license for a device in your network, you must have the device’s IP address.
When fewer devices are required for your applications, you can revoke licenses to reassign them to other BIG-IP VE devices, as needed. This procedure allows you to revoke a single license.
Important: When you revoke a BIG-IP license, BIG-IQ removes it from the BIG-IP. When the license is removed, that BIG-IP is no longer operable and won’t be able to manage traffic.
At the top of the screen, click Devices.
On the left, click LICENSE MANAGEMENT > Assignments.
Select the check box next to the device you want to remove a license from.
If this is an unmanaged device, type the BIG-IP system’s administrator’s Username and Password.
Unmanaged devices are devices that are located in your network, but are not in the BIG-IQ system’s BIG-IP Inventory list. These fields do not display if this is a managed device.
Click the Revoke button at the bottom of the screen.
This license is now available for re-assignment to another BIG-IP VE device.
