Manual Chapter :
How do I start managing SSL Orchestrator from BIG-IQ?
Applies To:
Show Versions
BIG-IQ Centralized Management
- 7.0.0
To manage SSL Orchestrator (SSLO) from BIG-IQ Centralized Management, BIG-IQ must be managing the BIG-IP devices running SSLO. To start managing a BIG-IP device, you must add it to the BIG-IP Devices in the BIG-IQ Centralized Management's inventory list.
There are a few ways you can add BIG-IP and BIG-IP VE devices to your BIG-IQ system so you can start managing them.
- Add a BIG-IP or BIG-IP VE device located in your network, specify its configuration options, and import its services all in one step in a process calledonboarding.
- Add a BIG-IP VE device located in a third-party cloud environment, then onboard it.
- Add a single BIG-IP device located in your network, and discover and import its services in a separate procedure. When you do this, you can manage any differences for shared objects between BIG-IQ and the BIG-IP device you’re adding, on an object-by-object basis.
You cannot discover the SSL Orchestrator service from multiple BIG-IP devices at once. This service must be discovered from one BIG-IP device at a time.
