Updated Date: 07/07/2026
Behavioral DoS charts
The charts that reflect behavioral DoS (BaDoS) data allow you to analyze traffic the system used to detect server stress over time. The parameters found in the charts described can indicate when attacks occurred and the amount of time required by the system to mitigate the attack. To view charts for an object protected by BaDoS, go to Monitoring > DASHBOARDS > Protected Objects and select a protected object name. Alternatively, go to Configuration > SECURITY > Shared Security > Protected objects > **** and select an object.
Note: Chart data is available only to certain versions of BIG-IP devices. See the chart information to verify whether data will appear for your object.
- Server Stress
- A measure of your application server (pool members) status, based on traffic volume data. Once a stress-based threshold is crossed the application’s stress status is elevated. Available to BIG-IP version 15.0 or later.
- Server Queue
- The BIG-IP host names, managing the virtual server’s traffic, with the highest server queues. Available to BIG-IP version 15.0 or later.
- Client HTTP Transactions
- The client-side outcome for HTTP transactions. Available to BIG-IP version 15.1 or later.
- Client HTTP Requests & Transactions
- The client-side outcome for HTTP requests and transactions. Available to BIG-IP version 15.1 or later.
- Server HTTP Transactions
- The server-side outcome for HTTP requests and transactions. Available to BIG-IP version 15.1 or later.
- Concurrent Server Side Connections
- The average number of active connections per second on the server side with the BIG-IP virtual server. Available to BIG-IP version 15.1 or later.
- TLS Handshakes
- The average number of transport layer security (TLS) handshakes to your virtual server. Available to BIG-IP version 15.1 or later.
- Connections Mitigation
- The average number of connection per second and the system mitigation action against the connection. Available to BIG-IP version 15.1 or later.
- Layer 3-4 & SSL Mitigations
- The number of dropped packets, or signatures, depending on the attack layer detection. Available to BIG-IP version 15.1 or later.
- HTTP Mitigation
- The number of dropped application layer connections, based on the mitigation action. Available to BIG-IP version 15.1 or later.
