Manual Chapter : Deploy configuration changes
Applies To:
Show Versions Show Versions
BIG-IQ Centralized Management
  • 7.1.0
Manual Chapter
To apply the changes you made on the BIG-IQ Centralized Management system to your managed device, you must deploy those changes to the managed device.
  1. At the top of the screen, click
    Deployment
  2. Under
    EVALUATE & DEPLOY
    , select the component for which you want to make changes.
    The screen displays a list of evaluations and deployments defined on this device.
  3. Click the name of the evaluation that you want to deploy.
    The View Evaluation screen opens.
  4. Scroll down to Deployment, and then use the Schedule controls to specify whether you want to deploy the changes immediately or schedule deployment for later.
    • To deploy this change immediately:
      1. Select
        Deploy Now
      2. Click
        Deploy
        to confirm.
    • To deploy this change later:
      1. Select the
        Schedule for later
        check box.
      2. Select the date and time.
      3. Click
        Schedule Deployment
    The process of deploying changes can take some time, especially if there are a large number of changes. During this time, you can click
    Cancel
    to stop the deployment process.
    If you cancel a deployment, some of the changes might have already deployed.
    Cancel
    does not roll back these changes.
The evaluation you chose is added to the list of deployments on the bottom half of the screen.
  • If you chose to deploy immediately, the changes begin to deploy and the Status column updates as it proceeds.
  • If you choose to delay deployment, the Status column displays the scheduled date and time.
