Manual Chapter : Warehouse Topic: BIG-IQ UI Navigation and Common Labels
Applies To:
Show Versions Show Versions
Manual Chapter
  1. At the top of the screen, click
    Monitoring
  2. At the top of the screen, click
    Configuration
  3. At the top of the screen, click
    Deployment
  4. At the top of the screen, click
    Devices
  5. At the top of the screen, click
    System
  6. At the top of the screen, click
    Applications
  7. At the top of the screen, click
    Traffic & Network
  8. In the
    Name
    and
    Description
    fields, type a name and an optional description to identify this task.
  9. Near the top of the screen, click the
    Create
    button.
  10. Near the top of the screen, click the
    Add
    button.
  11. Near the top of the screen, click the
    Remove
    button.
  12. Near the top of the screen, click the
    Import
    button.
  13. Near the top of the screen, click the
    Export
    button.
  14. Near the top of the screen, click the
    Delete
    button.
  15. Near the top of the screen, click the
    Clone
    button.
  16. Near the top of the screen, click the
    Deploy
    button.
  17. Near the top of the screen, click the
    Cancel
    button.
  18. Near the top of the screen, click the
    Compare
    button.
  19. Near the top of the screen, click the
    Restore
    button.
  20. Near the top of the screen, click the
    Edit
    button.
  21. Click the
    Add
    button at the bottom of the screen.
  22. Click the
    Save & Close
    button.
  23. Click the
    Create
  24. In the
    Name
    field, type a name to help you label this task.
  25. In the
    Description
    field, type an optional description to further identify this task.
  26. At the top of the screen, click
    Configuration
    , then, on the left, click
    LOCAL TRAFFIC
    Virtual Servers
    The screen displays the list of virtual servers defined on this device.
    If you select the check box for a virtual server, you can delete it, clone it, attach iRules to it, view statistics for it, or deploy it. You can also view details about other configuration objects to which this virtual server relates.
  27. At the top of the screen, click
    Configuration
    SECURITY
    Threat Intelligence
    Web Application Security
    The SIGNATURE FILES, SERVER TECHNOLOGIES FILES, and BROWSER CHALLENGES FILES menus appear.
  28. At the top of the screen, click
    Devices
    BIG-IP DEVICE SILOS
    The screen displays the list of silos defined on this device.
  29. At the top of the screen, click
    Devices
    BIG-IP DEVICES
    The screen displays the list of devices managed by this BIG-IQ.
