Manual Chapter : Configure device specific SSLO settings
Applies To:
Show Versions Show Versions
BIG-IQ Centralized Management
  • 8.0.0
Manual Chapter
From BIG-IQ, you can modify the device configuration for a managed BIG-IP device and view the status of services deployed to a device, and deploy changes to this device.
  1. At the top of the page, view your services deployed in a topology on this device. To make any edits to security service configuration, select the name of the service and you will be directed to a page where you can make edits.
  2. From BIG-IQ, navigate to
    Configuration
    SSL Orchestrator
    Devices
  3. Select a managed BIG-IP device from the
    Devices
    list.
    You will be directed to a page where you may configure SSLO BIG-IP device settings.
  4. Under
    Device Settings
    , specify whether you want this configuration to support IPv4 addresses or IPv6 addresses from the dropdown menu.
    You must configure IP addresses in the family you select for all IP address fields in this application.
  5. Under the
    DNS
    section, select either
    Internet Authoritative Nameserver
    to permit the system to send DNS queries directly out to the Internet, you can select
    Local Forwarding Nameserver
    Direct resolution can be more reliable than using forwarders but requires outbound UDP+TCP port 53 access to the Internet.
  6. Click the DNSSec Validation checkbox to specify whether you want to use DNSSEC to validate the DNS information.
    F5 recommends using DNSSEC to validate DNS information as it improves security.
  7. If you selected
    in the above section, add one or more
    Local DNS Nameserver
    in the section
    Local Forwarding NameServer(s)
  8. Under
    Routing
    , select
    Default
    to allow the system to let all SSL intercept traffic use the default route, or select
    Create New
    to route the traffic through a custom Internet gateway. Add an
    Address
    and specify the
    Ratio
    to define the ratio of traffic sent to each device.
  9. Under the
    Logging Configuration
    section, select a logging level for this device from the dropdown menu. You may select from Errors, Normal, or Debug.
  10. You may enable the default log configuration by selecting the checkbox. For
    Per-Request Policy
    FTP
    IMAP
    POP3
    SMTPS
    , and
    SSL Orchestrator Generic
    (generic logs for the SSL Orchestrator configuration), select the level of severity that you would like to log for this data.
  11. Select
    Deploy
    to push changes to this managed device.
Your configuration changes will be deployed to the managed BIG-IP device.
