Manual Chapter : Upgrade SSLO RPM versions
Applies To:
Show Versions Show Versions
BIG-IQ Centralized Management
  • 8.0.0
Manual Chapter
Before you begin the process of installing an SSLO RPM upgrade, obtain the SSLO RPM file you are interested in installing to the managed devices by navigating to f5.downloads.com and downloading the relevant files to your local machine.
You may use BIG-IQ Centralized Management to upgrade your SSL Orchestrator RPM version from within BIG-IQ.
  1. From BIG-IQ, navigate to
    SSL Orchestrator
    Devices
  2. Select the checkbox next to the device or devices you are interested in installing an upgrade SSLO RPM version to.
  3. Select
    Upgrade SSL Orchestrator
    A popup will appear.
  4. Click the
    Choose file
    button and select an RPM file from your local machine.
  5. Once you have uploaded the file, select
    Upgrade
Your managed BIG-IP device will be upgraded to your desired SSLO RPM version.
