Manual Chapter : Check the status of daemons running on BIG-IQ
Applies To:
Show Versions Show Versions
BIG-IQ Centralized Management
  • 8.0.0
Manual Chapter
Before you install or upgrade BIG-IQ , it's important to take inventory of the status of the running daemons. After you upgrade, you can verify the daemons' state, and make any necessary modifications. To view the daemons, type the following command in the BIG-IQ command line:
admin@(ip-10-1-1-4)(cfg-sync Standalone)(Active)(/Common)(tmos)# show /sys service
For further information about the daemons that run on BIG-IQ, refer to: https://support.f5.com/csp/article/K14736
