Updated Date: 07/07/2026
Creating and scheduling Analytics reports
Export the Analytics data found in the dashboards found in the Monitoring tab and in the application service dashboards. This allows you to create an audit of your system’s device health, traffic, application throughput, and protection events. You can schedule Analytics reports to be sent to one of more email addresses periodically.
Important: Analytics data includes dashboards that receive traffic and service module statistics from Application Visibility and Reporting (AVR). The Access module and dashboards that are supplemented by AVR (e.g. L7 Dashboard, Bot Traffic Summary, and DDoS Protection Summary) are not eligible for statistics reports. For more information about Access reporting, see Access Reporting and Statistics.
The reports that are available depend on the modules installed on your system, and how the system is configured. In the report, you can select which dimensions and metrics to export, and customize how often certain data is exported to PDF. Certain data, such as geomaps and top reported metric lists are not included in the report.
