Updated Date: 07/07/2026
Review reporting schedules and statuses
You must create a reporting schedule to manage reports.
Manage your statistics reporting schedules, or manually download reports currently saved on the system.
Go to Monitoring > REPORTING > Scheduled Reports.
The screen displays a list of report schedules. Reports that have completed their the date of their cycle are marked as Expired in the End Date column.
To modify a schedule’s settings select the check box next to the schedule’s row and click Edit.
The Edit Scheduler settings are displayed. Once you change the settings, click Save & Close to update the scheduler.
To delete a reporting schedule, select the check box next to one or more schedule rows and click Delete.
To confirm the schedule and its filter metadata’s deletion, click Delete.
To view a list of reports created by a schedule, and details of each report, click the name of the schedule.
To remove a report the system ends its scheduled retention, select the check box next to one or more report rows and click Delete.
The report retention expiration date is shown in the Valid Until column.
To download a PDF report to your local system, select the check box next to the report row and click Download.
It is recommended to only download reports listed as COMPLETED under the Status column.
