Manual : About Basic Device Management
Applies To:
  • BIG-IQ Centralized Management
    8.4.0
After you add BIG-IP devices to BIG-IQ Centralized Management and discover and import their services, you can start managing those devices.
Using the device list (go to Devices > BIG-IP DEVICES) you can view, filter and sort your discovered BIG-IP devices. You can also view details about the managed device, such as:
  • Status - whether your device is active and running or is experiencing connectivity issues.
  • Health - This is based on performance thresholds for CPU, memory, and disk space usage
  • Device name (hostname)
  • Type - the physical or logical BIG-IP device setup. This can include configurations such as hardware, BIG-IP virtual edition, vCMP etc.
  • IP Address
  • Cluster Display Name (if applicable)
  • Silo (if applicable)
  • Statistics collection status - displays whether this setting was enabled or not for the device
  • Data Collection Device
  • Stats Services- the service modules that have statistics collection enabled
  • The last statistics collection period
From this screen you can also perform the following tasks:
  • Create an instant backup of the device’s configuration.
  • Change the boot location of the device.
  • Edit cluster properties.
  • Log directly into the device from BIG-IQ.
  • Reboot the device from BIG-IQ.
  • Access details about the health of the device.
  • Access statistics for the device (if applicable).
  • Access services licensed for the device.
