Manual : Add A BIG-IP Device To The BIG-IQ Inventory
Applies To:
  • BIG-IQ Centralized Management
    8.4.0
Before you can add BIG-IP devices to BIG-IQ, keep these things in mind:
  • The BIG-IP devices must be located in your network and running a compatible software version. Refer to https://support.f5.com/csp/article/K14592 for more information.
  • The BIG-IP management address must be open (typically this is on port 22 and 443), or any alternative IP address. Ports 22 and 443 and the management IP address are open by default on BIG-IQ.
  • The BIG-IQ you are discovering BIG-IP devices from must be using local authentication. You cannot discover BIG-IP devices from remotely-authenticated BIG-IQ because that requires a token.
Note: A BIG-IP device running versions 10.2.0 - 12.0.x is considered a legacy device, and cannot be added to the BIG-IQ system’s inventory for management. Although version 12.1.x is supported, its features are limited, and it is recommended to upgrade to version 13.0 or later. If you were managing a legacy device in a previous version of BIG-IQ and upgrade, the legacy device displays as impaired with a yellow triangle next to it in the BIG-IP Devices inventory. To manage it, you must upgrade it to version 12.1.0 or later. For instructions, refer to the section titled, Upgrading a Legacy Device.
You add a BIG-IP device to BIG-IQ so you can discover and import its services, such as LTM, AFM, and so forth. After you discover and import a device’s services, you can start managing it. This procedure allows you to add a single BIG-IP device.
Note: If you would prefer to add several BIG-IP devices at once and handle all object conflicts the same way, select the Add multiple BIG-IP devices option.
  1. On the left, click BIG-IP DEVICES.
  2. Click the Add Device(s) button.
  3. For the Discovery Type setting, select Add a single BIG-IP device and discover and import services in a separate step.
  4. For IP Address, type the IPv4 or IPv6 address of the device.
  5. In the Port box, type the management port for this BIG-IP device.
    The port number must be between 4 and 65535. In many cases, it’s the default port 443.
    Note: Chrome and Safari browsers don’t allow access to web applications running on port 65535. So if you use port 65535 as the management port, you won’t be able to access the BIG-IP device’s interface from BIG-IQ when using Chrome or Safari. You can still discover and manage BIG-IP devices that are using port 65535.
  6. If this device is part of a DSC group, for the Cluster Display Name setting, specify how to handle it:
    • For an existing DSC group, select Use Existing from the list, and then select the name of the DSC group from the next list.
    • To create a new DSC group, select Create New from the list, and type a name in the field. For BIG-IQ to properly associate the devices in the same DSC group, the Cluster Display Name must be the same for all members in a group.
    There can be up to eight members in a DSC group.
    Important: For BIG-IP devices with ASM services, you can only add five devices at a time. If the BIG-IP device(s) provisioned with ASM is part of a DSC cluster, that device must also be a member of a sync-only device group, and ASM synchronization must be enabled for the device group. Without these DSC group settings, deploying changes to the ASM device can cause the cluster to get out of sync. For more information see https://support.f5.com/csp/article/K12200102, or the ASM Implementations chapter Automatically Synchronizing Application Security Configurations on support.f5.com.
  7. If this device is configured in a DSC group or you are creating a new DSC group, for the Cluster Properties, specify how to handle it:
    • Initiate BIG-IP DSC sync when deploying configuration changes (Recommended): Select this option if you want this device to automatically synchronize configuration changes with other members in the DSC.
    • Allow deployment when DSC configured devices have changes pending ( Not Recommended): Select this option if you want to deploy changes to this device even if there are changes pending for devices in the DSC group.
      Note: This option is not recommended, because it can lead to unpredictable results.
    • Ignore BIG-IP DSC sync when deploying configuration changes: Select this option if you want to manually synchronize configurations changes between members in the DSC group.
  8. Click the Add button at the bottom of the screen.
    The BIG-IQ system opens communication to the BIG-IP device, and checks the BIG-IP device framework.
    Note: The BIG-IQ system can properly manage a BIG-IP device only if the BIG-IP device is running a compatible version of the REST framework.
  9. Click the Discover & Import button at the bottom of the screen.
  10. To centrally manage this device’s configurations for licensed services, select the check box next to each service you want to discover.
    You can select other service configurations after you add the BIG-IP device to the inventory.
You can now discover the services for this device, and manage any differences for shared objects (on an object-by-object basis) between the BIG-IQ system and the BIG-IP device(s) during import.
