Updated Date: 07/07/2026
Before you add a BIG-IP to BIG-IQ for management
Before you can add BIG-IP devices to BIG-IQ, keep these things in mind:
The BIG-IP devices must be located in your network and running a compatible software version. Refer to https://support.f5.com/csp/article/K14592 for more information.
The BIG-IP management address must be open (typically this is on port 22 and 443), or any alternative IP address. Ports 22 and 443 and the management IP address are open by default on BIG-IQ.
The BIG-IQ you are discovering BIG-IP devices from must be using local authentication. You cannot discover BIG-IP devices from remotely-authenticated BIG-IQ because that requires a token.
Note: A BIG-IP device running versions 10.2.0 - 12.0.x is considered a legacy device, and cannot be added to the BIG-IQ system’s inventory for management. Although version 12.1.x is supported, its features are limited, and it is recommended to upgrade to version 13.0 or later. If you were managing a legacy device in a previous version of BIG-IQ and upgrade, the legacy device displays as impaired with a yellow triangle next to it in the BIG-IP Devices inventory. To manage it, you must upgrade it to version 12.1.0 or later. For instructions, refer to the section titled, Upgrading a Legacy Device.
Important: For BIG-IP devices with ASM services, you can only add five devices at a time. If the BIG-IP device(s) provisioned with ASM is part of a DSC cluster, that device must also be a member of a sync-only device group, and ASM synchronization must be enabled for the device group. Without these DSC group settings, deploying changes to the ASM device can cause the cluster to get out of sync. For more information see https://support.f5.com/csp/article/K12200102, or the ASM Implementations chapter Automatically Synchronizing Application Security Configurations on support.f5.com.
Important: You cannot add multiple BIG-IP devices with SSLO services. You must add those BIG-IP devices individually. After you import a BIG-IP device with SSLO services, make future configuration changes only from BIG-IQ. If you make a change to the SSLO service configuration directly on the BIG-IP device, you cannot re-discover or re-import that device.
