Manual Chapter :
Enable advanced shell terminal access on managed devices
Applies To:
Show Versions
BIG-IQ Centralized Management
- 8.4.0
To use BIG-IQ to update the geolocation database on your managed BIG-IP devices, Advanced Shell terminal access must be enabled on the devices. Perform this task for each BIG-IP to which you plan to send geolocation update packages.
- On the BIG-IP device, click .BIG-IP displays a list of current users defined on this BIG-IP.
- Under User Name, click the user name that was used to discover this device.In most cases, the user nameadminis used for device discovery.
- For Terminal Access, selectAdvanced shell.
- ClickUpdateto complete this task.
This BIG-IP device can now accept geolocation updates from the BIG-IQ.
