Manual Chapter :
About configuration templates
Applies To:
Show Versions
BIG-IQ Centralized Management
- 8.4.0
BIG-IQ can manage multiple devices simultaneously. These devices can be
located in several data centers that may be located in many different locations. To help
you easily manage required configuration changes to DNS, NTP, SMTP, and Syslog for a large
number of devices, you can use configuration templates.
To start, you create a configuration template, then deploy that template to certain
devices. This can save a significant amount of time because you are not required to log in to
each device individually to make configuration changes.
