Manual Chapter :
Deploying a configuration template to managed devices
Applies To:
Show Versions
BIG-IQ Centralized Management
- 8.4.0
You must create a configuration
template before you can deploy it to a managed device.
saves time when you want to make a similar change to several managed BIG-IP devices.
- At the top of the screen, clickConfiguration.
- On the left, click .
- Click theCreatebutton.
- From theConfig Templatelist, select the template you want to deploy.
- In theDeployment Namefield, specify the name for this configuration template deployment.
- From theAvailablelist, click the devices you want to deploy the configuration template to, and then click->to move it to theIncludedlist.
- Click theNextbutton at the bottom of the screen, navigating to the components required for this template, and specifying the configuration.
- Click theDeploybutton.
BIG-IQ applies this configuration to the specified BIG-IP
devices.
