Manual Chapter :
Create a script to run on your managed devices
Applies To:
Show Versions
BIG-IQ Centralized Management
- 8.4.0
BIG-IP version 13.0 has Advanced Shell (bash) and Traffic Management Shell (tmsh) access disabled by default. BIG-IQ supports only requests from users with bash access, so before you can run scripts on BIG-IP version 13.0, you must enable it. For more information, refer to article K16413: Enabling Advanced Shell or tmsh access for BIG-IQ user accounts on AskF5 at: https://support.f5.com/csp/article/K16413.
From
BIG-IQ Centralized Management, you can create scripts to run on your managed devices.
For example, you could create a script that changes the syslog settings for multiple
devices. Not only does this ensure those devices all have the same configuration, it
saves you time too, because you don't have to log in to and configure each device
individually. You can save the scripts you create so you can run them in the future and
you can share them with your colleagues.
- At the top of the screen, clickConfiguration.
- On the left, click .
- In theNameandDescriptionfields, type a name and optional description to identify this script.
- Into theScriptfield, type the commands or cut and paste a script you have saved elsewhere.
- Click theSave & Closebutton.
The new script is added to the list on the Scripts screen.
