Manual Chapter :
Run a script on BIG-IP devices
Applies To:
Show Versions
BIG-IQ Centralized Management
- 8.4.0
After you create a script, you can run it from BIG-IQ Centralized Management.
Run a script to quickly apply the same changes to several of your managed BIG-IP devices without requiring individual logins.
- At the top of the screen, clickConfiguration.
- On the left, click .
- Select the check box next to the script you want to run, and then click theRunbutton near the top of the screen.
- In theNameandDescriptionfields, type a name and an optional description to identify this task.
- For theTimeoutsetting, specify the number of seconds for BIG-IQ to attempt running the script before canceling the task.
- For theDevicessetting, move the devices you want to run this script on from theAvailablelist to theSelectedlist.
- Click theRunbutton at the bottom of the screen.
You can monitor and view the results of the task on the Execution Log screen.
