Manual Chapter :
Upgrade SSLO RPM versions
Applies To:
Show Versions
BIG-IQ Centralized Management
- 8.4.0
Before you begin the process of installing an SSLO RPM upgrade, obtain the SSLO RPM file you are interested in installing to the managed devices by navigating to f5.downloads.com and downloading the relevant files to your local machine.
You may use BIG-IQ Centralized Management to upgrade your SSL Orchestrator RPM version from within BIG-IQ.
- From BIG-IQ, navigate to .
- Select the checkbox next to the device or devices you are interested in installing an upgrade SSLO RPM version to.
- SelectUpgrade SSL Orchestrator.A popup will appear.
- Click theChoose filebutton and select an RPM file from your local machine.
- Once you have uploaded the file, selectUpgrade.
Your managed BIG-IP device will be upgraded to your desired SSLO RPM version.
