Manual Chapter :
Setting Up Secure Remote Logging
Applies To:
Show Versions
BIG-IP APM
- 16.0.0, 15.1.1, 15.1.0, 15.0.1, 15.0.0
BIG-IP Analytics
BIG-IP LTM
BIG-IP AFM
BIG-IP PEM
BIG-IP DNS
BIG-IP ASM
Introduction to secure logging configuration
The BIG-IP® system can securely log messages using Transport Layer
Security (TLS) encryption to a secure syslog server that resides on a shared, external network.
This implementation describes a sample configuration consisting of two BIG-IP
systems,
in a Device Service Clustering (DSC®) Sync-Only or Sync-Failover device
group,
that encrypt log messages using a local virtual
server before sending
the messages on to the remote secure syslog server.
In the example, the BIG-IP systems (
bigip1.syslog.secure.com
and
bigip2.syslog.secure.com
) and the secure syslog server
(server.syslog.secure.com
) mutually authenticate each other using X.509
certificates and keys on their TLS connections. This certificate validation requires a dedicated
certificate for each BIG-IP system's logging interface (the self IP address on the logging VLAN
for that BIG-IP system) and a certificate for the secure syslog server. In this sample
configuration, all three certificates are signed by the same Certificate Authority (CA) and each
have the same CA certificate bundle installed, to be used for X.509 certificate validation. The
configuration is based on the assumption that you have configured an external Domain Name System
(DNS) server with forward and reverse DNS entries for the names and IP addresses used in the
X.509 certificate authentication.In most configurations, the shared, external network should be deployed as a dedicated VLAN
connecting only the BIG-IP systems and secure syslog server, due to the potential for
high-bandwidth logging from the High Speed Logging (HSL) subsystem.
Some BIG-IP software versions
do not include the HSL subsystem. If the BIG-IP systems in your device group do not include
HSL, you can still configure secure logging to a remote syslog server. In this case, as long
as you can configure the local syslog service to direct messages to the local log encrypting
virtual server, the secure logging configuration supports the encrypting of messages from the
local syslog service.
Sample secure logging configuration
This illustration shows an example of the entire secure logging configuration. The logging
traffic proceeds from top to bottom in the illustration.
In the example:
- Each BIG-IP system has one or more HSL filters directing certain kinds of log messages to an HSL destination. The HSL destination forwards the messages to both the local syslog server (for local log retention, in case the external syslog server is unreachable), and an HSL syslog destination, whose purpose is to add the timestamp and other information expected by RFC5424-compliant syslog servers. The HSL syslog destination then sends the decorated log messages to an HSL pool destination, which directs them to the local syslog encryptor pool containing the IP address of a local encrypting virtual server.
- The two BIG-IP systems include identically-configured local syslog encrypting virtual servers. The virtual servers are configured using a non-floating IP address on a private VLAN that is internal to each BIG-IP system, with no external interfaces attached. This VLAN exists solely to provide a private communications link between the local syslog encryptor pool, the local syslog server, and the local encrypting virtual server. For messages that are not currently processed by the HSL subsystem, the local syslog server uses this VLAN to send selected messages directly to the local encrypting virtual server, to be encrypted and sent on to the remote secure syslog server.
- The local encrypting virtual server is configured with a Server SSL profile for the purpose of sending the BIG-IP system's client certificate to the server for X.509 validation, as well as for validating the server's X.509 certificate using a locally-installed CA certificate bundle. Once authenticated and connected to the server listed in the remote secure syslog server pool, the local syslog encrypting virtual server sends the outbound encrypted syslog messages to the remote syslog server. The outbound TCP sessions are retained for subsequent syslog messages until the TCP timeout on the virtual server expires; then the next syslog message initiates a new TCP session.
The result is that when the high speed logging subsystem or the standard syslog service of
either BIG-IP system sends TCP syslog traffic, the messages are forwarded to the remote syslog
server over an authenticated and encrypted, secure channel.
In this implementation, you
must configure the objects shown in the illustration by starting with those at the bottom and
then proceeding toward the top. This ensures that configuration objects are available when needed
to configure other objects.
Prerequisite tasks
Before configuring secure logging, you must perform these tasks on the BIG-IP systems in the configuration.
Task | Description |
Create a device group. | The Device Service Clustering (DSC®) device group must contain the
BIG-IP systems as members. You perform this task on only one device in
the device group. |
Enable Automatic Sync on the device group. | Enabling automatic sync for the device group ensures that every change you make to a
BIG-IP system is internally propagated to all device group members. In most cases, this
eliminates the need to manually sync configuration changes to the peer device. You perform
this task on only one device in the device group, and the change is propagated to the other
device. |
Assign fully-qualified domain names (FQDNs). | Each BIG-IP system in the device group, and the remote, secure syslog server, must have
a unique fully-qualified domain name (FQDN). In our example, these FQDNs are:
bigip1.syslog.secure.com ,
bigip2.syslog.secure.com , and
server.syslog.secure.com . |
Specify the DNS name server. | You must specify an external Domain Name System (DNS) server with forward and reverse
DNS entries for the names and IP addresses used in the X.509 certificate authentication. Once
configured, the DNS server resolves the FQDN used in the X.509 certificate for each device's
secure logging configuration to the IP address on the logging VLAN for that device. You must
perform this task on each BIG-IP device in the device group. |
About X.509 certificates for secure logging
One of the required elements of the secure logging configuration is the mutual validation of
the X.509 certificate for each device in the configuration (that is, each BIG-IP device, as well as the secure logging server). Each device must have a valid X.509
certificate and key assigned, where the
Common Name
attribute of the certificate
resolves to the Fully Qualified Domain Name (FQDN) of that device's IP address on the shared
secure logging VLAN. For the certificate on each of the two BIG-IP systems, this IP address is a self IP address.
For the certificate of the secure, remote syslog server, this IP address is the IP address of
that server.For either BIG-IP system to successfully validate the certificate of the other device, all
X.509 certificates must be signed by a parent certificate authority (CA) whose certificate chain
is included in the certificate bundle referenced in the SSL profile of each of the BIG-IP
encrypting virtual servers. The CA's certificate chain must also be included in the certificate
bundle of the secure syslog server's configuration.
Importing an X.509 certificate, key, and CA bundle
To ensure that secure logging operates successfully, you must import the required
certificate, key, and CA bundle to the local BIG-IP
device.
Perform this task on each device in the device group.
- On the Main tab, click.The Device Certificate screen opens.
- ClickImport.
- From theImport Typelist, selectCertificate and Key.
- For theCertificate Sourcesetting, selectUpload Fileand browse to select the certificate signed by the CA server.
- For theKey Sourcesetting, selectUpload Fileand browse to select the device key file.
- ClickImport.
Creating a pool containing the syslog server
On either of the BIG-IP systems in the device group, use the
TMOS Shell (
tmsh
) to create a pool containing the IP address and
TCP port number of the logging network interface on the remote syslog server.- At thetmshprompt, create a pool containing a remote syslog server. For example:create ltm pool pool_remote_secure_syslog { members replace-all-with { 192.0.2.10:6514 { address 192.0.2.10 } } monitor tcp_half_open }In this example,192.0.2.10:6514represents the IP address of the remote syslog server.
- Save the configuration by typingsave /sys config.
Configuring system
BIG-IP 1
Before you perform this task, verify that you have created a one-member pool containing
The main goal of this task is to create a virtual server and
associated objects on one of the two BIG-IP systems (in the example, a system named
) that encrypts server-side traffic
destined for the remote syslog server. This encrypting virtual server is on an
internal, private VLAN and is associated with a non-floating virtual address, using
the local BIG-IP system’s key and certificate. You also use this task to create a
shared, external VLAN and an associated self IP address. This is the VLAN with which
the remote syslog server is associated.The encrypting virtual server that you create has the same
destination address and port as the encrypting virtual server that you create on the
peer system (in the example,
). Also, the virtual server targets the
same pool as the peer system (the pool containing the remote syslog server).Perform all steps in this task at the
tmsh
prompt.- Create an SSL Server profile to encrypt traffic destined for the syslog server pool. For example:create ltm profile server-ssl profile_serverssl_syslog-1 { ca-file F5secureLoggingCA_bundle.crt cert b3-1.logging.f5cc.com.crt defaults-from serverssl key b3-1.logging.f5cc.com.key peer-cert-mode require }In this example,profile_serverssl_syslog-1represents the name of the Server SSL profile.The certificate bundle that you specify must include the certificate chain of the certificate authority.
- Create a VLAN on the private, internal network, with no interfaces assigned. For example:create net vlan vlan_securelog.
- Create a self IP address in the traffic grouptraffic-group-local-onlyand associate it with VLANvlan_securelog. For example:create net self 203.0.113.1/24 vlan vlan_securelog.The IP address that you specify must be a non-routable address and must be identical on all BIG-IP systems in the configuration.
- Create a non-floating virtual address on the private, internal network. For example:create ltm virtual-address 203.0.113.100 traffic-group traffic-group-local-only auto-delete falseYou must usetmshto create the virtual address, and you must create the virtual address prior to creating the associated virtual server. Also, the IP address you specify must be the same virtual address that you specify on the peer BIG-IP system.
- Create a virtual server network for the virtual address, assigning the pool, SSL Server profile, and private VLAN. For example:create ltm virtual vs_secure_syslog_target-1 { destination 203.0.113.100:514 ip-protocol tcp pool pool_remote_secure_syslog profiles replace-all-with { profile_serverssl_syslog-1 tcp } vlans replace-all-with { vlan_securelog } vlans-enabledIn this example,vs_secure_syslog_target-1represents the name of the virtual server, and the destination IP address is203.0.113.100:514. The destination IP address and port that you specify must be the same destination IP address and port that you specify on the peer BIG-IP system.
- Create a VLAN on the shared, external network with all appropriate BIG-IP interfaces assigned. For example:create net vlan vlan_logging { tag 4089 interfaces add { 1.1 {tagged} } }.
- Create a self IP address in the traffic grouptraffic-group-local-onlyand associate it with VLANvlan_logging. For example:create net self 192.0.2.100 vlan vlan_logging.
After you perform this task, system
contains a virtual server that references a
Server SSL profile, a private, internal VLAN, and the pool containing the remote syslog
server. The virtual server destination IP address and port match those of the virtual
server on system bigip2.syslog.secure.com
. System bigip1.syslog.secure.com
also
contains a shared, external VLAN with an associated self IP address.Configuring system
BIG-IP 2
the remote syslog server is associated.The encrypting virtual server has the same destination address and
port as the encrypting virtual server that you create on the peer system (in the
example,
tmsh
prompt.- Create an SSL Server profile to encrypt traffic destined for the syslog server pool. For example:create ltm profile server-ssl profile_serverssl_syslog-2 { ca-file F5secureLoggingCA_bundle.crt cert b3-2.logging.f5cc.com.crt defaults-from serverssl key b3-2.logging.f5cc.com.key peer-cert-mode require }In this example,profile_serverssl_syslog-2represents the name of the Server SSL profile.The certificate bundle that you specify must include the certificate chain of the certificate authority.
- Create a self IP address in the traffic grouptraffic-group-local-onlyand associate it with the VLAN. For example:create net self 203.0.113.1/24 vlan vlan_securelog.The IP address that you specify must be a non-routable address and must be identical on all BIG-IP systems in the configuration.
- Create a virtual server for the virtual address, assigning the pool, SSL Server profile, and private VLAN. For example:create ltm virtual vs_secure_syslog_target-2 { destination 203.0.113.100:514 ip-protocol tcp pool pool_remote_secure_syslog profiles replace-all-with { profile_serverssl_syslog-2 tcp } vlans replace-all-with { vlan_securelog } vlans-enabledIn this example,vs_secure_syslog_target-2represents the name of the virtual server, and the destination IP address is203.0.113.100:514. The destination IP address and port that you specify must be the same destination IP address and port that you specify on the peer BIG-IP system.
- Create a self IP address in the traffic grouptraffic-group-local-onlyand associate it with VLANvlan_logging. For example:create net self 192.0.2.200 vlan vlan_logging.
server on system bigip1.syslog.secure.com
. System bigip2.syslog.secure.com
also
contains a shared, external VLAN with an associated self IP address.Modifying the local syslog server
Because some of the older audit log messages do not use the high-speed logging (HSL)
system, you must modify the BIG-IP system’s local syslog
server to send audit data to one of the encrypting virtual servers.
You can perform this task on either one of the BIG-IP systems in the device group.
- At thetmshprompt, modify the syslog server to create a destination that targets the IP address and port number of the local encrypting virtual server. For example:modify sys syslog { include " destination d_to_secure_syslog { tcp( 203.0.113.100 port(514)); }; log { source(s_syslog_pipe); filter(f_audit); destination(d_to_secure_syslog); }; log { source(s_syslog_pipe); filter(f_authpriv); destination(d_to_secure_syslog); }; log { source(s_syslog_pipe); filter(f_apm); destination(d_to_secure_syslog); }; log { source(s_syslog_pipe); filter(f_sso); destination(d_to_secure_syslog); }; " }In this example,d_to_secure_syslogrepresents the name of the HSL destination, which targets the local syslog destination, which targets the local encrypting virtual server's destination IP address and port203.0.113.100:514.
Creating a pool for the local encrypting virtual server
For the High-Speed Logging (HSL) system, you must create a pool containing the IP
address and TCP port of the encrypting virtual servers. This pool becomes the target
pool for the HSL pool destination.
- At thetmshprompt, create a pool with the address and port of the encrypting virtual servers as the pool member. For example:create ltm pool pool_syslog_encryptor { members replace-all-with { 203.0.113.100:514 { address 203.0.113.100 } } monitor tcp_half_open }In this example,pool_syslog_encryptorrepresents the name of the pool that contains pool member203.0.113.100:514.
Creating an HSL destination targeting the encrypting pool
You must create a
remote high-speed log
local encrypting syslog pool. This pool contains a single pool member, which is the
destination IP address and port of the encrypting virtual server on each BIG-IP system.You can perform this task on either one of the BIG-IP systems in the
device group.
- At thetmshprompt, create aremote high-speed logdestination. For example:create sys log-config destination remote-high-speed-log hsldest_to_encryptor { pool-name pool_syslog_encryptor }In this example, aremote high-speed logdestination namedhsldest_to_encryptortargets the local encrypting syslog pool namedpool_syslog_encryptor.
Creating an RFC 5424 (syslog) HSL destination
To ensure that the syslog timestamp and other identifying information is included
with each log message, you must create a formatted
remote-syslog
destination that targets the remote high-speed log
destination.You can perform this task on either one of the
- At thetmshprompt, create aremote-syslogdestination.create sys log-config destination remote-syslog hsldest_syslog { format rfc5424 remote-high-speed-log hsldest_to_encryptor }In this example, a formattedremote-syslogdestination namedhsldest_syslogtargets theremote high-speed logdestination namedhsldest_to_encryptor.
Creating an HSL publisher
You must create a high-speed logging (HSL) publisher, which sends the selected audit
logging messages to both the local syslog server (for local logging) and the
formatted
remote-syslog
- At thetmshprompt, create the HSL publisher. For example::create sys log-config publisher hslpub_secure_remote_syslog { destinations replace-all-with { hsldest_syslog local-syslog } }In this example, a publisher namedhslpub_secure_remote_syslogtargets the local syslog server namedlocal-syslog, as well as the formattedremote-syslogdestination namedhsldest_syslog.
Creating HSL filters for log messages
You must create high-speed-logging (HSL) filters to select log messages and send the
messages through the chain to the secure remote syslog server. Types of filters you
can create are packet, SSL,
tamd
, and tmsh
- At thetmshprompt, create a packet filter. For example:Create sys log-config filter hslfilter_packet_filter { publisher hslpub_secure_remote_syslog source packet_filter }
- Create an SSL filter. For example:create sys log-config filter hslfilter_ssl { publisher hslpub_secure_remote_syslog source ssl }
- Create atamdfilter. For example:create sys log-config filter hslfilter_tamd { publisher hslpub_secure_remote_syslog source tamd }
- Create atmshfilter. For example:create sys log-config filter hslfilter_tmsh { publisher hslpub_secure_remote_syslog source tmsh }
Configuring APM
logging (APM systems only)
If you are testing a system on which you have provisioned BIG-IP
Access Policy Manager (APM), (also known as ADC-AP), you must enable APM syslog
logging and create additional high-speed logging (HSL) filters.
group.
- At thetmshprompt, enable syslog logging for BIG-IP Access Policy Manager (APM):modify sys db log.access.syslog value enable
- Create an APM filter. For example:create sys log-config filter remote_apm_filter { level info publisher hslpub_secure_remote_syslog source accesscontrol }
- Create an access control filter. For example:create sys log-config filter remote_acl_filter { level info publisher hslpub_secure_remote_syslog source apmacl }
- Create a filter for single sign-on. For example:create sys log-config filter remote_sso_filter { level info publisher hslpub_secure_remote_syslog source sso }
Saving the secure logging configuration
After performing all tasks to configure secure logging on the BIG-IP system, you must save the full secure logging configuration.
- At thetmshprompt, save the configuration by typingsave /sys config.
