Manual Chapter : Common element concepts
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.0, 15.1.2, 15.1.0, 15.0.1, 15.0.0, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0
Manual Chapter
Auto-Connect
Starts a secure access connection as it is needed. This option uses the DNS suffix information defined in the connectivity profile to determine when the computer is on a defined local network. When the computer is not on a defined local network, the secure access connection starts. When the computer is on a local network, the client disconnects, but remains active in the system tray. This option does not display if DNS suffixes were not defined.
Connect
Starts and maintains a secure access connection at all times, regardless of the network location.
Disconnect
Stops an active secure access connection, and prevents the client from connecting again until a user clicks
Connect
or
Auto-Connect
