Manual Chapter : Disconnecting from the VPN
Applies To:
  • BIG-IP APM
    17.1.0, 17.0.0, 16.1.6, 16.1.5, 16.1.4, 16.1.3, 16.1.2, 16.1.1, 16.1.0, 16.0.1, 16.0.0, 15.1.9, 15.1.8, 15.1.7, 15.1.6, 15.1.5, 15.1.4, 15.1.3, 15.1.2, 15.1.1, 15.1.0, 15.0.1, 15.0.0, 14.1.5, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.5, 13.1.4, 13.1.3, 13.1.1, 13.1.0
You can disconnect from the VPN in the following two ways:
  1. From the status menu, click the Edge Client icon and then click Turn VPN Off. When you disconnect from the VPN, your session remains active. You can reconnect by clicking Turn VPN On.
  2. From the status menu, click the Edge Client icon and then click Quit BIG-IP Edge Client. When you quit the application, your session ends, you are logged out, and disconnected from the VPN.
