Updated Date: 07/07/2026
Edge Client Status Messages
This section describes the different messages displayed on the BIG-IP Edge Client icon menu.
| VPN Status Message | Description |
| On | You are connected to the VPN and have an active login session. |
| Off | You are logged out and disconnected from the VPN. To connect, click Turn VPN On. |
| Connecting | The Edge Client is actively working to establish a connection to the VPN servers. Make sure your network connection is working. |
| Reconnecting | The Edge Client is reconnecting to the VPN servers. |
| Off, User: Logged In | You are disconnected from the VPN but have an active login session. To connect, click Turn VPN On. |
| In Enterprise Network | You are connected to the LAN and have an active login session. |
| Server Not Configured | The Edge Client is unable to establish a connection to the VPN Servers. Contact your network administrator. |
| Upgrading… | The Edge Client is updating to the latest version. |
| No Connectivity | There is no network connectivity between the client and the server. Verify the network connection. |
