Updated Date: 07/07/2026
What's New in 7.1.9
The newly designed Edge Client 7.1.9 includes enhanced user experience, seamless secure connectivity, status notifications, and much more. Let’s take a look at some of the new changes to BIG-IP Edge Client.
- New and improved UI
- Temporarily disconnect from the VPN without logging out
- Improved status notifications
- Auto-Connect moved to Preferences
The first thing that you will notice in the updated version of Edge Client is its new status icons and the absence of the main window. After launch, the Edge Client for macOS displays a welcome screen. Subsequent launches display a splash screen, which minimizes to the status menu on the right end of the menu bar. You can quickly access connection options by clicking on the Edge Client icon.
Use the Manage VPN Servers popup screen to add, edit, and delete servers. The graph displaying traffic throughput is no longer available and has been removed.
BIG-IP Edge Client’s Turn VPN Off option now temporarily disconnects from the VPN without logging you out. The login session remains active and allows you to establish a VPN without the need for re-authentication when you choose to Turn VPN On. This feature may be used to:
- Temporarily disconnect from the VPN to either print something on a printer or perform other tasks on a remote network without logging out.
- Establish a VPN quickly in high latency networks such as airplanes without going through the authentication flow.
- Switch between the corporate wifi network and public wifi network easily without re-authentication.
Edge Client now displays alerts instead of growl notifications to provide timely information about an error or an auto-update. Alert appears in the top-right corner of the screen and the Notifications pane, accessed by clicking the Notification Center icon.
Notifications are enabled by default. Use the Preferences popup screen to disable notifications.
Edge Client’s Auto-Connect lets you start a secure access connection as needed. You can enable Auto-Connect when your administrator configures the Network Location Awareness. Auto-Connect is disabled by default.
To enable auto-connect:
- From the status menu, click the Edge Client icon and then click Preferences.
- Select the Auto-Connect check box.
When the computer is on an enterprise network, the client disconnects and remains active in the status menu. In this case, the Edge Client icon menu displays the message In Enterprise Network, and the Turn VPN On option is not available.
When the computer moves outside the enterprise network, the login session remains active, and the VPN connection establishes automatically without the need for re-authentication. Authentication is required only when a new session is created.
