Manual Chapter : Disconnecting from the VPN
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.1, 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0
Manual Chapter
You can disconnect from the VPN in the following two ways:
  1. From the status menu, click the Edge Client icon and then click
    Turn VPN Off
    . When you disconnect from the VPN, your session remains active. You can reconnect by clicking
    Turn VPN On
  2. From the status menu, click the Edge Client icon and then click
    Quit BIG-IP Edge Client
    . When you quit the application, your session ends, you are logged out, and disconnected from the VPN.
