Manual Chapter : Edge Client Status Messages
Applies To:
Show Versions Show Versions
BIG-IP APM
  • 16.0.1, 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0
Manual Chapter
This section describes the different messages displayed on the BIG-IP Edge Client icon menu.
VPN Status Message
Description
On
You are connected to the VPN and have an active login session.
Off
You are logged out and disconnected from the VPN. To connect, click
Turn VPN On
Connecting
The Edge Client is actively working to establish a connection to the VPN servers. Make sure your network connection is working.
Reconnecting
The Edge Client is reconnecting to the VPN servers.
Off, User: Logged In
You are disconnected from the VPN but have an active login session. To connect, click
Turn VPN On
In Enterprise Network
You are connected to the LAN and have an active login session.
Server Not Configured
The Edge Client is unable to establish a connection to the VPN Servers. Contact your network administrator.
Upgrading...
The Edge Client is updating to the latest version.
No Connectivity
There is no network connectivity between the client and the server. Verify the network connection.
