Manual Chapter :
What's New in 7.1.9
Applies To:
Show Versions
BIG-IP APM
- 16.0.1, 16.0.0, 15.1.0, 15.0.1, 15.0.0, 14.1.4, 14.1.3, 14.1.2, 14.1.0, 14.0.1, 14.0.0, 13.1.3, 13.1.1, 13.1.0
What's New in 7.1.9
The Edge Client 7.1.9 includes enhanced user experience, seamless secure
connectivity, status notifications, and much more. Some of the new changes are:
- New and improved UI
- Temporarily disconnect from the VPN without logging out
- Improved status notifications
- Auto-Connect moved to Preferences
New and improved UI
The first thing that you will notice in the updated version of Edge Client is its new status
icons and the absence of the main window. After launch, the Edge Client for macOS displays a
welcome screen. Subsequent launches display a splash screen, which minimizes to the status menu
on the right end of the menu bar. You can quickly access connection options by clicking on the
Edge Client icon.
Use the
Manage VPN Servers
popup screen to add, edit, and delete
servers. The graph displaying traffic throughput is no longer available and has been
removed.Edge Client icon menu
BIG-IP Edge Client's
Turn VPN Off
option now temporarily disconnects
from the VPN without logging you out. The login session remains active and allows you to
establish a VPN without the need for re-authentication when you choose to Turn VPN
On
. This feature may be used to: - Temporarily disconnect from the VPN to either print something on a printer or perform other tasks on a remote network without logging out.
- Establish a VPN quickly in high latency networks such as airplanes without going through the authentication flow.
- Switch between the corporate wifi network and public wifi network easily without re-authentication.
Edge Client now displays alerts instead of growl notifications to provide timely information
about an error or an auto-update. Alert appears in the top-right corner of the screen and the
Notifications pane, accessed by clicking the Notification Center icon.
Edge Client error notification
Notifications are enabled by default. Use the Preferences popup screen to disable
notifications.
Edge Client's Auto-Connect lets you start a secure access connection as
needed. You can enable Auto-Connect when your administrator configures the Network Location
Awareness. Auto-Connect is disabled by default.
Edge Client preferences
To enable auto-connect:
- From the status menu, click the Edge Client icon and then clickPreferences.
- Select theAuto-Connectcheck box.
When the computer is on an enterprise network, the client disconnects and remains active in
the status menu. In this case, the Edge Client icon menu displays the message
In
Enterprise Network
, and the Turn VPN On
option is not
available.When the computer moves outside the enterprise network, the login session remains active, and
the VPN connection establishes automatically without the need for re-authentication.
Authentication is required only when a new session is created.
