Manual Chapter : Additional System Tasks
Applies To:
  • F5OS-A
    1.3.2, 1.3.1, 1.3.0
Service Provider Disaggregation (SP-DAG) is supported on F5 r5000 and r10000 systems.
For information on configuring service provider features for your BIG-IP tenant, see these documents at my.f5.com:
  • BIG-IP Service Provider: Administration
  • BIG-IP Service Provider: Diameter Administration
  • BIG-IP Service Provider: Generic Message Administration
  • BIG-IP Service Provider: Message Routing Administration
  • BIG-IP Service Provider: SIP Administration
You can enable or disable the DAG hash function from the CLI. This enables the use of TEID (tunnel endpoint identifier) instead of the default L4 port mode for DAG hashing. The setting is applied to all tenants running in the system.
  1. Connect using SSH to the management IP address.
  2. Log in to the command line interface (CLI) of the system using an account with admin access.
    When you log in to the system, you are in user (operational) mode.
  3. Change to config mode.
    config
    The CLI prompt changes to include (config).
  4. Configure the DAG hash function.
    system settings dag config gtp-u teid-hash { enabled | disabled }
  5. Commit the configuration changes.
    commit
  6. Return to user (operational) mode.
    end
  7. Verify the DAG hashing configuration.
    appliance-1# show system settings dag
    system settings dag state gtp-u teid-hash enabled
The rSeries system uses an encryption key, also called the primary key, to encrypt and decrypt highly sensitive passphrases contained in the configuration database. You follow a key migration process to set the encryption key on the system to a known value so that same key can be can set on another machine using same passphrase and salting. For more information, see the Migrate system configuration from one system to another section.
You might consider resetting (or rotating) the encryption key periodically on a system for additional security.
  1. Log in to the command line interface (CLI) of the system using an account with admin access.
  2. Change to config mode.
    config
  3. Reset the primary key.
    system aaa primary-key set
  4. Commit the configuration changes.
    commit
The encryption key is reset (or refreshed) on the system.
Before you can migrate the system configuration onto another rSeries system, you must have completed the initial configuration of management IP address on the new system, and it must be in stable running condition. You also must be able to log in to the existing system.
In the case of a Return Material Authorization (RMA) or other situations when aligning multiple systems, you might need to migrate the system configuration from one system (the source) to another one (the destination). Such a migration requires that you set the same encryption key on both systems so that the encrypted elements are moved successfully along with the configuration. You can migrate the system configuration from the CLI.
    config
  3. Set the primary key with the same passphrase on both the source and destination systems.
    system aaa primary-key set passphrase <*known-pass*> confirm-passphrase <*known-pass*> salt <*known-salt*> confirm-salt <*known-salt*>
    Note: Be sure to make note of the salt and passphrase, as these are needed to restore the configuration on a replacement system.
    The system shows a message confirming that key migration has started:
    Key migration is initiated. Use 'show system aaa
    primary-key state status' to get status
  4. Return to user (operational) mode.
    end
  5. Check the status of the primary key on both the source and destination systems.
    show system aaa primary-key state status
    A summary similar to this example displays:
     "COMPLETE Initiated: Thu Dec 2 01:12:34 2021"
  6. Check the primary key hash on both the source and destination systems.
    show system aaa primary-key state hash
    system aaa primary-key state hash YTkPNw5nxY/nqgfyNjdHZUZ
    WD1tfvxNY30+VAbSstzheCnE6Vy6aADftJKrVWY5W5w3UaQeRnwkT0NeFkb5Svg==
    Note: Be sure to make note of the primary key hash, as it is needed to restore the configuration on a replacement system.
  7. On the source system, save the system configuration.
    system database config-backup name <*file-name*>.xml
    System configuration backup files are located in configs/.
  8. Export the configuration backup file from the source system to an HTTPS server.
    file export local-file configs/<*file-name*>.xml remote-file /<file-path>/<*filename*>.xml remote-host <*ip-address*> username root
  9. When prompted, type the password for the remote root account.
  10. Import the configuration backup onto the destination system from the HTTPS server.
    file import local-file configs/backup1.xml remote-file /tmp/backup1.xml remote-host <*ip-address*> username root
  11. When prompted, type the password for the remote root account.
  12. Load the configuration backup onto the destination system.
    system database config-restore name <*filename*>.xml
    If the migration fails for any reason, the system automatically restores the previous configuration.
  13. Reset the primary key with a different password on both the source and destination systems (not required but recommended for security).
The destination system now has the same configuration as the original source system, including a unique encryption key.
Before you can perform a backup and restore, you must disable appliance mode, if it is enabled. There are a number of tasks recommended to perform a complete backup and restore of the rSeries system and tenants on that same system.
For more information, see K50135154: Back up and restore the F5OS-C configuration on a VELOS system.
If you want to move a system configuration from one system to another, you also need to perform a key migration. For more information, see the Migrate system configuration from one system to another section.
You can disable appliance mode on the system from the CLI. While it is recommended that you enable appliance mode most of the time, some tasks, such as restoring the default configuration or running the Setup utility, require use of the root account (which is unavailable in appliance mode).
    config
  3. Check whether the system is in appliance mode:
    show system appliance-mode state
    If appliance mode is enabled, proceed to the next step to disable it. Otherwise, skip the rest of these steps.
  4. Disable appliance mode:
    system appliance-mode config disabled
    commit
    end
To back up the configuration for your tenants, log in to each tenant and back up the configuration using the method recommended for that tenant.
For BIG-IP tenants
Create and save an archive (or UCS file), and then export the UCS backups to an external location. For more information, see the section titled “About managing archives using the Configuration utility” in BIG-IP System: Essentials at my.f5.com.
When the system is configured for your environment, you can log in to the CLI and back up the configuration.
    config
  3. Create a backup of the configuration.
    system database config-backup name backup1.xml
  4. Export the configuration backup file onto an external system for safe keeping.
    file export local-file configs/backup1.xml remote-file /tmp/backup1.xml remote-host 192.51.100.75 username root
    The system requests the password for the remote root account.
    Value for 'password' (<string>): *******
    result File transfer is initiated.(configs/backup1.xml)
You now have a backup of the system configuration that you can restore, if needed.
Be sure that you have a backup of the existing system configuration before you go back to the defaults. You must also disable appliance mode, if it is enabled.
Resetting the configuration to factory defaults from the CLI might be useful if you are testing, performing an RMA, or for any other reason want to restore the system to its initial factory default settings.
Important: Be sure you do this using a console connection because resetting the system to the default values removes the management network.
Warning: This procedure clears all existing configuration and regenerates the default configuration.
  1. Connect to the system using a management console or console server.
    Note: The default baud rate and serial port configuration is 19200/8-N-1.
    config
  4. Reset the system to the default configuration.
    system database reset-to-default proceed yes
    Warning: This command deletes all configuration on the system, including passwords.
    commit
The system now has the default configuration. You need to perform initial configuration and can run the Setup wizard for a guided experience of setting management IP addresses, DNS, and other required settings. For more information on initial configuration, see F5 rSeries Systems: Getting Started at techdocs.f5.com/en-us/hardware/f5-rseries-systems-getting-started.html.
If you want to restore a previously-saved system configuration, you can log in to the system where you want to load the configuration backup file and restore the saved configuration from the CLI.
    config
  3. Import the configuration backup onto the destination system from the external system.
    file import local-file configs/<*file-name*>.xml remote-file /<file-path>/<*filename*>.xml remote-host <*ip-address*> username root
  4. When prompted, type the password for the remote root account.
  5. Load the configuration backup onto the system .
    In this example you restore from a backup file named backup1.xml:
    appliance-1(config)# system database config-restore name backup1.xml
      response Succeeded.
    If the restore operation fails, the system automatically uses the previous configuration.
  6. Commit the configuration changes.
    commit
  7. Reboot the system.
    system reboot
After you restore the system configuration and reboot the system, you can restore any saved tenant configurations.
To restore the configuration for your tenants, log in to each tenant and restore the configuration using the method recommended for that tenant.
For BIG-IP tenants
Restore an archive (or UCS file) from an external location. For more information, see the section titled “Restore data from an archive using the Configuration utility” in BIG-IP System: Essentials at my.f5.com.
A Trusted Platform Module (TPM) is a hardware device that implements security functions to provide the ability to determine a trusted computing environment, allowing for an increased assurance of trust that a device behaves for its intended purpose. The TPM chain of custody provides assurance that the software loaded on your platform at startup time has the same signature as the software that is loaded by F5 when the system is manufactured.
These measurements include taking hashes of most of the BIOS code, BIOS settings, TPM settings, tboot, Linux Initrd, and Linux kernel (initial rSeries release only validates BIOS) so that alternative versions of the measured modules cannot be easily produced and so that the hashes lead to identical measurements. You can use these measurements to validate against known good values.
For the initial rSeries release, local attestation is done automatically at boot time and can be displayed in the CLI.
The TPM implements protected capabilities and locations that protect and report integrity measurements using Platform Configuration Registers (PCRs). The TPM also includes additional security functionality, including cryptographic key management, random number generation, and the sealing of data to system state.
Your TPM-equipped rSeries system comes with functionality to aid in local attestation and confirming chain of custody for the device locally without the need for doing it manually.
Important: If your system has been breached, consult your security team immediately.
You can perform local attestation on your rSeries system of the Trusted Platform Module (TPM) chain of custody using the Platform Configuration Register (PCR) values to confirm that the firmware is unmodified.
This table lists the available local attestation system integrity states for the Trusted Platform Module (TPM).
State Description
Not Supported Indicates that the system does not have the capability to perform System Integrity Measurements.
Pending Indicates that the system is not yet ready to produce a System Integrity Measurement and evaluate the reference values.
Valid Indicates that the solicited System Integrity Measurement matches one of the sets of reference values in the local System Integrity Reference Repository (SIRR).
Invalid Indicates that the System Integrity Measurement has been taken without error, but the values do not match any set of acceptable values in the local System Integrity Reference Repository. This could mean that the SIRR is out of date or that the system has been tampered with.
Unavailable Indicates that an error has occurred.
You can display and verify the current local attestation status of the system from the CLI.
  3. Display the current local attestation status of the appliance.
    show components component state tpm-integrity-status
    A message similar to this example displays:
    appliance-1# show components component state tpm-integrity-status
              TPM
              INTEGRITY
    NAME      STATUS
    platform  Valid
