Updated Date: 07/07/2026
Network Settings
An administrator can configure L2 network settings for the rSeries system, such as port groups, LAGs, interfaces, VLANs, LACP, LLDP, and STP. You can configure these network settings from the webUI, the CLI, or REST APIs.
The front-panel ports on F5 r2000/r4000 and F5 r5000/r10000 platforms support port group functionality. Port groups enable you to configure the mode of the physical port, which controls the port speed and whether the port is bundled or unbundled. Until configured, the rSeries system uses port speeds of 100G, 25G, or 10G, depending on the port and the platform. You can change them based on what optical transceiver module type you are using.
Note: F5 r2000/r4000 platforms have pre-defined configuration modes. These port group options are 4x25GbE, 8x10GbE, and 4x10GbE+2x25GbE.
Before configuring any interfaces, VLANs, or LAGs, you can set up port groups so that physical interfaces on the platform are configured for the proper speed and bundling. Depending on the port group mode, a different FPGA version is loaded, and the speed of the port is adjusted accordingly. The system creates the port group components.
Changing the mode for a port group reboots the system, removes stale interfaces from your configuration, and removes any references to stale interfaces from your configuration. You will then need to reconfigure any previously-configured protocols to use the modified port group.
You can configure port groups to use a specific mode depending on how you are connecting your system.
Important: Changing the port group mode impacts the view of physical interfaces published by the system. The previous interfaces that corresponded to the previous port group mode are deleted, and new ones are created. All configuration associated with the deleted interfaces is also lost.
Log in to the webUI using an account with admin access.
On the left, click NETWORK SETTINGS > Port Groups.
For a specific port group, select a Mode from the list.
For F5 r5000/r10000, you can choose one of these modes:
Option Description 100GbE Create one interface at 100G speed. 40GbE Create one interface at 40G speed. 10GbE Create one interface at 10G speed. For F5 r2000/r4000, you can choose a pre-defined configuration as a mode:
Option Description 4x25GbE Creates four interfaces at 25G speed. 4x10GbE+2x25GbE Creates four interfaces at 10G speed and two interfaces at 25G speed. 8x10GbE Creates eight interfaces at 10G speed. -
Click Save.
When you change the port group mode on ports for a specific group, the system resets. The previous interfaces that corresponded to the previous port group mode are deleted, and the associated (underlying) configuration is also lost.
You can configure a port group for the interfaces on the system at either 100GbE or 40GbE speeds from the CLI. .
Log in to the command line interface (CLI) of the system using an account with admin access.
When you log in to the system, you are in user (operational) mode.
Change to config mode.
configThe CLI prompt changes to include
(config). -
Configure port groups for a specific interface.
portgroups portgroup <*interface-number*> config mode { MODE\_100GB | MODE\_40GB }In this example, you configure the port group mode on interface 2 to use the 100GB mode:
appliance-1(config)# portgroups portgroup 2 config mode MODE_100GB -
Commit the configuration changes.
commit
You can show the state for port groups on the system from the CLI.
Show the current state for the port groups configuration.
show portgroups portgroupA summary similar to this example displays:
appliance-1# show portgroups portgroup portgroups portgroup 1 state vendor-name "F5 INC." state vendor-oui 009065 state vendor-partnum "OPT-0031 " state vendor-revision A0 state vendor-serialnum "A1B2C3D40 " state transmitter-technology "850 nm VCSEL" state media 100GBASE-SR4 state optic-state QUALIFIED state ddm rx-pwr low-threshold alarm -14.0 state ddm rx-pwr low-threshold warn -11.0 state ddm rx-pwr instant val-lane1 -1.96 state ddm rx-pwr instant val-lane2 -0.95 state ddm rx-pwr instant val-lane3 -1.06 state ddm rx-pwr instant val-lane4 -1.98 state ddm rx-pwr high-threshold alarm 3.4 state ddm rx-pwr high-threshold warn 2.4 state ddm tx-pwr low-threshold alarm -10.0 state ddm tx-pwr low-threshold warn -8.0 state ddm tx-pwr instant val-lane1 0.07 state ddm tx-pwr instant val-lane2 0.67 state ddm tx-pwr instant val-lane3 0.32 state ddm tx-pwr instant val-lane4 0.45 state ddm tx-pwr high-threshold alarm 5.0 state ddm tx-pwr high-threshold warn 3.0 state ddm temp low-threshold alarm -5.0 state ddm temp low-threshold warn 0.0 state ddm temp instant val 40.8046 state ddm temp high-threshold alarm 75.0 state ddm temp high-threshold warn 70.0 state ddm bias low-threshold alarm 0.003 state ddm bias low-threshold warn 0.005 state ddm bias instant val-lane1 0.00753 state ddm bias instant val-lane2 0.007448 state ddm bias instant val-lane3 0.007536 state ddm bias instant val-lane4 0.007504 state ddm bias high-threshold alarm 0.013 state ddm bias high-threshold warn 0.011 state ddm vcc low-threshold alarm 2.97 state ddm vcc low-threshold warn 3.135 state ddm vcc instant val 3.3027 state ddm vcc high-threshold alarm 3.63 state ddm vcc high-threshold warn 3.465 ...
Port mappings show how the front-panel interfaces on F5 r5000/r10000 systems are configured for capacity bandwidth and allocated bandwidth using pipelines and pipeline groups.
- pipeline
- Corresponds to a traffic-processing pipeline. There are eight virtual ports per pipeline. Each pipeline has 100Gb of throughput.
- pipeline group
- Contains two pipelines and corresponds to FPGA sockets. The system FPGAs are configured in the bitstream to support the different ports. No bitstream supports all ports simultaneously.
You can view how port mappings are configured from the webUI.
On the left, click NETWORK SETTINGS > Port Mappings.
The current configuration for port mappings displays.
The front-panel ports on F5 r2000/r4000 systems support port profile functionality. Port profiles enable you to change which mode, or port speed, that port uses. SFP28 ports operate at 25GbE by default, and SFP+ ports operate at 10GbE by default. Only these configurations are available:
- 8x10G
- All eight 10G (SFP+) ports run at 10G speed. This is the default configuration.
- 2x25G - 4x10G
- Two 25G (SFP28) ports run at 25G speed, and four 10G (SFP+) ports run at 10G.
- 4x25G
- All four 25G (SFP28) ports run at 25G speed.
Changing the mode for a port profile reboots the system, and then removes stale interfaces and any references to stale interfaces from your configuration. You must reconfigure any previously-configured protocols to use your modified port group.
Note: All tenants must be in “configured” state before you can change the port profile. You cannot change the profile while a tenant is in “deployed” state.
You can configure port profiles for the interfaces on the system from the CLI.
(config). -
Change the port profile configuration.
port-profiles config mode [ 2x25G-4x10G | 4x25G | 8x10G }In this example, you configure the port profile to use the 4x25G mode:
appliance-1(config)# port-profiles config mode 4x25G -
commit
Changing the mode for a port profile reboots the system, and then removes stale interfaces and any references to stale interfaces from your configuration. You must reconfigure any previously-configured protocols to use your modified port profile.
rSeries systems include a set number of front-panel interfaces (or ports). The number of available interfaces varies depending on hardware model.
Before you begin, you must already have created the VLANs that you want to associate with the interface.
Note: If you intend to create LAGs, you should wait to associate VLANs with interfaces, because an interface cannot be used as a LAG member if it is associated with an interface.
You can configure interfaces from the webUI.
On the left, click NETWORK SETTINGS > Interfaces.
A table showing all interfaces displays.
Click an interface name.
For State, select whether the interface is Enabled or Disabled.
These settings are informational, set values and cannot be changed: Operational Status, Speed, MAC Address, and Interface Type.
For MTU, the maximum transmissions unit is set to the default value of 9600 (read only).
This is the largest size that the system allows for an IP datagram passing through a physical interface.
Forward Error Correction is set to the default value of Auto (read only) and detects and corrects a limited number of errors in transmitted data.
Note: Since this setting is enabled automatically, your upstream switch must also support Forward Error Correction (FEC).
RX Flow Control is set to Off, and it is not supported on any of the interfaces.
For Native VLAN, select the VLAN ID to use for untagged frames received on an interface: either a single interface or LAG.
Note: An interface or LAG can have only one Native VLAN assigned to it. You can use a Native VLAN with multiple LAGs or interfaces. You cannot use a VLAN, however, as both a Native and Trunk VLAN for the same interface.
For Trunk VLANs, select one or more VLAN IDs, if available, and not a member of another LAG; this is used for tagged traffic.
You can use the same VLAN ID as the Trunk VLAN across all interfaces or LAGs. You cannot use a VLAN, however, as both a Native and Trunk VLAN for the same interface.
Note: A trunk VLAN or a Native VLAN is required to pass traffic. If you do not select either a Native VLAN or a Trunk VLAN, the port will not carry any traffic.
Click Save & Close.
You can view statistics for physical interfaces configured on the system from the webUI. The table shows, for each interface, the amount of data that was input and output in multiple forms. You can also see in/out errors and frame check sequence (FCS) errors that occurred on each of the interfaces, and you can reset to clear the data.
On the left, click SYSTEM SETTINGS > Management Interface.
Under Interface Statistics, change the way the statistics are displayed in the Data Format by selecting Normalized or Unformatted.
Selecting Normalized converts the byte representation to kilobytes, megabytes, or terabytes, depending on the size. This provides better data readability especially when there are massive amounts of traffic passing through the interfaces.
Set the Auto Refresh interval for refreshing the data displayed or click the refresh icon to update the data immediately.
Select one or more interfaces, then click Reset to clear the data.
You can configure front-panel interfaces from the CLI.
(config). -
Configure settings for the specified interface.
interfaces interface <*interface*> config { disabled | enabled } description <*interface-description*> type <*interface-type*>In this example, you enable and configure interface 1.0 with a custom description:
appliance-1(config)# interfaces interface 1.0 config enabled description "Interface 1.0" -
commit
You can show the state of a specific interface on a platform from the CLI.
Display the current status of a specific interface.
show interface interface <*interface-number*>When you specify a specific interface, a summary similar to this example displays:
`appliance-1# show interfaces interface 5.0 interfaces interface 5.0 state name 5.0 state type ethernetCsmacd state mtu 9600 state enabled true state ifindex 26 state oper-status DOWN state counters in-octets 0 state counters in-unicast-pkts 0 state counters in-broadcast-pkts 0 state counters in-multicast-pkts 0 state counters in-discards 0 state counters in-errors 0 state counters in-fcs-errors 0 state counters out-octets 0 state counters out-unicast-pkts 0 state counters out-broadcast-pkts 0 state counters out-multicast-pkts 0 state counters out-discards 0 state counters out-errors 0 state forward-error-correction auto state lacp_state LACP_DEFAULTED ethernet state port-speed SPEED_25GB ethernet state hw-mac-address 00:12:a1:34:56:78 ethernet state counters in-mac-control-frames 0 ethernet state counters in-mac-pause-frames 0 ethernet state counters in-oversize-frames 0 ethernet state counters in-jabber-frames 0 ethernet state counters in-fragment-frames 0 ethernet state counters in-8021q-frames 0 ethernet state counters in-crc-errors 0 ethernet state counters out-mac-control-frames 0 ethernet state counters out-mac-pause-frames 0 ethernet state counters out-8021q-frames 0 ethernet state flow-control rx on`appliance-1# show interfaces interface 1.0 interfaces interface 1.0 state name 1.0 state type ethernetCsmacd state mtu 9600 state enabled true state ifindex 19 state oper-status DOWN state counters in-octets 0 state counters in-unicast-pkts 0 state counters in-broadcast-pkts 0 state counters in-multicast-pkts 0 state counters in-discards 0 state counters in-errors 0 state counters in-fcs-errors 0 state counters out-octets 0 state counters out-unicast-pkts 0 state counters out-broadcast-pkts 0 state counters out-multicast-pkts 0 state counters out-discards 0 state counters out-errors 0 state forward-error-correction auto state lacp_state LACP_DEFAULTED ethernet state port-speed SPEED_100GB ethernet state hw-mac-address 00:98:a1:76:54:0d ethernet state counters in-mac-control-frames 0 ethernet state counters in-mac-pause-frames 0 ethernet state counters in-oversize-frames 0 ethernet state counters in-jabber-frames 0 ethernet state counters in-fragment-frames 0 ethernet state counters in-8021q-frames 0 ethernet state counters in-crc-errors 0 ethernet state counters out-mac-control-frames 0 ethernet state counters out-mac-pause-frames 0 ethernet state counters out-8021q-frames 0 ethernet state flow-control rx on
A link aggregation group (LAG) is a logical group of interfaces that function as a single interface. The LAG (like a trunk on tenant systems) distributes traffic across multiple links, which increases the bandwidth by adding the bandwidth of multiple links together. For example, four fast Ethernet (100 Mbps) links, if aggregated, create a single 400 Mbps link. LAGs also enhance connection reliability by providing link failover if a member link becomes unavailable.
There are two types of LAGs:
- Static
- Ports in the LAG are manually configured, and the group of ports assigned to a static LAG is always made up of active members. This is the default type of LAG.
- Link Aggregation Control Protocol (LACP)
- When LACP is enabled on a LAG, the ports configure automatically into groups without manual configuration. The LACP protocol detects error conditions on member links and redistributes traffic to other member links, thus preventing any loss of traffic on a failed link.
You can create a link aggregation group (LAG) or edit the properties of an existing LAG from the webUI.
On the left, click NETWORK SETTINGS > LAGs.
The screen shows LAGs that are configured.
Click Add.
For Name, type a name for the LAG.
For LAG Type, select one of these options:
Option Description STATIC Manually configure the links. The link state of LAG members is not dynamically updated. This is the default value for LAGs. LACP Automatically bundle links. -
If you select LACP, configure these additional settings:
Option |
Description |
LACP Interval |
Specify an interval at which interfaces send LACP packets. Select FAST (transmit packets every second) or SLOW (transmit packets every 30 seconds). |
LACP Mode |
Specify the negotiation state for LACP. Select ACTIVE (in an active negotiating state) or PASSIVE (do not initiate negotiation until peer contacts first). |
For Configured Members, select one or more interfaces (not members of another LAG) to assign to the LAG.
Note: Only interfaces that are configured with the same speeds can be members of the LAG. The interfaces cannot be associated with VLANs.
You can add up to 20 members to a LAG.
For Native VLAN, select the VLAN ID to use for untagged frames received on a trunk interface.
For Trunk VLANs, select one or more VLAN IDs, if available and not a member of another LAG.
Note: A trunk VLAN or a native VLAN is required to pass traffic. If you do not select either a native VLAN or a trunk VLAN, the port will not carry any traffic.
Click Save & Close.
The LAG is created and shown in the list. You can edit LAG properties by clicking the LAG name. You can add up to 256 LAGs.
You can view the LACP details on the webUI to troubleshoot. For example, you can determine why an interface member of an LACP LAG on the system is not working as expected.
On the left, click NETWORK SETTINGS > LACP Details.
The screen shows state information about whether LACP is Up, Down, or Defaulted for LACP interfaces. The lower portion of the screen shows details that can be used for troubleshooting LACP issues.
To configure a static LAG, you first configure the status LAG interface, then add interfaces to LAG members, and then associate VLANs with the LAG interfaces.
You can configure a LAG interface type as static from the CLI.
Connect using SSH to the management IP address.
(config). -
Create a LAG interface.
interfaces interface <*lag-name*> config type ieee8023adLag description <*lag-description*>This example creates a LAG named lag-test with a description:
appliance-1(config)# interfaces interface lag-test config type ieee8023adLag description "HA LAG"The system prompt updates to show that you are in configuration mode for the interface:
appliance-1(config-interface-lag-test)# -
Set the type of LAG interface to STATIC (this is the default setting).
aggregation config lag-type STATICThis example shows the interface named lag-test in configuration mode and configures it as a static LAG:
appliance-1(config-interface-lag-test)# aggregation config lag-type STATIC -
commit
You can add interfaces, or member ports, to a LAG interface from the CLI.
(config). -
Add interfaces to a LAG.
interfaces interface <*interface*> ethernet config aggregate-id <*lag-name*>This example adds interface 1.0 to a LAG named lag-test:
appliance-1(config)# interfaces interface 1.0 ethernet config aggregate-id lag-test -
commit
Before you can pass user traffic, you need to associate VLANs with LAG interfaces from the CLI.
(config). -
Associate VLANs with the LAG interface.
interfaces interface <*lag-name*> aggregation switched-vlan config trunk-vlans [ <*vlan-IDs*>]This example associates VLANs 1037 and 1038 with a LAG named lag-test:
appliance-1(config)# interfaces interface lag-test aggregation switched-vlan config trunk-vlans [ 1037 1038 ] -
commit
You can create a LAG interface from the CLI.
(config). -
interfaces interface <*lag-name*> config type ieee8023adLagThis example creates a LAG named lag-test:
appliance-1(config)# interfaces interface lag-test config type ieee8023adLag -
commit
Before LACP can manage a LAG interface, you need to create a LAG interface of type LACP from the CLI.
(config). -
Create a LAG interface of type LACP.
interfaces interface <*lag-name*> aggregation config lag-type LACPThis example creates a LAG of type LACP named lag-test:
appliance-1(config)# interfaces interface lag-test aggregation config lag-type LACP -
commit -
Return to user (operational) mode.
end -
Verify that LACP is enabled on the interface.
show interfaces interface lag-testA summary similar to this example displays:
appliance-1# show interfaces interface lag-test interfaces interface lag-test state type ieee8023adLag state mtu 9600 state oper-status UP state forward-error-correction auto ethernet state flow-control rx on aggregation state lag-type LACP aggregation state lag-speed 100 aggregation state distribution-hash src-dst-ipport aggregation state mac-address 00:94:a1:69:61:14 aggregation state lagid 1
By default, a LAG interface is in a static mode, which means that the member links do not initiate or process any of the LACP packets received. You can enable LACP on the LAG interface from the CLI.
(config). -
Enable LACP on a LAG interface.
interfaces interface <*lag-name*> aggregation config lag-type LACPThis example enables LACP on a LAG interface named lag-test:
commit -
end -
Verify that LACP is enabled on a specified LAG interface.
appliance-1# show interfaces interface lag-test state name lag-test state type ieee8023adLag state mtu 9600 state oper-status UP state forward-error-correction auto ethernet state flow-control rx on aggregation state lag-type LACP aggregation state lag-speed 100 aggregation state distribution-hash src-dst-ipport aggregation state mac-address 00:94:a1:69:61:14 aggregation state lagid 1
You can check the LACP state from the CLI.
Display the LACP state.
show lacpA summary similar to this example displays:
appliance-1# show lacp lacp state system-id-mac 00:94:a1:69:34:23 lacp interfaces interface lag-test state name lag-test state interval SLOW state lacp-mode ACTIVE state system-id-mac 00:94:a1:69:34:23 members member 1.0 state interface 1.0 state activity ACTIVE state timeout LONG state synchronization IN_SYNC state aggregatable true state collecting true state distributing true state system-id 00:94:a1:69:34:23 state oper-key 2 state partner-id 2c:dd:e9:41:87:61 state partner-key 4 state port-num 1024 state partner-port-num 266 state counters lacp-in-pkts 2456 state counters lacp-out-pkts 2458 state counters lacp-rx-errors 0
You can view the state of LACP interfaces from the CLI.
Display the state of LACP interfaces.
show interfaces interface state lacp_stateA summary similar to this example displays:
appliance-1# show interfaces interface state lacp_state NAME LACP STATE ---------------------- 1.0 LACP_UP 2.0 LACP_DEFAULTED 3.0 LACP_DEFAULTED 4.0 LACP_DEFAULTED 5.0 LACP_DEFAULTED 6.0 LACP_DEFAULTED 7.0 LACP_DEFAULTED 8.0 LACP_DEFAULTED 9.0 LACP_DEFAULTED 10.0 LACP_DEFAULTED 11.0 LACP_DEFAULTED 12.0 LACP_DEFAULTED 13.0 LACP_DEFAULTED 14.0 LACP_DEFAULTED 15.0 LACP_DEFAULTED 16.0 LACP_DEFAULTED 17.0 LACP_DEFAULTED 18.0 LACP_DEFAULTED 19.0 LACP_DEFAULTED 20.0 LACP_DEFAULTEDThese are the available LACP states:
Option Description LACP_DEFAULTED Initial lacp_state value. LACP_UP LACPD has determined that this interface is a working member of an LACP LAG. LACP_DOWN LACPD has determined that this interface is not a working member of an LACP LAG, and it should not receive or transmit user traffic.
LACP errors are collected into the standard /var/F5/system/log/platform.log file. LACP errors run at the log level INFORMATIONAL by default. If you want to change the severity level for logged information, you can enable a different log level from the CLI.
(config). -
Configure the logging level for LACP.
system logging sw-components sw-component lacpd config severity { ALERT | CRITICAL | DEBUG | EMERGENCY | ERROR | INFORMATIONAL | NOTICE | WARNING }This example enables DEBUG level logging for LACP:
`appliance-1(config)# system logging sw-components sw-component lacpd config severity DEBUG` -
commit
Configured members are interfaces in an LACP LAG that listen for and/or send LACPDUs that are attempting to establish that the peer is configured. You can check each physical interface’s aggregated ID from the CLI.
Show the configuration members.
show running-config interfaces interface ethernet config aggregate-id <*lag-name*>This example shows information about three members for a LAG named lag-test:
appliance-1# show running-config interfaces interface ethernet config aggregate-id lag-test interfaces interface 1.0 config type ethernetCsmacd config enabled ethernet config aggregate-id lag-test !
Working members are a subset of configuration members. These members are added and removed dynamically by LACPD. You can see information about working members in a LAG from the CLI.
Show the working members, including port statistics.
show lacp interfaces interface members member state countersA summary similar to this example displays:
appliance-1# show lacp interfaces interface members member state counters LACP LACP LACP LACP LACP IN OUT RX TX UNKNOWN LACP NAME INTERFACE PKTS PKTS ERRORS ERRORS ERRORS ERRORS ----------------------------------------------------------------- lag-test 1.0 952 384 0 - - - 2.0 844 384 0 - - -
A VLAN is a logical subset of hosts on a local area network (LAN) that operates in the same IP address space. Grouping hosts together in a VLAN has distinct advantages. For example, with VLANs, you can:
- Reduce the size of broadcast domains, thereby enhancing overall network performance.
- Reduce system and network maintenance tasks substantially. Functionally related hosts do not need to physically reside together to achieve optimal network performance.
- Enhance security on your network by segmenting hosts that must transmit sensitive data.
For the most basic rSeries system configurations, you might create multiple VLANs. That is, you create a VLAN for each of the internal and external networks, as well as a VLAN for high availability communications. You then associate each VLAN with the relevant interfaces or LAGs.
You can create a VLAN and associate physical interfaces or LAGs with that VLAN. In this way, any host that sends traffic to an interface is logically a member of the VLAN or VLANs to which that interface or LAG belongs.
On the left, click NETWORK SETTINGS > VLANs.
The screen shows VLANs that are configured for the system.
Click Add.
For Name, type a name for the VLAN.
Note: VLAN names must follow these rules:
- Start with an alphabetic character (Aa-Zz).
- Can be up to 56 characters in length.
- After the first character, can contain alphanumeric characters, periods (.), hyphens (-) and underscores (_).
- VLAN names must be unique.
For VLAN ID, type a number between 1-4094 for the VLAN.
The VLAN ID identifies the traffic from hosts in the associated VLAN for an associated interface or LAG.
Click Add VLAN to create the VLAN.
The VLAN is created and displayed in the VLAN list. You can use the VLANs when configuring interfaces, creating LAGs, and deploying tenants (one VLAN can be shared by more than one tenant).
VLAN listeners are created and deleted by the system at runtime. They are used to program the destination for broadcast packets and L2 destination lookup failures (DLFs).
The system creates a listener when you configure a VLAN for a tenant.
- VLAN Listener (listener)
- Created when a VLAN is used by a single tenant or when a VLAN is not shared among tenants. VLAN listeners that are created for tenant VLANs that do not include any members are indicated with the value
0.hostfor interface.
You can view VLAN listeners when you need to troubleshoot data path issues and check whether the correct VLANs are assigned to the tenants from the webUI.
On the left, click NETWORK SETTINGS > VLAN Listeners.
The screen shows VLAN listeners that are active on the system.
You can see the VLAN listeners that are associated with specific interfaces, VLANs, and other related information. If something does not look correct, review the configuration for that object.
Viewing the VLAN listeners is primarily used for troubleshooting data path issues. You can check whether the correct VLANs are assigned to the tenants from the CLI.
View configured VLAN listeners.
show vlan-listenersA summary similar to this example displays:
appliance-1# show vlan-listeners NDI INTERFACE VLAN ENTRY TYPE OWNER ID SVC VTC SEP DMS DID CMDS MIRRORING SERVICE IDS --------------------------------------------------------------------------------------------------------------------- 0.host 100 RBCAST-LISTENER rbcast 4095 5 32 15 - - - disabled [ 13 14 15 16 17 18 19 ] 0.host 101 VLAN-LISTENER t101100 4095 19 - 15 - - - disabled -
When you configure rSeries systems as network virtualization gateways, the system represents the connection as a tunnel, which provides a Layer 2 interface on the virtual network. You can use the tunnel interface in both Layer 2 and Layer 3 configurations. After you create the network virtualization tunnels, you can use the tunnels like you use VLANs.
You can configure Geneve IP tunnels from the CLI.
(config). -
Create an IP tunnel.
iptunnels iptunnel geneve config { disabled | enabled } dport <*port*>Allowed values for destination port (dport) are in the range of 0 to 65535.
In this example, you create a tunnel that is enabled with the destination port of 6081:
appliance-1(config)# iptunnels iptunnel geneve config enabled dport 6081 -
commit
You can configure NVGRE tunnels from the CLI.
(config). -
iptunnels iptunnel nvgre config ethertype <*hex-value*>Allowed values for ethertype are a hexadecimal value, with a leading “0x” followed by 4 digits.
In this example, you create an NVGRE tunnel:
appliance-1(config)# iptunnels iptunnel nvgre ethertype 0x1234 -
commit
You can configure VXLAN tunnels from the CLI.
(config). -
iptunnels iptunnel vxlan dport <*port*> gpe { disabled | enabled } dport <*port*> nsh { disabled | enabled }Allowed values for destination port (dport) are in the range of 0 to 65535.
In this example, you create a tunnel with gpe enabled and nsh disabled:
appliance-1(config)# iptunnels iptunnel vxlan dport 4789 gpe enabled dport 4790 nsh disabled -
commit
The rSeries system supports Link Layer Discovery Protocol (LLDP), which is a Layer 2 industry-standard protocol (IEEE 802.1AB) that enables a network device to advertise its identity and capabilities to multi-vendor neighbor devices on a network. The protocol also enables a network device to receive information from neighbor devices. LLDP transmits device information in LLDP frames using the TLV (Type-Length-Value) format.
In general, this protocol:
- Advertises connectivity and management information about the local rSeries device to neighbor devices on the same IEEE 802 LAN.
- Receives network management information from neighbor devices on the same IEEE 802 LAN.
- Operates with all IEEE 802 access protocols and network media.
Before you can configure LLDP, make sure that the interfaces you will use are up and running with VLANs configured.
You can configure LLDP from the webUI.
On the left, click NETWORK SETTINGS > LLDP Configuration.
Set Enable LLDP to Enabled.
Type a System Name and optionally, a System Description.
For TX Interval, type a number (0-65535) for the interval (in seconds) at which LLDP packets are sent to neighbors. The default value is 30 seconds.
For TX Hold, type a number (0-65535).
The default value is 4 seconds.
For Reinitiate Delay, type a number (0-65535) to specify the minimum time interval, in seconds, an LLDP port waits before re-initializing an LLDP transmission.
The default value is 2 seconds.
For TX Delay, type a number (0-65535) to specify the minimum time delay, in seconds, between successive LLDP frame transmissions.
For Max Neighbors Per Port, type a number to specify the maximum number of LLDP neighbors for which LLDP data is retained.
The default value is 10.
In the Interfaces table, select the interfaces and LAGs (if any) for which you want to enable LLDP. For each one selected:
Select Enabled.
For TLV Advertisement State, select TX (Transmit only), RX (Receive only), or TXRX (Transmit and Receive).
For TLV Map, select the TLV device information that you want to transmit and/or receive, such as MAC Phy configuration, management address, MFS (maximum frame size), port description, port ID, and power MDI.
Click Save.
To remove an interface that has been enabled for LLDP:
In the Interfaces table, select the interface you want to remove.
Click Remove.
Click Save.
LLDP is configured on the system for the specified interfaces and LAGs.
LLDP enables a network device to advertise information about itself to other devices on the network and enables network devices to receive information from neighboring devices. If using LLDP, you can display state information for the LLDP-enabled interfaces and LAGs on the system. When LLDP is enabled to receive data in a working network, any device information received from neighbors is included in a table.
On the left, click NETWORK SETTINGS > LLDP Details.
The screen shows LLDP state information for interfaces in the system (similar to information shown at the CLI using
show lldp). -
In the Neighbors table, examine the identification, configuration, and capabilities of neighboring devices.
This information provides details useful for troubleshooting many configuration problems.
The rSeries system supports a set of industry-standard, Layer 2 protocols known as spanning tree protocols. A spanning tree is a logical tree-like depiction of the bridges on a network and the paths that connect them. Spanning tree protocols block redundant paths on a network, preventing bridging loops. If a blocked, redundant path is needed later because another path has failed, the spanning tree protocols clear the path again for traffic.
Note: Spanning tree protocols are supported only on F5 r5000/r10000 platforms.
The spanning tree protocols that the rSeries system supports are:
- Spanning Tree Protocol (STP) - 802.1d
- Rapid Spanning Tree Protocol (RSTP) - 802.1w
- Multiple Spanning Tree Protocol (MSTP) - 802.1s
You can configure spanning tree protocols on the system from the webUI, CLI, or REST API. Only one spanning tree protocol can be configured at a time.
Central to the way that spanning tree protocols work is the use of bridge protocol data units (BPDUs). When you enable spanning tree protocols on Layer 2 devices on a network, the devices send BPDUs to each other, for the purpose of learning the redundant paths and updating their L2 forwarding tables accordingly, electing a root bridge, building a spanning tree, and notifying each other about changes in interface status.
Note: The term bridge refers to a Layer 2 device such as a switch, bridge, or hub.
When you configure spanning tree on the rSeries system, you must first decide which protocol, or mode, you want to enable. Because MSTP recognizes VLANs, using MSTP is preferable. All bridges in a network environment that you want to use spanning tree must run the same spanning tree protocol. If a legacy bridge running RSTP or STP is added to the network, the rSeries system must switch and also use that same protocol.
Note: STP cannot be enabled on individual LAG members. Live upgrades will not work if STP is not configured correctly; resolve any configuration issues before upgrading.
If you want to change STP modes, you must first remove the existing STP configuration by deleting the existing mode and configuration from the CLI.
(config). -
Disable the current STP mode
no stp global config enabled-protocol STP -
commit -
Remove the existing interface configuration for STP mode.
no stp stp interfaces interface -
Remove the edge port and link type configuration.
no stp interfaces interface -
commit -
Enable another STP mode.
stp global config enabled-protocol { MSTP | RAPID\_PVST | RSTP | STP }In this example, you enable RSTP:
appliance-1(config)# stp global config enabled-protocol RSTP -
commit
STP is the original spanning tree protocol, but it is not recommended in VLAN-rich environments due to poor performance unless required by your configuration. STP can create only one spanning tree (instance 0) for the entire network, and therefore cannot take VLANs into account when managing redundant paths. You can configure STP from the CLI.
(config). -
Enable STP.
stp global config enabled-protocol { MSTP | RAPID\_PVST | RSTP | STP ]In this example, you enable STP mode:
appliance-1(config)# stp global config enabled-protocol STP -
Configure the bridge-priority so that it is not selected as the root bridge.
stp stp config bridge-priority <*priority*>The priority is used together with the address as a bridge identifier. The range is from 0 (highest) to 61440 (lowest), in increments of 4096. The default value is 32768.
In this example, you set the bridge priority to 32768:
appliance-1(config)# stp stp config bridge-priority 32768 -
Configure interface cost and port priority.
stp { global | interfaces | mstp | rstp | stp } interfaces interface <*interface*> config cost <*cost*> port-priority <*priority*>Note: You must configure all interfaces that will be included in STP.
The priority is used as the port identifier together with the port number. The port priority range is from 0 (highest) to 240 (lowest) in increments of 16. The default value is 128. The port path cost range is from 0 (lowest) to 20,000,000,000 in increments of 1. The default port path cost is assigned dynamically (cost = 20,000,000,000 / port speed in kbits).
In this example, you configure the RSTP to use port 1.0, with an interface cost of 200 and a port priority of 128:
appliance-1(config)# stp stp interfaces interface 1.0 config cost 200 port-priority 128 -
commit
RSTP is an enhancement to STP that improves spanning tree performance. RSTP can create only one spanning tree (instance 0) for the entire network, and therefore cannot take VLANs into account when managing redundant paths. You can configure RSTP from the CLI.
(config). -
Enable RSTP.
stp global config enabled-protocol { MSTP | RAPID\_PVST | RSTP | STP ]The bridge-priority, forwarding-delay, hello-time, hold-count, and max-age have default values, which are recommended for use.
In this example, you enable RSTP mode:
stp { global | interfaces | mstp | rstp | stp } config bridge-priority <*priority*>The priority is used together with the address as a bridge identifier. The range is from 0 (highest) to 61440 (lowest), in increments of 4096. The default value is 32768.
appliance-1(config)# stp rstp config bridge-priority 32768 -
appliance-1(config)# stp rstp interfaces interface 1.0 config cost 200 port-priority 128 -
Configure interface edge-port and link-type.
stp interfaces interface <*interface*> config edge-port { EDGE\_AUTO | EDGE\_DISABLE | EDGE\_ENABLE } link-type { P2P | SHARED }Note: You must configure all interfaces that will be included in STP.
In this example, you configure port 2.0 to set the interface as an EDGE_AUTO port that uses point-to-point spanning tree links:
appliance-1(config)# stp interfaces interface 2.0 config edge-port EDGE_AUTO link-type P2P -
commit
MSTP is an enhancement to RSTP and is the preferred spanning tree protocol (STP) for the rSeries system. MSTP is specifically designed to understand VLANs and VLAN tagging (specified in IEEE 802.1q). MSTP allows for multiple spanning tree instances. Each instance corresponds to a spanning tree and can control one or more VLANs that you specify when you create the instance. Thus, for any rSeries system interface that you assigned to multiple VLANs, MSTP can block a path on one VLAN, while still keeping a path in another VLAN open for traffic.
You can configure MSTP from the CLI. The spanning tree algorithm automatically groups bridges into regions, based on the values you assign to the MSTP configuration name, revision number, instance numbers, and instance members.
(config). -
Enable MSTP.
stp mstp config name <region-name> revision [0-65535]The name option is a string <= 32 characters, and the default value is the bridge MAC address. The revision option is a range from 0 to 65535, and the default value is 0. The forwarding-delay, hello-time, hold-count, max-age, and max-hop options have default values, which are recommended for use.
Important: The name and revision options together form the common identifier of the BPDUs within the region. They must be identical on all bridges in the region.
Create an MSTP instance.
stp mstp mst-instances mst-instance <*integer*> config mst-id <*integer*>In this example, you create an instance named test with the default revision level (0):
appliance-1(config)# stp mstp config name test revision 0 -
Configure VLANs for the MSTP instance.
vlans vlan <*vlan-id*>The VLANs must already exist.
In this example, you create VLANs 300 and 301:
appliance-1(config)# vlans vlan 300 appliance-1(config-vlan-300)# vlans vlan 301In this example, you assign VLANs 300 and 301 to MSTP instance 1:
appliance-1(config)# stp mstp mst-instances mst-instance 1 config vlan [ 300 301 ] -
Exit to the top level of the configuration hierarchy.
top -
Configure bridge priority for the MSTP instance.
stp mstp mst-instances mst-instance <*instance*> config bridge-priority <*priority*>Each MSTP instance can have its own priority. The priority is used together with the address as a bridge identifier. The default value is 32768, and the range is from 0 (highest) to 61440 (lowest) in multiples of 4096.
In this example, you configure MTSP instance 1 with a bridge priority of 32768:
appliance-1(config)# stp mstp mst-instances mst-instance 1 config bridge-priority 32768 -
top -
stp mstp mst-instances mst-instance <*instance*> interface interface <*interface*> config cost <*cost*> port-priority <*priority*>Note: You must configure all interfaces that will be included in STP.
In this example, you configure MSTP instance 1 to use port 1.0, with an interface cost of 200 and a port priority of 128:
appliance-1(config)# stp mstp mst-instances mst-instance 1 interfaces interface 1.0 config cost 200 port-priority 128 -
top -
appliance-1(config)# stp interfaces interface 2.0 config edge-port EDGE_AUTO link-type P2PThese settings speed up convergence time by eliminating the learning state on ports that do not receive BPDUs. This configuration is cancelled automatically upon reception of a BPDU.
commit
You can configure Spanning Tree Protocol (STP), Rapid Spanning Tree Protocol (RSTP), and Multiple Spanning Tree Protocol (MSTP) from the webUI by selecting the desired protocol from the STP Configuration page under Network Settings. You can also disable STP functionality by selecting Disabled.
You can configure Spanning Tree Protocol (STP) from the webUI. To disable the use of STP Modes, select Disabled.
Note: Spanning tree protocols are only supported on F5 r5000/r10000 platforms.
On the left, click NETWORK SETTINGS > STP Configuration.
For STP Mode, select:STP (single instance, best on networks with legacy systems).
A message warns you that changing modes deletes any existing STP configuration settings. When you click OK, the selected mode is enabled, and additional options for that mode display (with default values set).
For Hello Time, specify the time interval, in seconds, that the system transmits spanning tree information (through BPDUs) to adjacent bridges in the network.
The default value is 2.
For Max Age, specify the length of time, in seconds, that spanning tree information received from other bridges is considered valid.
The default value is 20, and the valid range is from 6 to 40.
For Forwarding Delay, specify the amount of time, in seconds, that the system blocks an interface from forwarding network traffic when the spanning tree algorithm reconfigures a spanning tree.
The default value is 15, and the valid range is from 4 to 30. This has no effect when running in RSTP or MSTP unless using an added legacy STP bridge.
For Hold Count, specify the maximum number of spanning tree frames (BPDUs) that the system can transmit on a port within the Hello Time interval.
This ensures that spanning tree frames do not overload the network. The default value is 6, and the valid range is from 1 to 10.
For Bridge Priority, specify the bridge in the spanning tree with the lowest relative priority becomes the root bridge, which is responsible for managing loop resolution on the network.
Configure this setting so that the system never becomes the root bridge. The default value is 32768. The valid range is from 0 to 61440 in multiples of 4096.
For Interfaces, select the interfaces (and/or LAGs) for which you want to configure STP and specify these fields:
Option |
Description |
Cost |
Used to calculate the cost of sending spanning tree traffic through the interface to an adjacent bridge or spanning tree region, based on the speed of the interface. The default value is 0, and the valid range is from 0 (lowest) to 200,000,000 (highest). |
Port Priority |
Used as the port identifier together with the port number. The default value is 128 (when an interface is selected), and the valid range is from 0 (highest) to 240 (lowest) in multiples of 16. |
Edge Port |
Needed only for RSTP or MSTP. When enabled, indicates the interface or LAG is an edge port that does not receive any BPDU frames. Set to EDGE-AUTO, EDGE-ENABLE, or EDGE-DISABLE. If you enable EDGE-ENABLE, and the interface later receives BPDUs, the system disables the setting automatically, because only non-edge interfaces can receive BPDUs. |
Link Type |
Specifies the type of optimization:- P2P: Optimizes for point-to-point spanning tree links (connects two spanning tree bridges only). Note that P2P is the only valid STP link type for a LAG.
**Note:** For more information on the available interfaces and LAGs, see the **NETWORK SETTINGS** > **Interfaces** or **LAGs** screens.
Click Save.
The system displays a confirmation dialog confirming whether to change the STP mode.
STP is now set up for use on the system.
You can configure Rapid Spanning Tree Protocol (RSTP) from the webUI. To disable the use of STP Modes, select Disabled.
For STP Mode, select RSTP (single instance, fast convergence).
A message warns you that changing modes deletes any existing STP configuration settings. When you click OK, the selected mode is enabled, and additional options for that mode are displayed (with default values set).
For Hello Time, specify the time interval, in seconds, that the rSeries system transmits spanning tree information (through BPDUs) to adjacent bridges in the network.
The default value is 2. For RSTP, maintain this relationship between the Maximum Age and Hello Time options:
Max Age >= 2 * (Hello Time + 1)
The default value is 20, and the valid range is from 6 to 40. For RSTP, maintain these relationships between the Maximum Age and the Hello Time and Forward Delay options:
Max Age <= 2 * (Forward Delay - 1)
The default value is 15, and the valid range is from 4 to 30. This has no effect when running in RSTP or MSTP unless using an added legacy STP bridge. For RSTP, maintain these relationships between the Maximum Age and Forward Delay options:
For Interfaces, select the interfaces (and/or LAGs) for which you want to configure RSTP and specify these fields:
Option |
Description |
Cost |
Port Priority |
Edge Port |
Link Type |
Click Save.
RSTP is now set up for use on the system.
If you want to use Multiple Spanning Tree Protocol (MSTP) to define a region, you can configure it from the webUI. To disable the use of STP Modes, select Disabled.
For STP Mode, select MSTP (multiple instances, fast convergence).
For Region Name, enter a name (string with 1 to 32 characters) that you assign to all bridges in a spanning tree region.
A spanning tree region is a group of bridges with identical region names and MSTP revision numbers, as well as identical assignment of VLANs to spanning tree instances. The default value is the bridge MAC address. A region can have multiple members with the same MSTP configuration.
For Revision, specify a global revision number that you assign to all bridges in a spanning tree region.
The default value is 0, and the valid range is 0 to 65535. All bridges in the same region must have this same configuration revision number.
For Max Hop, specify The maximum number of hops that a spanning tree frame (BPDU) can traverse before it is discarded.
The default value is 20, and the valid range is from 1 to 255.
To configure multiple instances for a region, adjust these settings for MSTP Instances:
Under Instances, click +.
In the Add MSTP Instance popup, for Instance ID, type a positive integer and click Add.
Under Instances, select one of the instances.
Available interfaces are listed below.
Under VLANs, select the VLANs to map to this instance.
For Bridge Priority, configure this setting so that the rSeries system never becomes the root bridge.
The default value is 32768, and the valid range is from 0 to 61440 in multiples of 4096. Each MSTP instance can have its own bridge priority.
For Interfaces, select the interfaces that traffic for this instance can use and specify these fields:
Option |
Description |
Cost |
Port Priority |
Edge Port |
Link Type |
Continue to configure any other instances that you might need.
Click Save.
MSTP is set up for use on the system.
A virtual wire (also known L2 inline service) logically connects two interfaces, in any combination, to each other. This enables the system to forward traffic from one interface to another, in either direction. Packets received on a virtual-wire interface are forwarded to the other endpoint of the virtual wire.
A virtual network forms an internal virtual L2/L3 network in the system. Each virtual network has its own set of external network endpoints and can be configured using one of two modes: default and virtual-wire.
After you create a virtual wire, it is available to attach to a tenant. A single tenant can use multiple virtual networks.
Note: Virtual wire is supported only on F5 r5000/r10000 platforms.
You can configure virtual networks with a specified mode from the CLI.
Note: Only STATIC LAGs (not LACP) support virtual networks.
(config). -
Create a virtual network.
Important: You cannot create a virtual wire using this virtual network if you specify
defaultfor themodeoption.virtual-networks virtual-network <*name*> config mode { default | virtual-wire }This example creates a virtual network named vn1:
appliance-1(config)# virtual-networks virtual-network vn1 config mode virtual-wire -
top -
Create a second virtual network if you plan to configure a virtual wire (a virtual wire must include exactly two virtual networks).
defaultfor themodeoption.virtual-networks virtual-network <*name*> config mode { default | virtual-wire }This example creates a virtual network named vn2:
appliance-1(config)# virtual-networks virtual-network vn2 config mode virtual-wire -
top -
commit
After you have configured two virtual networks, you can associate these networks with an interface or STATIC LAG.
You can configure the interface or STATIC LAG to associate with two previously-configured virtual networks from the CLI.
(config). -
Associate an interface or STATIC LAG with a virtual network.
interfaces interface <*interface-or-lag-name*> { ethernet | aggregation } config virtual-networks <*virtual-network*>This example associates interface 1.0 with a virtual network named vn1:
appliance-1(config)# interfaces interface 1.0 ethernet config virtual-networks vn1This example associates LAG-11 with a virtual network named vn1:
appliance-1(config)# interfaces interface LAG-11 aggregation config virtual-networks vn1 -
top -
Associate a different interface or STATIC LAG with the other virtual network.
interfaces interface <*interface-or-lag*> ethernet config virtual-networks <*virtual-network*>This example associates interface 2.0 with a virtual network named vn2:
appliance-1(config)# interfaces interface 2.0 ethernet config virtual-networks vn2This example associates LAG-12 with a virtual network named vn12:
appliance-1(config)# interfaces interface LAG-12 aggregation config virtual-networks vn2 -
top -
commit
After you have associated the virtual networks with an interface or LAG, you can create a virtual wire that uses these virtual networks.
You can configure a virtual wire from the CLI.
(config). -
Create a virtual wire.
virtual-wires virtual-wire <*name*> config virtual-networks [ <*virtual-networks*> ] vwire-propagate-linkstatus { false | true }This example creates a virtual wire named vwire that includes virtual networks named vn1 and vn2. It also specifies that link status is propagated, which means that if one interface in the virtual wire loses its connection (link down), that state propagates to the other interface in the virtual wire.
appliance-1(config)# virtual-wires virtual-wire vwire config virtual-networks [ vn1 vn2 ] vwire-propagate-linkstatus true -
commit
After you have created virtual networks and a virtual wire, you can add a virtual wire to a tenant.
You can add a virtual wire to a configured tenant from the CLI.
(config). -
Add a virtual wire to a tenant.
tenants tenant <*tenant-name*> config virtual-wires <*virtual-wire-name*>This example creates a virtual wire named vwire that includes virtual networks named vn1 and vn2.
appliance-1(config)# virtual-wires virtual-wire vwire config virtual-networks [ vn1 vn2 ] -
commit -
end -
Verify the virtual network configuration.
appliance-1# show virtual-networks NAME NAME MODE ID ------------------------------ vn1 - virtual-wire 11 vn2 - virtual-wire 12 -
Verify the virtual wire configuration.
appliance-1# show virtual-wires VWIRE PROPAGATE VIRTUAL NAME NAME BPDU MODE LINKSTATUS NETWORKS ------------------------------------------------------- vwire vwire passthrough true [ vn1 vn2 ]
You can create a virtual network with a specified mode and interface members or link aggregation groups (LAGs).
On the left, click NETWORK SETTINGS > Virtual Wire.
In the Virtual Networks area, click Add.
For Name, type a name for the virtual network.
For Mode, select virtual-wire.
Important: You cannot create a virtual wire using this virtual network if you select default.
For Member, select from available interface members and STATIC LAGs.
Click Save & Close.
After you have configured virtual networks, you can create virtual wires that use these virtual networks.
You can create a virtual wire that includes exactly two virtual networks.
In the Virtual Wires area, click Add.
For Propagate Link Status, select either False or True.
Select True to specify that if one interface in the virtual wire loses its connection (link is own), that state propagates to the other interface in the virtual wire. The default value is False.
For Virtual Networks, select exactly two existing virtual networks to add to this virtual wire.
The virtual wire networks must have the same member type (either interface or LAG). Mixing types is not supported. Also, each virtual network must have the same number of configured members.
Click Save & Close.
After you have configured virtual networks and virtual wires, you can assign virtual wires to a tenant.
You can add a virtual wire to a configured tenant from the webUI.
On the left, click TENANT MANAGEMENT > Tenant Deployments.
The Tenant Deployment screen displays showing the existing tenant deployments and associated details.
Click the name of the tenant deployment you want to modify.
The Tenant Deployment screen displays.
For Virtual Wires, select configured virtual wires to be used by the tenant.
Note: This field displays only when virtual wires are configured on the system.
Click Save & Close.
The tenant is reconfigured to use the selected virtual wires.
