Manual Chapter :
Fan tray replacement overview
Applies To:
Show VersionsF5OS-A
- 1.7.0, 1.3.1, 1.3.0, 1.2.0, 1.1.1, 1.1.0
The fans in F5 platforms help maintain airflow throughout the chassis and run constantly while the unit is powered on. Over time, the fans can wear out, requiring you to replace the fan tray. For platforms that have a removable fan tray, you can change or replace the fan tray as part of the routine maintenance of the unit, or in the event of a fan failure.
This product is sensitive to electrostatic discharge (ESD). F5 recommends that you use proper ESD grounding procedures and equipment when you install or maintain the unit.
