Manual Chapter : Hardware specifications - r5000 Series
Applies To:
Show Versions Show Versions
F5OS-A
  • 1.1.1, 1.1.0
Manual Chapter
This table lists hardware specifications for r5000 Series platforms.
Item
Specification
Dimensions
H: 1.72 inches (4.37 cm) x W: 17.4 inches (44.20 cm) x D: 30.6 inches (77.72 cm) (per unit) 1U industry standard rack-mount chassis
Weight
36.0 pounds (16.33 kg) with two power supply units (PSUs) (per unit)
  • Quick install rail kit adds 4.5 pounds (2.04 kg).
  • Optional mid-mount rack brackets add 2.5 pounds (1.13 kg).
Processor
1 x 16-Core Intel® Xeon® processor (total 32 hyperthreaded logical processing cores)
Communication interfaces
8 x 25GbE SFP28 ports
2 x 100GbE QSFP28 ports
1 x 1GbE management port
1 x RJ45 console port
1 x USB 3.0 interface
Storage drive capacity
1 x 960 GB M.2 solid-state drive (SSD)
Memory
128 GB
AC power supply unit
1 x 650 W 100-240 VAC(+/- 10%) AUTO Switching Platinum
1 x universal power cords
DC power supply unit
2 x 650W DC
Operating range: 44-72 VDC
Minimum start up voltage: 44 VDC
power supply unit will not start below 44 VDC.
High Voltage DC (HVDC) power supply unit
2 x 650W DC
Operating range: 180-400 VDC
Minimum start up voltage: 170 VDC
power supply unit will not start below 170 VDC.
Specifications are subject to change without notification.
