Manual Chapter :
100GbE QSFP28 interfaces
Applies To:
Show Versions
F5OS-A
- 1.1.1, 1.1.0
On platforms that include 100GbE interface ports, you can
use only F5-branded 100GbE QSFP28 transceiver modules in those ports.
When a 100GbE interface operates at either 40GbE and 100GbE
speeds, it is considered to be
bundled
.On
the r10000 platform, the 100GbE ports
(1, 2, 11, and 12)
default to 100GbE. The cable that you use when operating at 100GbE with
100GBASE-SR4 transceiver modules is an industry-standard OM4 qualified
multi-mode fiber optic cable with female MPO/MTP connectors at both ends. The
cable that you use with 100GBASE-LR4 transceiver modules is an
industry-standard SMF fiber optic cable with LC duplex connectors and a reach
of up to 10km. You must provide your own cable and F5-branded QSFP28
transceiver modules for 100GbE operation.
