Manual Chapter :
1200W AC power supply LEDs
Applies To:
Show Versions
F5OS-A
- 1.1.1, 1.1.0
The LEDs located on the 1200W AC power supply units
(PSUs) indicate PSU operating state.
Input LED | Output LED | Condition (PWR-0388-xx) |
green solid | green solid | Normal operation |
off | off | Fault: Input UV, Input OV, VSB
SC |
off | amber/yellow solid | Not valid |
green solid | amber/yellow solid | Warning: VSB OC Fault: Fan, OTP, OC, VOUT
OV/UV |
green solid | amber/yellow blinking | Warning: FAN, OTP, OC, VOUT
OV/UV |
green blinking | amber/yellow solid | Fault: Input OV |
green blinking | amber/yellow blinking | Warning: Input OV, Input
UV |
green blinking | off | Not valid |
green solid | green blinking | PS_ON_L is high |
green solid | off | PS_KILL PSU not inserted |
OV - Over Voltage; OTP - Over Temperature
Protection; UV - Under Voltage; OC - Over Current; VSB - Standby Voltage
