Manual Chapter :
Power specifications - r10000 Series
Applies To:
Show Versions
F5OS-A
- 1.1.1, 1.1.0
Series
This table lists power specifications for r10000
Series platforms.
Item | Single PSU | Dual PSU |
Idle power draw (AC
power) | 110VAC input: 555W 230VAC input: 545W | 110VAC input: 555W 230VAC input: 550W |
Idle power draw (DC /HVDC
power) | 44VDC input: 555W 240HVDC input:
575W | 44VDC input: 570W 240HVDC input:
560W |
Typical power draw (AC power;
50% load; temp 25°C) | 110VAC input: 680W 230VAC input: 665W | 110VAC input: 680W 230VAC input: 670W |
Typical power draw (DC /HVDC power;
50% load; temp 25°C) | 44VDC input: 685W 240VDC input: 700W | 44VDC input: 690W 240VDC input: 690W |
Maximum power draw (AC
power) | 110VAC input: 805W 230VAC
input: 785W | 110VAC input: 800W 230VAC
input: 790W |
Maximum power draw (DC /HVDC
power) | 44VDC input: 815W 240HVDC input: 820W | 44VDC input: 805W 240HVDC input: 820W |
Typical heat generated (AC
power) | 110VAC input: 2325 BTU/hour 230VAC input: 2270 BTU/hour | 110VAC input: 2325 BTU/hour 230VAC input: 2290 BTU/hour |
Typical heat generated (DC /HVDC
power) | 44VDC input: 2340 BTU/hour 240HVDC input: 2390
BTU/hour | 44VDC input: 2355 BTU/hour 240HVDC input: 2355
BTU/hour |
Maximum heat generated (AC
power) | 230VAC input: 2680 BTU/hour | 230VAC input: 2700 BTU/hour |
Maximum heat generated (DC /HVDC
power) | 44VDC input: 2340 BTU/hour 240HVDC input: 2800
BTU/hour | 44VDC input: 2355 BTU/hour 240HVDC input: 2800
BTU/hour |
Specifications are subject to change without
notification.
