Manual Chapter : Power specifications - r5000 Series
Applies To:
Show Versions Show Versions
F5OS-A
  • 1.1.1, 1.1.0
Manual Chapter
This table lists power specifications for r5000 Series platforms.
Item
Single PSU
Dual PSU
Idle power draw (AC power)
110VAC input: 360W
230VAC input: 350W
110VAC input: 365W
230VAC input: 355W
Idle power draw (DC
/HVDC
power)
44VDC input: 355W
240HVDC input: 350W
44VDC input: 365W
240HVDC input: 360W
Typical power draw (AC power; 50% load; temp 25°C)
110VAC input: 425W
230VAC input: 415W
110VAC input: 425W
230VAC input: 420W
Typical power draw (DC
/HVDC
44VDC input: 425W
240VDC input: 415W
44VDC input: 430W
240VDC input: 425W
Maximum power draw (AC power)
110VAC input: 485W
230VAC input: 475W
110VAC input: 485W
230VAC input: 480W
Maximum power draw (DC
/HVDC
power)
44VDC input: 490W
240HVDC input: 475W
44VDC input: 495W
240HVDC input: 485W
Typical heat generated (AC power)
110VAC input: 1455 BTU/hour
230VAC input: 1420 BTU/hour
230VAC input: 1435 BTU/hour
Typical heat generated (DC
/HVDC
power)
44VDC input: 1455 BTU/hour
240HVDC input: 1420 BTU/hour
44VDC input: 1470 BTU/hour
240HVDC input: 1455 BTU/hour
Maximum heat generated (AC power)
230VAC input: 1625 BTU/hour
230VAC input: 1640 BTU/hour
Maximum heat generated (DC
/HVDC
power)
44VDC input: 1675 BTU/hour
240HVDC input: 1625 BTU/hour
44VDC input: 1690 BTU/hour
240HVDC input: 1655 BTU/hour
Specifications are subject to change without notification.
